Results 1 to 7 of 7
Reload Thread: what exactly is sensitivity?
    Mar 2004
    Collierville, TN
    26
    67
    keep in mind that i'm a newbie to this type of thing. i've been in the market for a new speaker system for my car...what i want to know is what is the sensitivity mean....everything in my car is Alpine....i've been looking at the Alpine SPS-170A Coaxial Speaker which i can get for $55 a pair or the Alpine SPR-174A Coaxial Speaker which i can get for $99 a pair.....now i assume that the more expensive model would be the better one....but then i look at the sensitivity of the less expensive one and its higher.....the cheaper model has a sensitivity of 92db and the more expensive model has a sensitivity of 87db....a friend of mine told me it has to do with sound quality but i figured i'd ask you guys....WHAT DOES SENSITIVTY MEAN!?
    Car: 1995 Nissan 240sx
    Head-Unit: Alpine CDA-9807
    Speaker Amp: Alpine MRV-F340
    Sub Amp: Alpine MRD-M501
    Subwoofers: (2) Alpine SWR-1221D
    Speakers: stock Nissan speakers
    Wiring: Tsunami 4-guage multi-amp kit
    DJ FURY's Avatar
    DJ FURY is offline Senior VIP Member
    Feb 2004
    TX
    491
    Re: what exactly is sensitivity?
    Sensitivity ratings simply tell you how much sound a speaker will produce for a given power input.
    Speaker efficiency is the ability of the speaker to do work or use power.......hope this helps
    DJ FURY's Avatar
    Feb 2004
    TX
    491
    [QUOTE=Jmac]
    It has absolutely NOTHING to do with sound quality ...
    And Jmac is right on with this one
    ladiesman8527's Avatar
    ladiesman8527 is offline The Man
    Mar 2004
    Collierville, TN
    26
    67
    so is a higher sensitivity neccesarily better?.....right now my subwoofers can get so loud that they drowned out the speakers....any suggestions on what sensitivity i should look for?
    somekook's Avatar
    somekook is offline only 15"s
    Jul 2003
    Daytona Beach, FL
    26
    1,178
    Quote Originally Posted by Jmac
    Sensitivity is how loud a speaker is with 1 watt ... in other words, it gives an idea of how loud a speaker is at low volumes ...
    Efficiency (1W/1M) = 112 + 10*Log(9.64*10^-10*Fs^3*Vas/Qes)
    Vas = equivalent compliance measured in liters
    Sensitivity is also known as efficiency in some cases. In other cases, sensitivity is the the loudness using 2.828427125 volts instead of 1 watt ...
    2.83 volts @ 8 ohms = 1 watt
    2.83 volts @ 4 ohms = 2 watts
    2.83 volts @ 2 ohms = 4 watts
    2.83 volts @ 1 ohm = 8 watts
    im sure a newbie is going to understand that.... lol. anyways its important to remember that sensitivity may give you an idea of how loud a speaker will get with low power, but with higher wattage the 87 db speaker may easily be able to get louder. so dont assume a higher sensitivity is always a louder speaker
    Dec 2003
    Atlanta
    122
    you're a ladies man and you don't know what sensitivity is?
    :hilarious:
    Mar 2004
    Collierville, TN
    26
    67
    lol i dont know how i should reply to that one
  1. car alarm sensitivity
    By zerohertz in forum Car Video, Security and Electronics
    Last Post: 03-02-2004, 12:53 AM
  2. sensitivity
    By snfsh79077 in forum Subwoofers
    Last Post: 09-05-2003, 02:49 AM
