Page 1 of 2 1 2 LastLast
Results 1 to 15 of 18
Reload Thread: Adding rear speakers, recommendations?
    nstillmatic's Avatar
    nstillmatic is offline Member
    Oct 2010
    Cleveland, OH
    79
    4 Post(s)
    This is my current setup (no rear speakers):
    HAT Imagine I61 6.5" component set -> Sundown SAX 125.2
    Sundown SA-15 -> Sundown SAX-1200D
    I'm swapping out my SAX 125.2 for a 125.4 and would like to drop something in the rears. Are the Sundown Neo Pro 6.5"s a good option? Or HAT's Mirus set?
    HU: Pioneer AVH-P4200DVD
    EQ: Clarion EQS746
    Front: HAT Imagine l61-2
    Sub: 15" Sundown SA-15
    Amp(High): Sundown SAX-125.2
    Amp(Low): Sundown SAX-1200D
    jrdnhsnbrg's Avatar
    jrdnhsnbrg is offline Pimped my grandma's ride
    Aug 2012
    Eau Claire, WI
    23
    1,877
    689 Post(s)
    Re: Adding rear speakers, recommendations?
    Don't. Last thing you want is your rear stage drowning out your front stage.
    2013 Ford Flex Ecoboost AWD “Turbo Fridge”
    Shok Triton 15”
    3.8 cubic feet tuned to 32
    DC 1.2k
    Oct 2010
    Cleveland, OH
    79
    4 Post(s)
    I have a hatchback with the rear speakers disconnected. Problem is without speakers plugged in the rear.. driving with the windows open or on the highway the sound is drowned out like crazy.
    EQ: Clarion EQS746
    jrdnhsnbrg's Avatar
    Aug 2012
    Eau Claire, WI
    23
    1,877
    689 Post(s)
    Quote Originally Posted by nstillmatic View Post
    You need to do some sound deadening throughout the car then
    Shok Triton 15”
    DC 1.2k
    Oct 2010
    Cleveland, OH
    79
    4 Post(s)
    Both doors are sound deadened already. I spend most of my time driving on the highway for work and the volume from the front components is drastically reduced with windows open. It is like night and day.
    EQ: Clarion EQS746
    jrdnhsnbrg's Avatar
    Aug 2012
    Eau Claire, WI
    23
    1,877
    689 Post(s)
    That's because you have your windows open, you either need more powerful speakers and a more powerful amp for them. Adding more speakers won't help.
    Shok Triton 15”
    DC 1.2k
    jrdnhsnbrg's Avatar
    Aug 2012
    Eau Claire, WI
    23
    1,877
    689 Post(s)
    Not to mention the window rolled down bounces the rear wave directly at the speaker instead of the deadener you hopefully have on the inside of the outer skin of the door.
    Shok Triton 15”
    DC 1.2k
    T3mpest's Avatar
    T3mpest is offline CarAudio.com Veteran
    Mar 2005
    Illinois
    3,054
    1 Post(s)
    372 Post(s)
    If it's a small vehicle adding some extra speakers in the rear will help fix the issue. You could also try a louder set of speakers up front instead which would sound better when it's all said and done. If you knew that's how you usually drive I would have went with some sort of pro audio styled car audio speaker to start with. (not true pro audio though since I'm assuming you need the passive x-over). A good real 92-94dbw/1w/1m speaker should be able to overcome road noise like that. I know my last setup using 8's and horns, swear to god couldn't even hear ANY road noise with the windows down going 80 on the highway. The normal wind noise got drowned out, and that was on any type of music, not just rap lol. That was a 97db/1w/1m front on around 125 watts, from 3/4 volume and up you had no issues with road noise with the windows down. Always build your system aruond what your using it for. If your mostly on the highway windows down then dont' go with a "SQ" car audio component set. Get something in a similar budget that will get louder, even if it gives up a bit of fidelity to get there, you can't hear it over road noise anyways.
    Quote Originally Posted by sdmtnbiker420 View Post
    JL is for ballers. Theres a reason all the biggest rappers sing about JL, Zapco, Alpine..... and not Lightning audio or Pyle. It's all about the BALLER FACTOR.
  9. #9
    Side Show's Avatar
    Side Show is offline Bringin The Noise
    Aug 2007
    Australia
    3,337
    457 Post(s)
    install some midbass drivers..... I don't like the sound of rears in anycar, specially if they have tweets
  10. #10
    zako's Avatar
    zako is offline CarAudio.com Elite
    Jan 2011
    TX
    1,347
    238 Post(s)
    Quote Originally Posted by jrdnhsnbrg View Post
    If the guy listens music with windows open on highway, the SQ has already gone out of window. The sound deadening will not help with that. At this point, SPL is the only thing you can optimize, so I'd say add the rear speakers. Hybrid Audio Mirus should be a good choice, specially if the OP already likes the HAT Imagines in front.
  11. #11
    jrdnhsnbrg's Avatar
    Aug 2012
    Eau Claire, WI
    23
    1,877
    689 Post(s)
    Quote Originally Posted by zako View Post
    I was thinking for road noise, he said driving down the highway in general.
    Shok Triton 15”
    DC 1.2k
  12. #12
    Oct 2010
    Cleveland, OH
    79
    4 Post(s)
    Road noise is not really a problem, it's just the wind from having the windows down at higher speeds (highway). I am impressed with the Imagine's up front (especially SQ). Wouldn't the pro audio style of the Neo Pro 6.5"s work better in the rear for this application than Mirus? I am satisfied with the Imagine set, but wouldn't something with more punch be ideal for the back?
    EQ: Clarion EQS746
  13. #13
    trumpet's Avatar
    trumpet is offline CarAudio.com Veteran
    Jan 2011
    Grafton, ND
    37
    6,792
    43 Post(s)
    1859 Post(s)
    A pro audio type of speaker has a lot greater efficiency than standard speakers, so with much less power they will be equally as loud as your front speakers. What I'm getting at is adding PA speakers in the rear is going to pull the sound to the back hard.
    Rubyserv - I believe I can delivery joy every time you drive by the power of an incredible sound system. Barry Schanz, Owner
    Authorized dealer for CDT Audio - Shop With Us Now.
    FB | Rubyservsales
    IG | Rubyserv
  14. #14
    Bcruze1's Avatar
    Bcruze1 is offline Junior Member
    Nov 2013
    Middle east
    18
    10 Post(s)
    Sorry for hijacking the thread, im in a same situation as the thread starter, i also want something loud enough that can be heard even when window is down.
    Is The DLS C6A components ok for it which has 93 db/1w/1m & 60 w rms Upto 90 w max. I will be powering them wid Phoenix gold Z500.4 amp @ 75 w rms. These will be 2 in front & 2 in the rear. Will it be loud???
  15. #15
    Oct 2010
    Cleveland, OH
    79
    4 Post(s)
    Quote Originally Posted by trumpet View Post
    Which would you suggest then for a windows down situation? I get that PA speakers in the rear will be higher volume but wouldn't that be the best way to combat the wind? I have a dedicated EQ with F/R knob for easily adjusting the fade back and forth.
    Sundown Neo Pro v2 6.5":
    http://www.woofersetc.com/p-11829-pa...e-speaker.aspx
    HAT Mirus M61-2 6.5":
    http://store.12velectronics.com/miru...l-speaker-set/
    EQ: Clarion EQS746
  1. Recommend me some rear speakers
    By mooseknuckle in forum Speakers
    Last Post: 11-01-2012, 07:22 PM
  2. Rear speaker Recommendations
    By BlackHaze in forum Speakers
    Last Post: 05-06-2008, 09:36 PM
  3. 3.5" Rear Speakers - Recommendations
    By rick3000 in forum Speakers
    Last Post: 11-20-2007, 10:19 AM
  4. rear speaker wiring
    By birdman420 in forum Wiring, Electrical and Installation Help
    Last Post: 01-19-2002, 10:34 PM
  5. Need Help with replacing rear speakers....
    By torothebull in forum Subwoofers
    Last Post: 12-11-2001, 10:43 PM
