+ Reply to Thread
Results 1 to 7 of 7
Reload Thread: Help, want to replace factory door speakers
    roxbury29's Avatar
    roxbury29 is offline Junior Member
    Sep 2017
    NW Indiana
    13
    3 Post(s)
    Hi, need some help
    Have a F150 with Sony factory system
    I already upgraded the Sub Amp and custom box/ w-Sundown Woofer.
    Wanting to find a good replacement for the factory speakers, will not be amplifing them.
    just power from factory HU.
    JBL/Infinity/Polk/etc..
    is it worth changing ?
    Jeffdachef's Avatar
    Jeffdachef is online now Gunz That Turn on Nunz
    Feb 2013
    South Coast Metro, CA
    16,196
    245 Post(s)
    7919 Post(s)
    Re: Help, want to replace factory door speakers
    no, The factory amp's built in crappy EQ curve and agressive high pass filter is there and you cant get rid of it. Its there because its compensating for ****** factory speakers. Now all your aftermarket equipment is subjected to that.
    What that means is, there is a VERY good chance any aftermarket replacement will sound like garbage compared to stock.
    09 Sienna Subs : Four Team Ascendant 18s......Sub amp: Two Taramps 15k
    Headunit: Pioneer 80PRS................................Mids/Highs amp: CT 500.2, ppi 600.2, ppi 900.4 bridged
    Front stage: Two PWX 10s per door midbass only....... PRV 6MR500 midrange....... Massive CT 2 german tweeters.
    320 amp Singer alt....... 1 group 34 under the hood 6 group31 agms in the back 560 amp hours total.
    Boomin_tahoe's Avatar
    Jul 2005
    WA
    14,539
    42 Post(s)
    6181 Post(s)
    Ugh...factory HU. Jeff here despises those....and once again, I cannot disagree with him.
    This issue is a clean signal to your speakers. Most people don't realize the garbage signal by using a LOC instead of just simply replacing the HU. Think of it as the HU being the brains of the system. Then aftermarket amp(s) then speakers. Once HU is swapped out, get a small 4 ch amp to power the spkrs.....will sound 10000X better than factory.
    97 4 dr. Tahoe
    Interstate battery
    Alpine 9835
    Polk Audio MM6501 comps
    Soundstream Rubicon 1.2500D & 4.500 amps (New amps coming soon)
    roxbury29's Avatar
    Sep 2017
    NW Indiana
    13
    3 Post(s)
    Hi, thanks
    with the Nav/Bluetooth and other factory settings. changing HU isn't feasible for me at this time.
    I already upgraded the Bass( Amp and Custom sub ) and it make a huge improvement. just thought if it would be worth changing the speakers or just leave it.
    for the Sub there was a factory sub, I removed it added a 500W D ( Alpine amp ) to a 10" Sundown sub in a sealed custom box.
    bandit_kb's Avatar
    bandit_kb is offline Senior VIP Member
    Mar 2014
    austin,tx
    263
    1 Post(s)
    110 Post(s)
    The stock system doesn't sound very good with upgraded speakers as mentioned above. I'd tell you to get a dsp first
    roxbury29's Avatar
    Sep 2017
    NW Indiana
    13
    3 Post(s)
    ^ I know , they(Ford) could have did a better job.
    Mazda Bose and other systems from the factory are soo much better.
    Jeep-Alpine is Worse
    luckily the factory sub I removed, and the signal coming from the HU doesn't reduce the signal as I turn up the volume
    roxbury29's Avatar
    Sep 2017
    NW Indiana
    13
    3 Post(s)
    Few local stereo stores said i would get an improvement with just changing speakers out
    ( if I don't plan on adding an amp ) to stay basic;
    and pick one of these;
    Memphis PRX57
    Infinity 682.11CF
    or even Polk DB572
+ Reply to Thread
  1. HELP! Want to add 15" flame q and amp to premium 350 7 speaker factory system.
    By Enforced Reaper in forum Wiring, Electrical and Installation Help
    Last Post: 08-06-2011, 07:35 AM
  2. Help want to trade home theater speakers for car audio
    By TJones, CPII in forum Miscellaneous Classifieds
    Last Post: 02-18-2008, 01:57 PM
  3. Mazda cx7 9 speaker bose want to replace with alpine HU need help
    By integrity in forum Wiring, Electrical and Installation Help
    Last Post: 08-28-2007, 11:29 PM
  4. Replies: 22
    Last Post: 07-20-2007, 04:52 PM
  5. Need to replace factory speakers in 99 Blazer
    By hawk45 in forum Speakers
    Last Post: 10-10-2005, 04:59 PM
