+ Reply to Thread
Page 1 of 7 1 2 3 4 5 6 7 LastLast
Results 1 to 15 of 93
Reload Thread: Factory rear panel install
    Rzza's Avatar
    Rzza is offline Member
    Sep 2017
    Detroit
    64
    37 Post(s)
    I've been building this SQ system for a few weeks now and I just realized that my Dodge Dart has speaker cutouts in the rear panel. This site doesn't allow me to post a photo, I get an error every time. Its oddly, (2) 3.5" and (1) 8 inch. My question is, will I need to build an enclosure if I drop an 8" sub in there or will my trunk act as an enclosure? I feel like my options have opened up a ton now but I just need to know the extent of use I can get from the rear deck 8".
    blazian87's Avatar
    blazian87 is online now CarAudio.com Elite
    Mar 2007
    Los Angeles, CA
    1,277
    7 Post(s)
    487 Post(s)
    This really depends on the sub you're using. If you want to just drop it in without an enclosure, then find a sub that works good in infinite baffle. You're probably have to do a little cutting or some type of fabrication to make it work. Make sure it has a nice seal between the trunk and cabin.
    2009 Scion TC
    HU: Alpine INA-W910
    Processor: Alpine PXA-H800
    Amps: B2 Audio Zero.5R - Zapco Z-150.4LX - Zapco Z-150.2LX
    Front Stage: New front stage TBA~, JL ZR800's
    Subs: 4 10" Dayton HO's 3.2 cu ft @ 30hz
    Electrical: Singer 320a, XS D2400, Juicebox Lithium 20ah
  3. Thanks Rzza thanked for this post
  4. #3
    Rzza's Avatar
    Sep 2017
    Detroit
    64
    37 Post(s)
    Re: Factory rear panel install
    I think I want to just add some full range, I have subs already. How can I add 3 speakers without adding another amp? I already have two amps. I assume I cannot use my sub amp because it's not full range. I have a 4 channel amp and 4 door speakers already. Can I share channels?
  5. #4
    blazian87's Avatar
    Mar 2007
    Los Angeles, CA
    1,277
    7 Post(s)
    487 Post(s)
    Quote Originally Posted by Rzza View Post
    Theres no point of adding a 3rd full range speaker honestly. It's better if you just use the last 2 channels for a pair of rear speakers and call it a day.
    2009 Scion TC
    HU: Alpine INA-W910
  6. #5
    Rzza's Avatar
    Sep 2017
    Detroit
    64
    37 Post(s)
    I have 4 door speakers and 2 subs in the trunk. I want to fill in the speaker holes in the back panel, it's (2) 3.5" and (1) 8". What type of speakers would you be putting in there? I want it louder and more SQ
    I was thinking about switching my 4 channel to a 5 channel and using the 5th for a full range 8" speaker that fits in the hole. Is this a bad idea? I can turn down the speaker levels on the 4 doors if I have to, in order to hear the 8" better.
  7. #6
    LosIsATool's Avatar
    LosIsATool is online now CarAudio.com Veteran
    Apr 2011
    Pensacola, Florida
    37
    18,379
    110 Post(s)
    7897 Post(s)
    If you are building for sound quality you are going the wrong way.
    Less is more.
    2014 Ford Fusion SE 2.0T
    JBL MS-8
    Zapco ST-4X SQ, ST-1000XMii
    IDQ12v4 1.8cu sealed
    Alpine SPX Pro ring radiators
    Hertz HV165XL
    Knuconceptz OFC, Custom fit Soundrive RCAs.
  8. #7
    Jeffdachef's Avatar
    Jeffdachef is offline Gunz That Turn on Nunz
    Feb 2013
    South Coast Metro, CA
    16,187
    245 Post(s)
    7915 Post(s)
    sounds like your idea of SQ is sound quantity rather than quality. There is no SQ when rear speakers are involved. 5 channels are basically 4 channels and subwoofer amp combined into one.
    What you need to do is do a proper front stage setup with quality drivers, good head unit that can run active network crossovers and powerful amp with 150 watts to the mid and tweet along with acoustical door treatments. Sound quality and sound stage will be much better than whatever you had planned and you will be loud enough to be heard a football field away.
    09 Sienna Subs : Four Team Ascendant 18s......Sub amp: Two Taramps 15k
    Headunit: Pioneer 80PRS................................Mids/Highs amp: CT 500.2, ppi 600.2, ppi 900.4 bridged
    Front stage: Two PWX 10s per door midbass only....... PRV 6MR500 midrange....... Massive CT 2 german tweeters.
    320 amp Singer alt....... 1 group 34 under the hood 6 group31 agms in the back 560 amp hours total.
  9. #8
    LosIsATool's Avatar
    Apr 2011
    Pensacola, Florida
    37
    18,379
    110 Post(s)
    7897 Post(s)
    Quote Originally Posted by Jeffdachef View Post
    Don't forget about surround sound upmixers and differential rear fill. But I doubt the OP can do that.
    JBL MS-8
    Hertz HV165XL
  10. #9
    BOOMINGRANDPA's Avatar
    BOOMINGRANDPA is offline CHEAP A/F
    Jan 2017
    NC
    6,733
    17
    30 Post(s)
    2687 Post(s)
    u can run 8 4 ohm speakers off a 4 channel amp.. that said don't put more speakers in rear, speakers should be in front of u.. sounds like u need better front speakers with bigger 2 channel amp instead of 4 and just run rears on hu..
    KENWOOD X301 HU, PRECISION POWER Phantom 1000, FU 750 12, 2.1cfad ported, soundqubed 6.5" coax/doors, hp & lp xover on hu, AGM starting batt...
    2 ohms rule
  11. Thanks Rzza thanked for this post
  12. #10
    Rzza's Avatar
    Sep 2017
    Detroit
    64
    37 Post(s)
    So what you say makes sense so I went to my car and apparently I have 3 empty speaker holes in my front dash for (3) 3.5". My question to you is, how do I install them and have my head unit recognize them so I can adjust them properly? Thanks!
  13. #11
    LosIsATool's Avatar
    Apr 2011
    Pensacola, Florida
    37
    18,379
    110 Post(s)
    7897 Post(s)
    No head unit will properly run a center channel if that's what you have.
    JBL MS-8
    Hertz HV165XL
  14. #12
    Rzza's Avatar
    Sep 2017
    Detroit
    64
    37 Post(s)
    Thanks, can I install the three dash speakers and have control of them at all?
  15. #13
    LosIsATool's Avatar
    Apr 2011
    Pensacola, Florida
    37
    18,379
    110 Post(s)
    7897 Post(s)
    You might want to find a good shop and get them to show you how it works. I don't think you are understanding.
    JBL MS-8
    Hertz HV165XL
  16. #14
    LosIsATool's Avatar
    Apr 2011
    Pensacola, Florida
    37
    18,379
    110 Post(s)
    7897 Post(s)
    If you do go to a shop don't buy anything before posting it here
    JBL MS-8
    Hertz HV165XL
  17. #15
    Rzza's Avatar
    Sep 2017
    Detroit
    64
    37 Post(s)
    Yeah I came here for answers because my shop literally cannot answer my questions regarding speaker resistance. If you are sick of replying to noob questions then you should just disregard them and move on. What's the point in replying to a question saying "I don't think you're getting it"? Yeah obviously I am not that's why I asked.
+ Reply to Thread
  1. Replies: 0
    Last Post: 06-23-2007, 10:01 AM
  2. Rear Deck installation problem
    By toosh in forum Wiring, Electrical and Installation Help
    Last Post: 01-06-2004, 07:01 PM
  3. rear panel removal
    By koop in forum Wiring, Electrical and Installation Help
    Last Post: 05-21-2002, 09:32 PM
  4. rear speaker installation
    By Unregistered in forum Wiring, Electrical and Installation Help
    Last Post: 02-07-2002, 01:28 PM
  5. Rear Engine Install?
    By Registered in forum General Discussion
    Last Post: 01-14-2002, 11:47 AM
