Page 3 of 3 FirstFirst 1 2 3
Results 31 to 38 of 38
Reload Thread: How do I get bass out of my door speakers?
  1. #31
    keep_hope_alive's Avatar
    keep_hope_alive is offline Acoustics Engineer keep_hope_alive is a Supporting Member of the forum!
    May 2007
    Quad Cities, IL
    7,080
    28
    47 Post(s)
    1502 Post(s)
    Re: How do I get bass out of my door speakers?
    top hole
    now that the holes are closed up, remove the foam on the door panel
    got a question? shoot me a PM. Matthew 6:9-15 - YouTube Channel: https://www.youtube.com/channel/UCkYUo2EShW9lgtrfXiDvLNQ/videos
    2014 Accord build log: http://www.caraudio.com/forums/car-audio-build-logs-cars-trucks-suvs/608637-2014-accord-sport-sq-build-keep_hope_alive.html
    2001 Accord build log: http://www.caraudio.com/forums/car-audio-build-logs-cars-trucks-suvs/536049-2001-accord-ex-sedan-its-long.html
    My 1966 MGB: http://www.mgexp.com/journal/keephopealive
    Fix Photobucket Image Loading ------> https://addons.mozilla.org/en-US/firefox/addon/photobucket-fix/ <------
  2. #32
    May 2007
    Quad Cities, IL
    7,080
    28
    47 Post(s)
    1502 Post(s)
    to prevent noises with the panel on the deadener, we covered the door with CCF and also foamed each panel clip
    repeat on the passenger side
    finished
  3. #33
    calebkhill's Avatar
    calebkhill is offline CarAudio.com Elite
    Dec 2012
    Phenix City, Alabama
    1,103
    326 Post(s)
    @keep_hope_alive ;
    Why on earth would you do 100% coverage off cld. Such a waste.....
    Sarcasm......
    "When I listen to a stereo loudspeaker playback in my room and an auditory scene has formed in my mind, how would I know that what I hear is an accurate replica of an auditory scene that could be had at the recording venue? Or more generally, that this is an auditory scene that could have existed at all?"
  4. Likes keep_hope_alive liked this post
  5. #34
    May 2007
    Quad Cities, IL
    7,080
    28
    47 Post(s)
    1502 Post(s)
    all three cars have awesome midbass response. you can see/feel your pants move.
    all have front components that cost $500-$900. But $100 speakers would sound great in these doors.
    all have external amplifiers on the speakers for plenty of clean power.
    All have a combination of deadening, fiberglass bags, foam weatherstripping, and are fully sealed.
    Deadening:
    The van has 8 sq. ft. per door.
    The accord and scion have closer to 20 sq. ft. per door.
    The front doors are responsible for most of what you hear, and should receive more attention than anything else in the system. To duplicate this, you should budget 10 hours per door, start to finish. Can be done in half that time if you already know what you are doing.
    some people say 25% deadener coverage is all you need and more than that is wasting it. i know a few acoustical engineers that would disagree with their marketing attempts. "buy my product and use less". Fact is, patches create multiple resonance modes. The industry tests damping and resonance by knocking on the panels. knock until the entire panel is dead and you have achieved your goal. ideally, you would add enough mass and damping to lower the resonance frequency to be below the speaker range. simply adding layers of wood to the inner door would come very close to achieving that goal. 2" of wood is pretty dead. also, besides making the car very, very dead. 100% coverage also greatly improves transmission loss (blocks noise).
    CCF is just to isolate the door panel from the door metal. could just be done where the panel contacts the door. instead of CCF, you could use fabrics like felt or fleece. buzzing isolation is just soft stuff between hard things. pretty simple.
    closed cell foam doesn't absorb or block much sound (highs get blocked). open cell foam barely absorbs sound and doesn't block sound either. the next step is Mass Loaded Vinyl (MLV) for road noise blocking. but door seals themselves and the glass are larger sources once you do the above.
  6. Likes calebkhill liked this post
  7. #35
    calebkhill's Avatar
    Dec 2012
    1,103
    326 Post(s)
    Quote Originally Posted by keep_hope_alive View Post
    Deadening:
    Thanks for a very thorough response kha
  8. #36
    Jeffdachef's Avatar
    Jeffdachef is online now Gunz That Turn on Nunz
    Feb 2013
    South Coast Metro, CA
    15,330
    220 Post(s)
    7369 Post(s)
    sorry to resurrect an old thread but this is a very awesome thread with great info.
    Got some spare time tomorrow so I'm gonna take off the door panels tomorrow to work on rear wave absorption with fiberglass insulation tomorrow and i got a question,
    @keep_hope_alive ; where do you get your 1 millimeter plastic sheet for cheap? all the packages they have at home depot are around 35-60 dollars each... and have a long delivery time Can 2 or 4 or 6 millimeter work? Or is it going to cause plastic noise or even reflecting waves? Also what do you use to seal the plastic sheets into bags? would this be fine? http://www.walmart.com/ip/iTouchless...-Pack/10247581
    EDIT: How about two layers of the plastic food wrap? Would that work? i have a ton of those at home.
    09 Sienna Subs : Four Team Ascendant 18s......Sub amp: Two Taramps 15k
    Headunit: Pioneer 80PRS................................Mids/Highs amp: CT 500.2, ppi 600.2, ppi 900.4 bridged
    Front stage: Two PWX 10s per door midbass only....... PRV 6MR500 midrange....... Massive CT 2 german tweeters.
    320 amp Singer alt....... 1 group 34 under the hood 6 group31 agms in the back 560 amp hours total.
  9. #37
    May 2007
    Quad Cities, IL
    7,080
    28
    47 Post(s)
    1502 Post(s)
    my local hardware stores have painters drop cloth in 1mil thickness for $3.
    and yes, grocery bags would also work. thinner is better.
  10. #38
    BockSTK's Avatar
    BockSTK is offline Junior Member
    May 2014
    So Cal.
    ****...I just learned a lot!
  1. Trying to get more bass out of my system at low volume levels
    By igorbmwx5 in forum Wiring, Electrical and Installation Help
    Last Post: 01-10-2013, 05:33 PM
  2. Replies: 2
    Last Post: 05-17-2010, 11:19 PM
  3. I need help getting deep bass out of my 12w6v2's
    By rc10mike in forum Subwoofers
    Last Post: 03-26-2008, 09:48 PM
  4. is my batt voltage low? how do i get more out of it?
    By talon2nr7588 in forum Wiring, Electrical and Installation Help
    Last Post: 05-31-2007, 01:47 PM
  5. Getting must out of my subs.......
    By iceman112 in forum Subwoofers
    Last Post: 10-20-2002, 10:40 AM
