+ Reply to Thread
Results 1 to 2 of 2
Reload Thread: Wiring to 1 ohm using 2 speaker terminals mono amp
    GtzStunna's Avatar
    GtzStunna is offline Junior Member
    Jul 2017
    Canada
    1 Post(s)
    Hi, I'm going to wire my (2) Rockford fosgate subs dual 4 ohm to a mono amp that has 2 sets of speaker output terminals I want to use both instead of wiring the subs in parallel. How would I wire the subs to get 1 ohm and use both the terminals?
    Amp is MB Quart DA1-1800.1
    BOOMINGRANDPA's Avatar
    BOOMINGRANDPA is online now CHEAP A/F
    Jan 2017
    NC
    5,957
    18
    29 Post(s)
    2401 Post(s)
    Re: Wiring to 1 ohm using 2 speaker terminals mono amp
    just wire + - terminal on amp to each sub.. as far as sub itself wire +to + & -to - then out to amp as i said..
    KENWOOD X301 HU, PRECISION POWER Phantom 1000, FU 750 12, custom 2.11 cf ad ported tuned @ 36hz 30.375 port area, soundqubed 6.5" coax, hp xover (hu), AGM starting batt...
    2 ohms rule
    Quote Originally Posted by Popwarhomie View Post
    Shit Ill sleep with you if you do that for me..
  3. Thanks GtzStunna thanked for this post
+ Reply to Thread
  1. Getting the speaker wire to the sub via terminals or no...?
    By taylor3333 in forum Enclosure Design & Construction Help
    Last Post: 06-14-2010, 05:31 PM
  2. want to buy a cheap working mono amp 300-600 RMS @ 2 ohm
    By Xenozx in forum Wanting to Buy (WTB) - Car Audio
    Last Post: 05-02-2010, 09:31 PM
  3. How to wire this 4ohm dvc sub to a 08zx750.1 kicker mono amp?
    By ExplicitUrSelf in forum General Discussion
    Last Post: 03-22-2009, 06:37 PM
  4. Help, wiring 1 ohm, but speaker wire terminals too small
    By Supergumby5000 in forum Wiring, Electrical and Installation Help
    Last Post: 01-28-2007, 12:59 AM
  5. Where to buy screws for speaker terminal on amp?
    By chargers in forum Amplifiers
    Last Post: 08-29-2006, 12:17 AM
