Page 2 of 2 FirstFirst 1 2
Results 16 to 28 of 28
Reload Thread: Looking for budget 6.5" comp set in the $200 price range.
  1. #16
    mylows10's Avatar
    mylows10 is offline B2,singer,ampere rep
    Sep 2009
    monterey , ca
    54
    22,442
    142 Post(s)
    1 Thread(s)
    6016 Post(s)
    Re: Looking for budget 6.5" comp set in the $200 price range.
    If you like the cdt or even phd set I have all the pricing. I can't sell you the phd set but I can get you in contact with a rep in your area
    pioneer avhx 4800 dvd, ampere tfhe 9.0 and 150.4 with arc audio xxd 4080
    4 d3100 and 3 deka 8a31 and d975 ,270 dc power and 320 amp singer alt
    B2 ref mids,Cdt es6 mids cdt es 010 tweets x2 ,es 03 Mids x 2 mx1000 , sky high ,eb flex, and stinger hpm o gauge wires ,also 2 crossfire xsv2 18s in a 4th order no wall box
    NOR CAL DB DRAG JUDGE
    http://www.dcsoundlab.com
  2. #17
    trumpet's Avatar
    trumpet is offline CarAudio.com Veteran
    Jan 2011
    Grafton, ND
    37
    6,792
    43 Post(s)
    1859 Post(s)
    Quote Originally Posted by Bass Face84 View Post
    Can you do mix match sets? Like the HD 6'5" mids with the tw-25 tweets so it would cost less than the actual hd set?
    Yes, I can do that. I have a loose pair of TW-25 tweeters in stock.
    Rubyserv - I believe I can delivery joy every time you drive by the power of an incredible sound system. Barry Schanz, Owner
    Authorized dealer for CDT Audio - Shop With Us Now.
    FB | Rubyservsales
    IG | Rubyserv
  3. #18
    Bass Face84's Avatar
    Bass Face84 is offline Member
    Sep 2013
    Sulpher Springs, Texas
    63
    26 Post(s)
    Any options I should consider besides the PHD 6.1 PRO KIT for around $300 ( I believe they cost more than 300 but I'm a little flexible) If you didn't read the original post update I just ordered a 200x2 rms Boston acoustics amp so I can pretty much go with anything.
    Other brands I am looking at and would like opinions on are
    CDT
    HAT
    MOREL
    IMAGE DYNAMICS
    anything you guys can come up with?
  4. #19
    Timmy13091's Avatar
    Timmy13091 is offline Team DC
    Apr 2012
    Chicago
    3,000
    1 Post(s)
    1286 Post(s)
  5. #20
    Sep 2013
    63
    26 Post(s)
    At this point these are the options I'm looking at. Which set do you guys think would meet what I'm looking for?
    HAT Unity U61-2, $399
    PHD 6.1 PRO KIT, $300 - $400ish?
    Morel Tempo 6, $329
    Image Dynamics - CXS64 V2, $299
    Hertz ESK-165L.5, $280
    ( there is also a ESK - 165.5 set for same price, what's the difference and is this set better than the ESK high energy set? )
    Now the Hertz set is 120 cheaper than the Hat's but if there is not a huge difference I would obviously prefer to spend less if possible. However I am willing to spend a little more if it's worth it.
  6. #21
    trumpet's Avatar
    Jan 2011
    Grafton, ND
    37
    6,792
    43 Post(s)
    1859 Post(s)
    Hertz isn't supposed to be sold online at all, so I'd be wary of those options unless you're buying locally. Honestly, none of these options are bad. Based on your amplifier thread we listen to some of the same bands, and for me I need a metal dome tweeter to make the midrange and treble pop out like live music. I'm not certain, but I believe all of those sets have silk dome tweeters. I still think for a lower cost good set JBL MS-62C should be in consideration. It's $299, but it's been selling for much less online.
    You're going to have to be conservative with your high pass filter with a 200x2 amp. Instead of pounding the **** out of them at 50-60 Hz I recommend 80 Hz, 24 dB/octave, or a higher frequency if you have to use a lower slope. Sound deadening is going to be a must to make any of these speakers sound great in your doors. I applied vibration damper, closed cell foam and mass loaded vinyl on the inner side of the door and bagged pink fiberglass insulation is placed inside the door cavity for absorption. Some doors really require a lot of attention, others, not as much.
    FB | Rubyservsales
    IG | Rubyserv
  7. #22
    tat2bass's Avatar
    tat2bass is offline CarAudio.com Elite
    Aug 2011
    Cali
    1,680
    614 Post(s)
    I could sell you a set of BNIB Alpine SPX17PRO's for $350 shipped. I listen to a lot of metal and rock also and loved how it all sounded on these when I auditioned them at a local shop.
  8. #23
    Sep 2013
    63
    26 Post(s)
    Quote Originally Posted by trumpet View Post
    I am going to dampen the doors very well and seal up as many of the holes as I can. I will be careful with the gains and I do plan on HP at 80hz. My Hu is a Pioneer 80prs so I have good active xo's on it so will run the amp full range. I believe the xo on my HU is 12db slope. As far as the JBL'S go I have read good reviews on them but some people say they can't handle the power of the lower model the p600. Is that true? The MS is only rated at 90 rms.
    You may be right about tweets. The best sounding speakers I have ever heard in my life by far were the Focal Polykevlar's. My buddy used to have them in his Silverado. They were freaking amazing but VERY EXPENSIVE. I think he paid like $750 for the set or something.
    BTW, I may actually HP my set a little lower like at 60 or so until I get my subs. When I get my subs I will run the LP 80 then my comps HP 80. I'll baby all my gear though. I plan on investing a good amount of money in the equipment and install. I want my system to last me for years to come.
  9. #24
    trumpet's Avatar
    Jan 2011
    Grafton, ND
    37
    6,792
    43 Post(s)
    1859 Post(s)
    This can make for an audible improvement, but in my experience the outcome was dwarfed by putting up a sound barrier(the mass loaded vinyl with closed cell foam as a gasket) and also by adding the fiberglass for absorption. I recommend you very strongly consider doing all of these steps.
    Welcome to Sound Deadener Showdown | Sound Deadener Showdown
    With a 12 dB slope you may need a higher crossover frequency. There's still a lot of output below 80 Hz with a 12 dB slope.
    While I have not used either of these sets, they're rated only 10W RMS apart. MS-62C is 80W RMS, while P660C is 90W RMS. A few people have had one of the tinsel leads break on their MS-62C sets. I don't know under what conditions this failure occurred, but it's possibly it's from abuse by testing the limits on the low end. With a safe crossover setting you can maximize the output and lifespan of the speaker and increase power handling while minimizing excursion. Another good side effect of minimizing excursion is reduced distortion.
    FB | Rubyservsales
    IG | Rubyserv
  10. #25
    Sep 2013
    63
    26 Post(s)
    Can you explain how to do the foam gasket? Is that basically like a box for the midwoofer using foam or something? I don't really get it but I want to do everything in my power to get the absolute most out of my speakers. I want really great sq and loudness.
  11. #26
    SubbyBeat's Avatar
    SubbyBeat is offline Member
    Jan 2013
    134
    37 Post(s)
  12. #27
    Sep 2013
    63
    26 Post(s)
    I found the JBL MS-62 set for $218.95 shipped. I think I am just gonna go ahead and order them. The JBL's paired with the Boston Acoustics GT-2200 I ordered today will only run me a total of $408.95 leaving me with plenty of money to get some sound dampener, amp wire kit, and the foam stuff. I need to learn how to do the foam stuff and how to properly seal up the holes in the door. Do I use like Butyl rubber stuff to seal up the holes then use dynamat over it or what?
  13. #28
    trumpet's Avatar
    Jan 2011
    Grafton, ND
    37
    6,792
    43 Post(s)
    1859 Post(s)
    Hang or Secure Barrier Layers (MLV/CCF) | Sound Deadener Showdown
    FB | Rubyservsales
    IG | Rubyserv
  14. Thanks Bass Face84 thanked for this post
  1. Looking for a nice 5.25" Comp. set
    By Juicee in forum Speakers
    Last Post: 03-25-2012, 11:04 PM
  2. Any suggestions for a 5 1/4 comp set
    By mountaineer in forum Speakers
    Last Post: 06-23-2006, 02:30 AM
  3. x-over for an active 2-way comp set
    By flakko in forum Wanting to Buy (WTB) - Car Audio
    Last Post: 01-07-2006, 10:53 PM
  4. Looking for budget subs?
    By Scarenius in forum Subwoofers
    Last Post: 10-17-2004, 09:44 PM
