+ Reply to Thread
Page 1 of 2 1 2 LastLast
Results 1 to 15 of 20
Reload Thread: 6x9 speaker help
    Acide24's Avatar
    Acide24 is offline Junior Member
    Apr 2018
    Georgia
    14
    10 Post(s)
    6x9 speaker help
    So I've decided between 2 speakers
    https://www.amazon.com/gp/aw/d/B00C7...GHHKgDi2L&th=1
    https://www.amazon.com/gp/aw/d/B001P86SE8?th=1&psc=1
    I just need something that has a pretty good bass. I'm planning on replacing all my speakers in my 2009 Toyota Camry. I don't really have any intentions on buying a sub or amp since I was pretty satisfied with stock speakers in a 2004 Honda Accord. That said, I am looking for something that is easy to install, specifically for the Camry (front and rear). I am also planning on buying a new hu with crossovers. Do any of you have suggestions? I would like a hu that can do gps as well but I do have a budget for the hu of around $100.
    Louisiana_CRX's Avatar
    Louisiana_CRX is online now dem shoes......
    Aug 2006
    Piney Hills of Louisiana
    37,550
    24 Post(s)
    1886 Post(s)
    Re: 6x9 speaker help
    Quote Originally Posted by Acide24 View Post
    https://www.amazon.com/gp/aw/d/B001P..._1525640776413
    The 2nd link is a 6x8 not 6x9 so it won’t fit without an adapter
    Current 2010 Louisiana USACi State Records :
    Trunk 0-1000.................. 151.3
    StreetBeat 2................... 145.6
    Stock 1801-up.................153.8
    SuperStock 1801-up..........154.2
    Top three in 11 out of 26 power classes and Louisiana USACi Points Leader at 465
    Acide24's Avatar
    Apr 2018
    Georgia
    14
    10 Post(s)
    Wrong link. This is the correct one, same brand. https://www.amazon.com/gp/aw/d/B001P86SE8?th=1&psc=1
    Acide24's Avatar
    Apr 2018
    Georgia
    14
    10 Post(s)
    I read somewhere on here about someone recommending this head unit.
    https://www.amazon.com/gp/aw/d/B076K...rb_top?ie=UTF8
    What are your guys' opinion on this?
    Jeffdachef's Avatar
    Jeffdachef is offline Gunz That Turn on Nunz
    Feb 2013
    South Coast Metro, CA
    15,965
    240 Post(s)
    7783 Post(s)
    1000% chance you'll lose all bass with aftermarket speakers. They are meant for midrange and midbass. Your stock speakers are full range meaning it was geared to produce subsonic bass about down to 30hz. Aftermarkets are meant to be paired with a sub, they do not handle any kind of bass duty at all, absolute sh*t amounts of bass compared to these newer toyota stock speakers.
    What you think will happen will not happen, you'll literally get the opposite results and be left bassless. Your first stop is to get a head unit. a pioneer 201ex would make your setup sound 100x better. Your stock speakers need more power to perform properly. They turn into a completely different beast. Why do I know so much, my personal high school friend has an 09 camry. Replacing the stocks without doing other steps such as major professional acoustical door treatments, and strong enough amplifier power along with a subwoofer will just leave you with beyond garbage results.
    Why the 201ex over the jvc? the internal stock amp is a bit more powerful even though its rated for less. The look as also sick, ads major value to your car along with coolness factor. Just this swap alone will give you almost everything you are looking for. with a lot better sound, louder and more bass.
    If you want more bass than that, i'd recommend adding a subwoofer. The stock toyota speakers are quite a bit better than most of the cheap [email protected] you get outside aka your two choices.
    09 Sienna Subs : Four Team Ascendant 18s......Sub amp: Two Taramps 15k
    Headunit: Pioneer 80PRS................................Mids/Highs amp: CT 500.2, ppi 600.2, ppi 900.4 bridged
    Front stage: Two PWX 10s per door midbass only....... PRV 6MR500 midrange....... Massive CT 2 german tweeters.
    320 amp Singer alt....... 1 group 34 under the hood 6 group31 agms in the back 560 amp hours total.
    BOOMINGRANDPA's Avatar
    BOOMINGRANDPA is online now CHEAP A/F
    Jan 2017
    NC
    6,187
    18
    29 Post(s)
    2486 Post(s)
    if u like factory speakers listen to jeff, get mono amp and a 12" sub with new hu, then factory speakers will have xover so they play clean no distortion and sub will handle the bass..
    KENWOOD X301 HU, PRECISION POWER Phantom 1000 (@2ohm), pioneer 3003 12 1.63cfad ported, soundqubed 6.5" coax/doors, hp xover (hu), AGM starting batt...
    2 ohms rule
    Quote Originally Posted by Popwarhomie View Post
    Shit Ill sleep with you if you do that for me..
    Acide24's Avatar
    Apr 2018
    Georgia
    14
    10 Post(s)
    Interesting...so how much would this cost me overall? Also, to me the stock camry speakers are absolute **** even compared to my honda accord 2004 stock speakers. Could it be that the head unit is so bad that the speakers are not being fully utilized?
    Acide24's Avatar
    Apr 2018
    Georgia
    14
    10 Post(s)
    Quote Originally Posted by Jeffdachef View Post
    What's the difference between the 201ex and the 200ex? Also would I be better off with this, if I were potentially looking into upgrading in the future? The hu installation for the camry does not look too hard, however do I need to buy other things to ensure it fits into the car or is it just a direct fit?
    https://www.amazon.com/gp/aw/d/B06W2...earch-keywords
  9. #9
    Jeffdachef's Avatar
    Feb 2013
    15,965
    240 Post(s)
    7783 Post(s)
    yes the stock head unit s*cks donkey di*ck. With a better EQ, and EQ work you can make them sound pretty decent. the extra amount of power will get them hitting pretty decent too. Only other thing i'd do is get a sub.
    The 2003 to 2007 hondas have a 10 watts x 4 channels of power in their head unit. Your current camry is around 3-5 watts for the stock head unit.
  10. #10
    Jeffdachef's Avatar
    Feb 2013
    15,965
    240 Post(s)
    7783 Post(s)
    Buy it from this website, enter in your vehicle make and model and they include a free dash kit to make everything look flush. Includes the wiring harness needed for install as well as instruction manuals etc...
    https://www.crutchfield.com/S-P0hYWi...AVH-201EX.html
  11. #11
    Acide24's Avatar
    Apr 2018
    Georgia
    14
    10 Post(s)
    When looking at the 2 types of installation kits they have, 1 is free and the other is $80. Under the vehicle features retained, aux and bluetooth are not checked. I'm a little confused by this. Is this just saying that if I had aux and bluetooth before from the stock head unit, it won't be available? Isn't this implied since I am replacing the head unit or is it saying I won't have aux or bluetooth capabilities at all? Also, is it possible to make this head unit work with the steering wheel controls?
  12. #12
    Jeffdachef's Avatar
    Feb 2013
    15,965
    240 Post(s)
    7783 Post(s)
    Ignore that, the head unit is bluetooth capable and has an aux connection in the rear that you can run to the side. You just wont be using the stock aux connection. I'd go with the free one especially if you use bluetooth as your main music source. Retaining the steering wheel controls is what that 80 dollars is, which i dont feel is worth it at all.
  13. #13
    Acide24's Avatar
    Apr 2018
    Georgia
    14
    10 Post(s)
    Ok cool, what do you mean by running the the aux connection to the side?
  14. #14
    Acide24's Avatar
    Apr 2018
    Georgia
    14
    10 Post(s)
    The pioneer 200ex seems to be the better deal. The only thing different is that the 200ex has sub preamp outputs, and the 201ex doesn't. But the 201ex has switchable rear preamp outputs while the 200ex doesn't. What's the difference and is it worth the $30 difference?
  15. #15
    Jeffdachef's Avatar
    Feb 2013
    15,965
    240 Post(s)
    7783 Post(s)
    there's an aux connection in the rear of the head unit. but to be honest, just give up the aux completely, its sh*t compared to bluetooth on an aftermarket head unit and you can connect multiple phones to the bluetooth as well and seemlessly switch over whenever you want so yeah aux is obsolete.
+ Reply to Thread
