Results 1 to 2 of 2
Reload Thread: 6.5" Enclosure Build Help
    bradl79's Avatar
    bradl79 is offline CarAudio.com Elite
    Jan 2013
    NLR
    1,407
    1 Post(s)
    447 Post(s)
    i was looking at a sealed box for my 6.5 Exodus Anarchy
    Re: 6.4 Ohm
    Le: 0.84mH
    Fs: 45.8Hz
    Qms: 6.37
    Qes: 0.48
    Qts: 0.44
    Mmd: 29.4
    Mms: 30.25
    Cms: 0.4mm/N
    Vas: 9.61L
    Sd: 131 cm^2
    BL 10.79 N/A
    SPL: 84.7 dB/1W/1m
    Pmax: 125W
    Xmax: 12 mm 30% Down Point on simulated BL curve
    VC former: 34.95mm Kapton
    VC: Wire: round CCAW OD0.25mm with EISV, 4 layers, winding width 11.0mm
    Gap Height: XBL^2 16mm tall with 5mm gap to form 2-plates: See Drawing
    Power Handling: 125W Approx: No AES or IEC power testing conducted
    can i get some measurements and for what would be good for this, i need to make a box for 2 or should should i do them seperate boxes, thank you.
    Head Unit - Clarion NX702 w/Backup Cam
    DSP - JBL MS-8
    Amp 1 - MB Quart 800.4 (Sub, Mid Bass)
    Amp 2 - MB Quart 600.4 (Tweeters/Mid Range, Center)
    Amp 3 - MB Quart 400.2 (Rears)
    Fronts Stage (3-Way) - CDT HD-6 (Mid Bass) CDT ES-03 (Mid Range) CDT DRT 26s (Tweeters)
    Center Stage - CDT HD-100 (Hi) CDT ES-03 (Lo)
    Rear Stage - CDT HD 6EX
    Sub - Sealed in Custom Box - 12" Sundown E12V2
    Deadened/MLV - All Doors and Trunk (Reckhorn 80mil)
    bradl79's Avatar
    Jan 2013
    NLR
    1,407
    1 Post(s)
    447 Post(s)
    Re: 6.5" Enclosure Build Help
    DSP - JBL MS-8
  1. Enclosure Build Help!
    By Febrewary in forum Enclosure Design & Construction Help
    Last Post: 08-18-2010, 08:09 PM
  2. Anyone have experience with enclosure build for elemental design 13Av.2--NEED HELP
    By wet_rat in forum Enclosure Design & Construction Help
    Last Post: 06-10-2010, 02:14 AM
  3. Treo SSi 12" I want to build slot vented enclosure need help!
    By cbrrocketrdr in forum Enclosure Design & Construction Help
    Last Post: 06-30-2007, 03:52 PM
  4. Building Enclosure Need Help
    By keaton810 in forum Wiring, Electrical and Installation Help
    Last Post: 08-10-2006, 11:29 AM
