Results 1 to 8 of 8
Reload Thread: 2-ohm 200 watts rms 6.5 component set
    FireGS's Avatar
    FireGS is offline Junior Member
    Jun 2013
    Houston
    20
    3 Post(s)
    Anyone got any suggestions?
    I looking at the JBL p660c and the re audio xxx any others that can take that power at 2ohms.
    Looking for some SQL type speakers.
    Not too picky on sound but I want them to play loud enough that it can be heard clearly when my top is off the car.
    keep_hope_alive's Avatar
    keep_hope_alive is offline Acoustics Engineer keep_hope_alive is a Supporting Member of the forum!
    May 2007
    Quad Cities, IL
    7,080
    28
    47 Post(s)
    1502 Post(s)
    Re: 2-ohm 200 watts rms 6.5 component set
    aiming will have more to do with how loud they are than impedance. off-axis aiming can lower response by 6-10dB for upper mids and highs. going to 2 ohm only gains you 3dB (which is barely discernible). it takes 10dB to seem as half or twice as loud. further, a 4 ohm speaker with a 92dB sensitivity will be louder than a 2 ohm speaker with 88dB sensitivity.
    instead of focusing on impedance only, look at sensitivity and adjust speaker aiming (as much as possible) to get them more on-axis. lastly, ensure the speakers are installed with the best seals possible to minimize cancellation.
    Image Dynamics had some nice 2 ohm comps i've ran with success - huge magnets though. what do you have for depth?
    got a question? shoot me a PM. Matthew 6:9-15 - YouTube Channel: https://www.youtube.com/channel/UCkYUo2EShW9lgtrfXiDvLNQ/videos
    2014 Accord build log: http://www.caraudio.com/forums/car-audio-build-logs-cars-trucks-suvs/608637-2014-accord-sport-sq-build-keep_hope_alive.html
    2001 Accord build log: http://www.caraudio.com/forums/car-audio-build-logs-cars-trucks-suvs/536049-2001-accord-ex-sedan-its-long.html
    My 1966 MGB: http://www.mgexp.com/journal/keephopealive
    Fix Photobucket Image Loading ------> https://addons.mozilla.org/en-US/firefox/addon/photobucket-fix/ <------
    zako's Avatar
    zako is offline CarAudio.com Elite
    Jan 2011
    TX
    1,347
    238 Post(s)
    Take a look at Massive Audio CK6 and RK6. Both are loud. The CK6 woofer is supposedly tighter sounding, while RK6 has more SPL potential. The later has big mounting depth. They 4-ohm I think. You amp should have no problems delivering power to them I think.
    3-ways may work out best for SQL, specially if you get them with 6x9 or 8 inch woofers.
    FireGS's Avatar
    Jun 2013
    Houston
    20
    3 Post(s)
    I have a 2010 vette and from what I have read its got about 3.5 to play with depth wise. can't really aim mids since there is no room for kicks. tweets I might have to do the a pillars so I can aim them
    I'm only using a single 10 so itdoesnt have to keep up with 15's but it will have to play over open headers that's why im not too concerned with sq
    trumpet's Avatar
    trumpet is offline CarAudio.com Veteran
    Jan 2011
    Grafton, ND
    36
    6,792
    43 Post(s)
    1859 Post(s)
    This is going to make this a lot harder. Your engine and exhaust noise is going to drown out some of the music and it will vary depending on your speed and what gear you're in. Can you maintain a conversation with a passenger without shouting? I've done a system in a loud car but it wasn't "open headers" loud. When that car accelerated you can forget about the music because you're not going to pay attention to it one bit.
    Rubyserv - I believe I can delivery joy every time you drive by the power of an incredible sound system. Barry Schanz, Owner
    Authorized dealer for CDT Audio - Shop With Us Now.
    FB | Rubyservsales
    IG | Rubyserv
    FireGS's Avatar
    Jun 2013
    Houston
    20
    3 Post(s)
    you can still talk and have a convo with windows up at cruising speeds. top off is a different story.
    I guess either of these sets listed would do just fine right?
    HCCA's Avatar
    HCCA is offline Slayer of Libs
    Oct 2006
    Lincoln, IL
    376
    1 Post(s)
    The JBL P660C has a sensitivity rated at 94 db ([email protected]). My Boston Pro's are rated at 91 db ([email protected]). So, all else being equal, the JBL's will be the same volume, with half the power. I bought a set, recently. I plan to give them a test listen in the next month, or so.
    Generally, higher impedance speakers are more efficient....but, that's NOT a hard and fast rule!
    The Top 50% of income earners pay 96.54% of All Income Taxes. The Top 1% Pay More Than a Third:34.27%...so, the next time you hear about "tax cuts for the rich", remember...those are practically the only people paying taxes.
    trumpet's Avatar
    Jan 2011
    Grafton, ND
    36
    6,792
    43 Post(s)
    1859 Post(s)
    Your car has 10" woofers up front with 3.5" speakers covering the midrange on up. It would be absolutely pointless to drop down to a 6.5" woofer when you have those monsters from the factory. I didn't think of this earlier.
    FB | Rubyservsales
    IG | Rubyserv
  1. help me! need asap!!! 200 watts RMS x 2 @ 4 ohms for cheap!!
    By mrkNOw1 in forum Wanting to Buy (WTB) - Car Audio
    Last Post: 12-06-2010, 05:25 AM
  2. 2 12" 200 watts rms 4 ohm suggestions
    By The Van Man in forum Subwoofers
    Last Post: 10-03-2007, 06:42 PM
  3. Best 10" sub for 150-200 watts RMS??
    By Getwild2 in forum Subwoofers
    Last Post: 11-02-2004, 07:14 PM
  4. 150x2 watts rms @4ohms...for components
    By ngsm13 in forum Amplifiers
    Last Post: 03-29-2004, 02:06 PM
  5. Replies: 2
    Last Post: 02-03-2003, 11:47 AM
