Page 2 of 2 FirstFirst 1 2
Results 16 to 26 of 26
Reload Thread: Crossovers for pro audio?
  1. #16
    mlstrass's Avatar
    mlstrass is offline Shaggy DOA
    Jul 2006
    Illinois
    10,782
    6 Post(s)
    1266 Post(s)
    Re: Crossovers for pro audio?
    Quote Originally Posted by NASTY08IMPALA View Post
    I had them set on bandpas crossed at 100and 3.5k then my tweets hpf crossed at 3.5k. switched to hpf on mids to see and not much difference to me at all
    Will also depend upon what mids, how much power, and music you listen to. On rap it won't make a diff, on rock it can sound distorted/muddy on the upper end as you will probably get some cone break up....
  2. #17
    NASTY08IMPALA's Avatar
    NASTY08IMPALA is offline CarAudio.com Veteran
    Aug 2012
    LOUISVILLE, KENTUCKY
    6,131
    3 Post(s)
    2554 Post(s)
    Quote Originally Posted by mlstrass View Post
    80% of ****.i listen to is rock thats what it.was setup and.tested with ..i thougjt it would.be a big diff
  3. #18
    Aug 2012
    6,131
    3 Post(s)
    2554 Post(s)
    Aq mids and 100rms per mid
  4. #19
    mlstrass's Avatar
    Jul 2006
    Illinois
    10,782
    6 Post(s)
    1266 Post(s)
    AQ's will definitely play up to 3500 with no issues at all. The PE 6.5's I have play up to 9Khz, but I still LP them much lower...
  5. #20
    Aug 2012
    6,131
    3 Post(s)
    2554 Post(s)
    Guess thats why theres not.much diffeence
  6. #21
    Side Show's Avatar
    Side Show is offline Bringin The Noise
    Aug 2007
    Australia
    3,337
    457 Post(s)
    i'm going 3-way active front stage + sub..... sooo painful
  7. #22
    naughtyca's Avatar
    naughtyca is offline CarAudio.com Veteran
    Feb 2012
    Tampa FL
    2,105
    803 Post(s)
    The only time people use pro audio is if your bass is very loud and you need for mids and highs to keep up so sq is thrown out the door and if u bandpass its hard to tell the difference
  8. #23
    galacticmonkey's Avatar
    galacticmonkey is offline Wants a button like that.
    Sep 2006
    Tampa, FL
    7,681
    139 Post(s)
    ITT: I learn that 99% of car audio "enthusiasts" dont know the difference between a LPF and a HPF.
  9. #24
    mlstrass's Avatar
    Jul 2006
    Illinois
    10,782
    6 Post(s)
    1266 Post(s)
    Quote Originally Posted by galacticmonkey View Post
    L or an H is the diff LOL
    ---------- Post added at 02:13 AM ---------- Previous post was at 02:12 AM ----------
    Quote Originally Posted by naughtyca View Post
    Wouldn't SQ go out the window with loud bass also? PA can sound find for daily listening and has been used in world championship SQ cars...
  10. #25
    Bass Face84's Avatar
    Bass Face84 is offline Member
    Sep 2013
    Sulpher Springs, Texas
    63
    26 Post(s)
    I got a question about running active. If you have a 4 channel amp but your hu like the pioneer 80prs has active ability what do you do? Do you set the amp to full range then the HU xo works? Also do channels 1,2 count as the front and 3,4 as the rear on the HU? Could you still run coaxils of the rear channels yet have the tweets and mids active off the HU?
    ---------- Post added at 12:57 PM ---------- Previous post was at 12:56 PM ----------
    Also if you want to use amp xo's and not HU xo's how do you turn off hu xo's? Is there an option to? If you did that can you still use the eq, t/a off the Hu with amp xo's?
  11. #26
    mlstrass's Avatar
    Jul 2006
    Illinois
    10,782
    6 Post(s)
    1266 Post(s)
    Quote Originally Posted by Bass Face84 View Post
    Amps set to FULL, use xovers on the HU if in Network mode.
    Using amp xovers leave HU in Standard mode.
    On the PRS80 Front = mids Rear = tweeters when in Network mode
    I would run active using the HU for sure vs using amp xovers as you have WAY more adjustability...
  1. WTT - For Pro Audio Gear
    By fredridge in forum Wanting to Buy (WTB) - Car Audio
    Last Post: 07-03-2009, 01:54 PM
  2. cauer elliptic crossovers for car audio
    By thch in forum General Discussion
    Last Post: 07-16-2005, 06:20 PM
  3. Car Audio Fit For Pro Audio?
    By boister77 in forum Subwoofers
    Last Post: 11-10-2004, 06:11 PM
