Page 2 of 2 FirstFirst 1 2
Results 16 to 26 of 26
Reload Thread: Does adding a 2nd speaker side by side add much volume?
  1. #16
    T3mpest's Avatar
    T3mpest is offline CarAudio.com Veteran
    Mar 2005
    Illinois
    3,054
    1 Post(s)
    372 Post(s)
    Re: Does adding a 2nd speaker side by side add much volume?
    Quote Originally Posted by DDtC View Post
    Double cone area or double power on paper is a 3 db gain. It has show cone area gets closer to that mark. With that said if you double cone and not power it would equal out, you still could have a slight gain do to the cone but it might not be noticable. Double power and cone and it will have a big increase
    Basic acoustic theory says both your posts on this matter are wrong.
    Doubling cone area and cutting power in half to each speaker (same power overall) still gains you 3db. Watts and excursion don't correlate at a 1:1 ratio, halving wattage to each speaker doesnt' drop excursion by half, so when you double cone are you gain displacement/output. You also sometimes gain thermal advantages, which can gain you more.
    Doubling cone area AND power gains you 6db which is a doubling of total displacementl and acoustic power. 10db of loudness is generally considered where the sound "sounds" twice as loud. With bass it's slightly lower due to the hearing. This corresponds to about 10x the power keeping cone area equal. If you quadruple power and cone are doubles, that also gets you close to this mark. IE 1 speaker on 100 watts becomes 2 sepakers on 200 watts each. For bass this doesn't work as well due to the box size needed often messes up your cabin gain, which is the biggest overall contributor to bass in a car, which is why alot of car audio guys dismiss these rules. For mids and highs though they work fairly well. So for OP, if your amp can't drop impedence and you end up using 1/2 the power on 2x the cone area, your still going to get the 25% sound increase your looking for, imagine if your volume knob had 2 or 3 turns of clean volume left..
    Quote Originally Posted by sdmtnbiker420 View Post
    JL is for ballers. Theres a reason all the biggest rappers sing about JL, Zapco, Alpine..... and not Lightning audio or Pyle. It's all about the BALLER FACTOR.
  2. #17
    LosIsATool's Avatar
    LosIsATool is online now CarAudio.com Veteran
    Apr 2011
    Pensacola, Florida
    37
    17,843
    109 Post(s)
    7612 Post(s)
    Quote Originally Posted by T3mpest View Post
    Doubling cone area and cutting power in half to each speaker (same power overall) still gains you 3db. Input voltage and excursion don't correlate at a 1:1 ratio, halving voltage to each speaker doesnt' drop excursion by half, so when you double cone are you gain displacement/output. You also sometimes gain thermal advantages, which can gain you more.
    Sorry you feel that way but I am not wrong.
    2014 Ford Fusion SE 2.0T
    JBL MS-8
    DD M1c, DD SS4A
    IDQ12v4 1.8cu sealed
    Hertz HT28
    Hertz HV165XL
    Knuconceptz OFC, Custom fit Soundrive RCAs.
  3. #18
    T3mpest's Avatar
    Mar 2005
    Illinois
    3,054
    1 Post(s)
    372 Post(s)
    LMAO care to google search to back youself up.. Nah, 100+ years of acoustic theory is useless next to the YOU! Maybe if you learned a bit about how speakers really work you wouldn't be stuck nuthugging brands so much.
  4. #19
    dumple's Avatar
    dumple is offline What's in your trunk?
    Sep 2006
    Philly
    29
    8,595
    139 Post(s)
    We skipped the moat important question are the doors sealed and deadend
    Pioneer Avic 8100nex
    Audible Physics H6mb, AR3-A, AR20
    JBL W10GTI MKII
    Minidsp c6to8
    Kenwood XR400-4
    Kenwood XR900.5
  5. #20
    LosIsATool's Avatar
    Apr 2011
    Pensacola, Florida
    37
    17,843
    109 Post(s)
    7612 Post(s)
    I said doubling cone area OR power is a 3 db increase. If he cuts his power in half and doubles cone area it's the same thing. If everything is within parameters.
    JBL MS-8
    DD M1c, DD SS4A
    Hertz HT28
    Hertz HV165XL
  6. #21
    T3mpest's Avatar
    Mar 2005
    Illinois
    3,054
    1 Post(s)
    372 Post(s)
    aha nvm then my apologies, i misunderstood your point. I was thinking you meant splitting the total power in half, not literally only having half..
  7. #22
    LosIsATool's Avatar
    Apr 2011
    Pensacola, Florida
    37
    17,843
    109 Post(s)
    7612 Post(s)
    It's all good.
    JBL MS-8
    DD M1c, DD SS4A
    Hertz HT28
    Hertz HV165XL
  8. #23
    Roland's Avatar
    Roland is offline Senior VIP Member
    Dec 2012
    Atlanta
    491
    10 Post(s)
    232 Post(s)
    Quote Originally Posted by dumple View Post
    Yeah about 1 yard in each door.
    Went buy a couple of shops today to see about cost of building the door panels for Two 6.5s. it would be tricky because the lay out. So they were talking pretty big bucks.
    Went to check on the Hertz 165 XL at a dealer, one of the guys show me 3 boxes of failed Hertz speakers! Yeks. Only a few of them where high energy's but still. needless to say he was not to jazzed about them.
    Against some good advice i went ahead and ordered the RF T5652-s. The price was even lower than before, and the warranty is solid, so im going out on a limb. I haven't seen where anyone (non invested in RF) has actually tried the T5652-s, so maybe that particular model will be as good was some of the sponsored guys say they are.
    T3mpest thanks for the info.
  9. Likes dumple liked this post
  10. #24
    dumple's Avatar
    Sep 2006
    Philly
    29
    8,595
    139 Post(s)
    What headunit are you running active with
    JBL W10GTI MKII
    Minidsp c6to8
    Kenwood XR400-4
    Kenwood XR900.5
  11. #25
    Roland's Avatar
    Dec 2012
    Atlanta
    491
    10 Post(s)
    232 Post(s)
    DEH 80PRS.
    Im going to get some one to tune it next week (i'm sure someone who really knows what there doing will get the sound to its max potential.
  12. #26
    Roland's Avatar
    Dec 2012
    Atlanta
    491
    10 Post(s)
    232 Post(s)
    The Rockford Fosgate T5652-S work out GREAT!!!!
    Put them in, and tuned them up, and not only gave me the extra good clean Volume i wanted, but they Totally Rocked My World! Absolutely Amazing!
    No need for second speakers
  1. Replies: 1
    Last Post: 03-11-2007, 05:32 PM
  2. What to do: How to attach MDF side by side?
    By Supergumby5000 in forum Enclosure Design & Construction Help
    Last Post: 01-08-2007, 11:05 AM
  3. Side By Side
    By bigbassboi in forum Subwoofers
    Last Post: 03-30-2006, 11:59 PM
  4. Running Power, RCA and Speakers Side by Side
    By 02envoy in forum Wiring, Electrical and Installation Help
    Last Post: 07-28-2005, 11:28 AM
  5. does anyone have pix of the se and *** side by side?
    By caraudionoob in forum Subwoofers
    Last Post: 08-13-2004, 08:52 AM
