+ Reply to Thread
Results 1 to 12 of 12
Reload Thread: good 6x9 speakers?
    TimV's Avatar
    TimV is offline Junior Member
    Feb 2018
    Pa
    2 Post(s)
    good 6x9 speakers?
    Hello, I'm currently looking into upgrading my rear 6x9s and just want to see what more experienced people have to say.
    Right now I'm in between the Infinity REF-9623ix 300W Max 6" x 9" 3-Way and the JBL GTO939 Premium 6 x 9. Just from some light research these seem to be my best options, however I don't have any experience with mid-range speakers. Any and all suggestions are greatly appreciated!
    Here are the links to the speakers:
    https://www.amazon.com/JBL-GTO939-Pr...C0KPB7TG8FN5MP
    giltyler's Avatar
    giltyler is online now Senior VIP Member
    Jul 2013
    DFW METROPLEX
    310
    1 Post(s)
    91 Post(s)
    Re: good 6x9 speakers?
    What will power these Head unit or amp
    How much will you be able to spend.
    1987 THUNDER ON WHEELS NATIONAL CHAMPION 0-100 Watt class
    Avatar Tony Mannino "The Godfather" M&M Electronics with me at Finals
    Reference amedeuce papermaker shizzon
    Louisiana_CRX's Avatar
    Louisiana_CRX is online now dem shoes......
    Aug 2006
    Piney Hills of Louisiana
    37,550
    24 Post(s)
    1886 Post(s)
    I have a set of old school very rare Pioneer Rev 6x9swith the yellow Kevlar cone that will blow you away ..I ran them for a short time in the rear deck of my 67 Camaro ..it sounded like I had mini subs the midbass was so strong and just the right amount of highs ..Everything blended so nicely and crystal clear ...it’s a shame Pioneer no longer makes these if you can find a set grab them the last used set I saw on eBay went for $150 they cost $200 new back in the day ..they have a quality high end real crossover built into the speaker connection pod ..I might sale my set but I doubt I’ll get rid of them ...
    Current 2010 Louisiana USACi State Records :
    Trunk 0-1000.................. 151.3
    StreetBeat 2................... 145.6
    Stock 1801-up.................153.8
    SuperStock 1801-up..........154.2
    Top three in 11 out of 26 power classes and Louisiana USACi Points Leader at 465
  4. Likes TimV liked this post
  5. #4
    BOOMINGRANDPA's Avatar
    BOOMINGRANDPA is online now CHEAP A/F
    Jan 2017
    NC
    6,187
    18
    29 Post(s)
    2486 Post(s)
    i think u meant to include this link https://www.amazon.com/Infinity-REF-.../dp/B01E8OZ1KM they probably about the same speakers except 1 is a 3 way, many of us don't run rear speakers at all.. if u have a sub and use hp xovers on speakers as u should get 3 way for front (if u have them in front) and get very very cheap dual cone midrange for rear deck u don't need tweeter back there., parts express has grs 6x9 for like $8 each.. deadening the door is just as important as the speaker, u can also use the foam baffles $10 on rear deck to prevent sub from missing up sound of the speakers
    KENWOOD X301 HU, PRECISION POWER Phantom 1000 (@2ohm), pioneer 3003 12 1.63cfad ported, soundqubed 6.5" coax/doors, hp xover (hu), AGM starting batt...
    2 ohms rule
    Quote Originally Posted by Popwarhomie View Post
    Shit Ill sleep with you if you do that for me..
  6. #5
    TimV's Avatar
    Feb 2018
    Pa
    2 Post(s)
    Just a head unit and I would like to stay under $150 if possible
  7. #6
    TimV's Avatar
    Feb 2018
    Pa
    2 Post(s)
    Quote Originally Posted by BOOMINGRANDPA View Post
    thank you for the info, I have a 2002 chevy cavalier and haven't made door pods (mostly because I'm not very skilled in that sort of work) so that's the only reason why im replacing the rear deck. I can only fit a 4x6 in the doors unless there's a way that I'm unaware of.
  8. #7
    Jan 2017
    NC
    6,187
    18
    29 Post(s)
    2486 Post(s)
    Quote Originally Posted by TimV View Post
    lol i had 96 cav.. i thought mine took 6.5" i'll check
    2 ohms rule
  9. #8
    Jan 2017
    NC
    6,187
    18
    29 Post(s)
    2486 Post(s)
    u don't have monsoon system right? even without it looks like 4" 4x6 maybe few 5 1/4 will fit but must be very shallow mount under 2".. thats *****.. u really need hp xover, u say just hu power is it stock?, if not u need hu with xovers and 24 bit da convertor both will help a ton, louder and less distortion.. u can set door speakers to play 120hz up and rears to play down to 70hz.. u just need any type of sub (well not any) but small 10" sub even in small box with small used amp or even a dualxpr82d 2 channel $59 walmart (guy here tested does pretty good power) and u would have full range sound speakers wouldn't distort and little bass.
    2 ohms rule
  10. #9
    Aug 2006
    37,550
    24 Post(s)
    1886 Post(s)
    I’d let the Pioneer Revs go for $140 shipped they are mint like new ..if interested you can PM and I’ll send you some pics ..they have a magnet/motor bigger than some subs ..these are truly unique and high quality 6x9s
  11. #10
    TimV's Avatar
    Feb 2018
    Pa
    2 Post(s)
    No I don't have a monsoon system, and i haven't actually taken my doors apart. That's just what I've researched online from multiple sites.
  12. #11
    giltyler's Avatar
    Jul 2013
    DFW METROPLEX
    310
    1 Post(s)
    91 Post(s)
    https://www.crutchfield.com/p_108693...1i.html?tp=105
    Nice price on a quality speaker
    2ohm will help with deck power for decent volume
  13. #12
    JL_pinoy's Avatar
    JL_pinoy is offline Junior Member
    Mar 2018
    Manila, Philippines
    26
    1 Post(s)
    Audiofrog GS690.
    Sent from my Flare S5 using Tapatalk
+ Reply to Thread
