Results 1 to 8 of 8
Reload Thread: 6.5 speaker
    irocwagon's Avatar
    irocwagon is offline Member
    Dec 2009
    cola sc
    117
    1 Post(s)
    6.5 speaker
    Vehicle is a party bus..looking for speaker recommendations. It currently has 8 ppi Sedona series,4 are blown or just tweets play...they're running off hifonics Zeus ,I think 100x4. Need to replace them..around $60.00 a set..subs used are 2 JL 12w1s on ppi600...also head unit is located in rear with passengers,so it's getting turned all the way up,so need something with stamina.
    Jeffdachef's Avatar
    Jeffdachef is offline Gunz That Turn on Nunz
    Feb 2013
    South Coast Metro, CA
    15,328
    220 Post(s)
    7369 Post(s)
    Re: 6.5 speaker
    thats gonna be hard with the abuse it gets... Do you want it just loud? you can go for pro audio speakers, it can go very loud to ear bleeding volume levels with ease, it will be to the point where people wont even want to turn it up any louder. With the head unit at a lower level this will keep the signal clean and unclipped which means your less likely going to burn another set of speakers. These PA speakers can handle a lot of power also. See crescendo PWX or soundqubed Pro audio or sundown Neos or seleniums.
    https://www.youtube.com/watch?v=uSD_osM_E1w this is how loud and clean it sounds on very little power around 12 rms per speaker, but it can handle up to 150 rms easily. I dont think any of your party customers can handle fully powered PA speakers.
    09 Sienna Subs : Four Team Ascendant 18s......Sub amp: Two Taramps 15k
    Headunit: Pioneer 80PRS................................Mids/Highs amp: CT 500.2, ppi 600.2, ppi 900.4 bridged
    Front stage: Two PWX 10s per door midbass only....... PRV 6MR500 midrange....... Massive CT 2 german tweeters.
    320 amp Singer alt....... 1 group 34 under the hood 6 group31 agms in the back 560 amp hours total.
    irocwagon's Avatar
    Dec 2009
    cola sc
    117
    1 Post(s)
    Re: 6.5 speaker
    The problem is alcohol ..it's a party bus so sometimes there drunk,so the volume is turned all the way up...
    ---------- Post added at 08:17 PM ---------- Previous post was at 08:16 PM ----------
    Checking into pa speakers now..
    Yep ear bleeding and loud should work
    Side Show's Avatar
    Side Show is offline Bringin The Noise
    Aug 2007
    Australia
    3,337
    457 Post(s)
    Re: 6.5 speaker
    tune and setup amps accordingly once you have the new gear installed, you can set it up so that no matter how drunk they are they shouldn't be able to damage your system.
    seems like they try to crank the bass and kill the speakers, is that right?
    irocwagon's Avatar
    Dec 2009
    cola sc
    117
    1 Post(s)
    Re: 6.5 speaker
    They crank it all...radio has the eq button so you know what that means...no matter what it's getting turned all the way up...I don't like the idea of the radio all the way up and amps all the way down but see no other way...then there's aux so we get all the distorted music as well
    Side Show's Avatar
    Aug 2007
    Australia
    3,337
    457 Post(s)
    Re: 6.5 speaker
    just protect your gear, if they wanna crank **** up so it sounds crap and distorted they can go for it lol..... might be worth doing a little upgrade tho. we have done a few party buses and they are a real pain.
  7. Thanks irocwagon thanked for this post
  8. #7
    irocwagon's Avatar
    Dec 2009
    cola sc
    117
    1 Post(s)
    Re: 6.5 speaker
    I have another to do from scratch,different budget,gonna be loud speakers/pa and bullet tweets,first build wasn't mines,just fixing problems,but need a fix for the first..do you think it'll still clip with volume all the way up and amps down low,not the cleanest highs amp
  9. #8
    irocwagon's Avatar
    Dec 2009
    cola sc
    117
    1 Post(s)
    Re: 6.5 speaker
    Ok thanks for the help
  1. Rear fill to Front speaker ratio.....(long)
    By Pl8er in forum General Discussion
    Last Post: 02-22-2008, 02:59 PM
  2. cold VS speakers
    By McCraperson in forum General Discussion
    Last Post: 01-04-2007, 03:59 PM
  3. component speakers
    By <jaylee> in forum General Discussion
    Last Post: 10-29-2004, 09:46 AM
  4. Running new speaker wire
    By <Muff DVR> in forum General Discussion
    Last Post: 12-22-2001, 06:30 AM
  5. Replies: 1
    Last Post: 12-11-2001, 09:57 PM
