Page 1 of 2 1 2 LastLast
Results 1 to 15 of 16
Reload Thread: Upgraded equipment, worse sound
    mjboss's Avatar
    mjboss is offline Junior Member
    Jul 2013
    Cincinnati, OH
    1 Post(s)
    I bought a new 2013 Wrangler Unlimited Sport with the stock/base model sound system this weekend. Today I had a new Pioneer AppRadio 3 and 4 Alpine 6.5 speakers installed.... and it sounds terrible. There is no depth or "warmth" to the sound, no vibrations so to speak, the music sounds like it's coming from an elevator speaker. It could be the EQ but I messed with that for 45 minutes and am still not getting even the sound I had with the stock system. Any ideas?
    mylows10's Avatar
    mylows10 is offline B2,singer,ampere rep
    Sep 2009
    monterey , ca
    54
    22,442
    141 Post(s)
    1 Thread(s)
    6015 Post(s)
    Re: Upgraded equipment, worse sound
    deaden the doors and seal off the speakers from the door panel
    pioneer avhx 4800 dvd, ampere tfhe 9.0 and 150.4 with arc audio xxd 4080
    4 d3100 and 3 deka 8a31 and d975 ,270 dc power and 320 amp singer alt
    B2 ref mids,Cdt es6 mids cdt es 010 tweets x2 ,es 03 Mids x 2 mx1000 , sky high ,eb flex, and stinger hpm o gauge wires ,also 2 crossfire xsv2 18s in a 4th order no wall box
    NOR CAL DB DRAG JUDGE
    http://www.dcsoundlab.com
    gckless's Avatar
    gckless is offline CarAudio.com Veteran
    Aug 2011
    San Antonio
    5,159
    6 Post(s)
    2218 Post(s)
    Are you sure it's not just settings somewhere? Check, and pay attention to your HPF and your EQ settings. Who did the install? If it was a shop you may want to pop off the door panel and check their work, if they are behind a door panel.
    Lowlacs's Avatar
    Lowlacs is offline Senior VIP Member
    Jul 2012
    Live Oak Fl. 32060
    263
    95 Post(s)
    Probably a polarity problem. Try fading to one speaker alone and see if it comes to life.
    97 Ram
    2 sets Kicker ks650.2 on a
    Mmats 2050x
    2 American Bass XFL12s(4th order) on
    American Bass VFL110.1
    Kinetic hc1800
    Traded to: WinkyChevelle, Sold to: Outer,Markbuhler007,67bass71, Bought from: Mylows10
    Jes 42's Avatar
    Jes 42 is offline DeezNtzz
    Aug 2012
    Ohio
    2,383
    4 Post(s)
    709 Post(s)
    Yeah may be out of phase somewhere.Check your negative and positive connections.Put fader to the front and use the balance to see if one speaker sounds diff than the other.Should be able to tell that way.
    Pioneer 880PRS
    4 PRV 6.5's 4 Bazooka Euphonic os tweets
    Kicker KX850.4
    2 Incriminator Death Penalty 18's
    American Bass VFL450.1
    300 amp Ohio Gen alt
    4 Deka Intimidator's in back.C&D 77ah up front.
    Lotta 1/0 welding wire
    keep_hope_alive's Avatar
    keep_hope_alive is offline Acoustics Engineer keep_hope_alive is a Supporting Member of the forum!
    May 2007
    Quad Cities, IL
    7,082
    28
    48 Post(s)
    1502 Post(s)
    I agree that phase as well as a lack of seals will cause this problem.
    replacing speakers is more involved than simple drop-in. the factory speakers have perfect seals against the door panel. note the door panel is the front of the speaker enclosure and should be treated as a speaker baffle.
    many Chrysler vehicles have factory amplifiers which need to be properly fed. did you intend to bypass any factory amplification?
    got a question? shoot me a PM. Matthew 6:9-15 - YouTube Channel: https://www.youtube.com/channel/UCkYUo2EShW9lgtrfXiDvLNQ/videos
    2014 Accord build log: http://www.caraudio.com/forums/car-audio-build-logs-cars-trucks-suvs/608637-2014-accord-sport-sq-build-keep_hope_alive.html
    2001 Accord build log: http://www.caraudio.com/forums/car-audio-build-logs-cars-trucks-suvs/536049-2001-accord-ex-sedan-its-long.html
    My 1966 MGB: http://www.mgexp.com/journal/keephopealive
    Fix Photobucket Image Loading ------> https://addons.mozilla.org/en-US/firefox/addon/photobucket-fix/ <------
    mjboss's Avatar
    Jul 2013
    Cincinnati, OH
    1 Post(s)
    Thanks for the help... couple things so far
    a) The speakers are not in the door panel, they are in the roll bar and dash, and the shop used Dynamax to dampen
    b) No factory amp bypassed.
    c) I also posted this on the Wrangler forum for audio equipment and everyone there said I needed to add an amp because the speakers weren't getting enough power. This being an audio specific site I'm assuming the folks here know more. Would anyone suggest adding an amp to solve the problem? The HU is 14 RMS / 80 Peak, the speakers are 80 RMS / 240 Peak.
    I will give the fade thing a try for polarity, but I can't go in and check connections on my own, I am not that knowledgable, and the front speakers require the dash be removed and I am not up for getting into all that. If the fading issue seem to be the problem, I am assuming I can bring this back to Best Buy and present the findings? Any suggestions there?
    LosIsATool's Avatar
    LosIsATool is online now CarAudio.com Veteran
    Apr 2011
    Pensacola, Florida
    37
    17,858
    109 Post(s)
    7617 Post(s)
    1st issue I see is Best Buy. Amping them will help a lot. Check the settings, check the phase.
    2014 Ford Fusion SE 2.0T
    JBL MS-8
    DD M1c, DD SS4A
    IDQ12v4 1.8cu sealed
    Hertz HT28
    Hertz HV165XL
    Knuconceptz OFC, Custom fit Soundrive RCAs.
  9. Likes Josef344, southernboom88 liked this post
  10. #9
    johnthompson's Avatar
    johnthompson is offline Junior Member
    Jan 2011
    Canton, Ohio
    27
    1 Post(s)
    I'm gonna bet that an amp would solve your problem. most alpine speakers sound best when amped
  11. #10
    mjboss's Avatar
    Jul 2013
    Cincinnati, OH
    1 Post(s)
    Quote Originally Posted by DDtC View Post
    Yeah I am not arguing the Best Buy issue but you live in Va. Beach (I used to live there) and I live in Cincinnati... finding someone quality in this city for this kind of work is daunting at best. It's just not like some of the other cities out there, midwestern mid-sized city people just don't upgrade like coast cities and stuff do, it's a real pain. I would do it myself but I don't trust it, I'm more of an outdoor guy not an audio guy so I really just never learned. Thanks for the tips.
  12. #11
    LosIsATool's Avatar
    Apr 2011
    Pensacola, Florida
    37
    17,858
    109 Post(s)
    7617 Post(s)
    Quote Originally Posted by mjboss View Post
    There is only one shop around here I would let touch my car and its only one of those techs. I'll be watching every minute of his work.
    JBL MS-8
    DD M1c, DD SS4A
    Hertz HT28
    Hertz HV165XL
  13. #12
    mjboss's Avatar
    Jul 2013
    Cincinnati, OH
    1 Post(s)
    What size amp would you suggest? Alpine Speakers with 80 RMS / 240 RMS
  14. #13
    LosIsATool's Avatar
    Apr 2011
    Pensacola, Florida
    37
    17,858
    109 Post(s)
    7617 Post(s)
    This would make a night and day difference. Its cheap and coming from a good dealer, it wont tax the Jeep either
    Alpine MRP-F300 V-Power Series 4-channel car amplifier &mdash; 50 watts RMS x 4 at Crutchfield.com
    JBL MS-8
    DD M1c, DD SS4A
    Hertz HT28
    Hertz HV165XL
  15. #14
    Josef344's Avatar
    Josef344 is offline Member
    Apr 2013
    Jacksonville
    92
    28 Post(s)
    A class A/B are the best when it comes to sound quality.
    There's also this: Alpine MRP-F550 4/3/2-Channel Amplifier - Alpine - Car Toys
    It should match up with your Alpine 6.5s perfectly.
    There's a lot of amps that have that.
    Also if possible, it's best if you, yourself, will do the install.
    It's better to learn what you've did wrong that to pay somebody to do the install that mess up what they do.
  16. #15
    mjboss's Avatar
    Jul 2013
    Cincinnati, OH
    1 Post(s)
    Just ordered the amp, could this also power a 10" sub? or no
  1. Need help upgrading equipment
    By jokersace69 in forum Subwoofers
    Last Post: 04-01-2013, 08:17 AM
  2. Need advise concerning upgrading my existing sound system
    By alfadigital in forum General Discussion
    Last Post: 06-20-2012, 07:43 PM
  3. Replies: 8
    Last Post: 02-06-2011, 10:58 PM
  4. Replies: 3
    Last Post: 07-28-2008, 10:23 PM
  5. rewired inside speakers=worse sound?
    By chronicblazen in forum Wiring, Electrical and Installation Help
    Last Post: 03-20-2004, 01:53 AM
