ok If I have a pair of kenwoods 6x9 55 rms, I want to run them at 2ohms to get most out of a 4 channel amp ( pioneer gxm-374) it's 35rms at 4 ohms x 4, & 50 rms x 4 at 2ohms should I try this would it sound a bit louder and cleaner than running them at 4 ohms? ,,,,
the other b channel I will be running them at 4 ohms since I will use 5-1/4 spkrs. for the doors...
Ok just to make sure if I wire +to+ & -to- it's at 2ohm load correct ??
do i just hook up to 1 channel, either left or right or both are used ?? not quite sure on this ,? can some one explain a bit thanks
since it's a 4 channel amp all using the hpf switch
Register To Reply
Bookmarks
