Results 1 to 8 of 8
Reload Thread: 8" DIY component build
    mustang90's Avatar
    mustang90 is offline Junior Member
    Apr 2013
    USA
    1 Post(s)
    Haven't built a great system since the early 90's when Orion HCCA amps and Orion Kevlar cone subs were in!
    I have a unusual type of space that will allow me to use a board big enough to use an 8" driver and any size tweeter. One set for the right, and one left. Each driver and tweeter will have 150 watts RMS. The area behind the board is approximately 2 cubic feet and is not totally sealed.
    Keep in mind that this is a budget minded DIY build. I'm not looking for any crazy amount of bass, just a nice clean, full sound. Anything from Parts Express or Madisound useful? I have a few starter questions for those with experience in building component systems.
    1. Will an 8" driver setup have any advantages over using a good 6.5" driver?
    2. Since the space is not sealed, use an IB type driver?
    3. Any budget driver/tweeter/crossover set that stands out above the rest?
    keep_hope_alive's Avatar
    keep_hope_alive is offline Acoustics Engineer keep_hope_alive is a Supporting Member of the forum!
    May 2007
    Quad Cities, IL
    7,082
    28
    48 Post(s)
    1502 Post(s)
    Re: 8" DIY component build
    yes, Parts Express and Madisound are excellent DIY resources. i've bought from them for over decade.
    1. you are most concerned about the woofer high frequency response. larger woofers will roll off sooner due simply to impedance (inductance of the coils) and the will beam sooner (lower freq). there are some really nice rull range 8" (Fostex, Dayton)
    2. IB doesn't really exist, you just want a woofer with a higher Qts. you also want to be careful of low frequencies and mechanical suspension limits. that said, any speaker will perform in IB.
    3. Dayton does a nice job across the board. As do Peerless, Vifa, and Scanspeak. Crossovers will eventually determine performance and can cost more than budget drivers.
    i've done an 8" 2-way in my garage using the wall cavity as the airspace and building a baffle. essentially like an in-wall speaker system. you are mostly concerned about contolling resonance of the mounting baffle and airspace. stiffening the baffle and getting some fiberglass batt in the airspace will go a long way to improving performance.
    got a question? shoot me a PM. Matthew 6:9-15 - YouTube Channel: https://www.youtube.com/channel/UCkYUo2EShW9lgtrfXiDvLNQ/videos
    2014 Accord build log: http://www.caraudio.com/forums/car-audio-build-logs-cars-trucks-suvs/608637-2014-accord-sport-sq-build-keep_hope_alive.html
    2001 Accord build log: http://www.caraudio.com/forums/car-audio-build-logs-cars-trucks-suvs/536049-2001-accord-ex-sedan-its-long.html
    My 1966 MGB: http://www.mgexp.com/journal/keephopealive
    Fix Photobucket Image Loading ------> https://addons.mozilla.org/en-US/firefox/addon/photobucket-fix/ <------
    mustang90's Avatar
    Apr 2013
    USA
    1 Post(s)
    ^^ Thanks much!
    Yes, the upper frequencies were what I was concerned with versus using a more standard 6.5" driver.
    I've used Vifa 6.5's back in 1990 and they were very good. Also used the older large diameter soft dome tweeters.
    Any budget minded driver & tweeter combos you'd suggest off hand? Any ready made 2 way X-over that's also budget friendly?
    gckless's Avatar
    gckless is offline CarAudio.com Veteran
    Aug 2011
    San Antonio
    5,159
    6 Post(s)
    2218 Post(s)
    Here are a couple good 8's:
    Usher 8945A 7" Carbon Fiber/Paper Woofer 296-600
    The Madisound Speaker Store
    Dayton Audio RS225-4 8" Reference Woofer 4 Ohm 295-376
    Here are a couple tweeters:
    Dayton Audio RS28F-4 1-1/8" Silk Dome Tweeter 275-140
    There are more of course, but these are very solid choices.
    You have any way to run active? If not, search around some car audio sites, ask some dealers, to see if they offer strictly crossovers at the frequency/slope/power you want.
    mustang90's Avatar
    Apr 2013
    USA
    1 Post(s)
    The Usher driver looks like my cup of tea. Looks like it might be able to reach a little lower than the others?
    No way to use an active crossover now. Looks like PE has premade 2 way Xovers.
    May 2007
    Quad Cities, IL
    7,082
    28
    48 Post(s)
    1502 Post(s)
    PE does have pre-made crossovers. just take note of impedance. you may want the single in-line 12dB/oct versions in lieu of a premade 2-way so you can run 4 ohm speakers.
    the biggest challenge is locating these speakers since they don't have the same mounting as car audio products. they don't come with the same mounting rings and adapters. you end up fabricating.
    mustang90's Avatar
    Apr 2013
    USA
    1 Post(s)
    Quote Originally Posted by keep_hope_alive View Post
    A subwoofer will now be incorporated into the mix of this system. A 8" driver is not set in stone now. I'll be making a baffle board of sorts not much larger than what the drivers can fit into. It will in turn cover an empty compartment that will somewhat act as an enclosure. What are the +/-'s of using a 8" driver for mids rather than a 6" driver? Or vice/versa?
    May 2007
    Quad Cities, IL
    7,082
    28
    48 Post(s)
    1502 Post(s)
    depends on the driver. some 8's are better at midrange than some 6's. some 6's are better at midbass than some 8's. you cannot compare speakers by size but by build quality and design.
    all else equal, an 8" will play lower than a comparable 6" but since a 6" starts beaming later than an 8" it is more suitable for off-axis mounting in a door and due to coil inductance an 6" will play higher than a comparable 8".
    but you can buy full range 8" drivers from Fostex or Dayton Audio that could be the only drivers in the system besides subs.
  1. Decisions on DIY components!
    By ngsm13 in forum Speakers
    Last Post: 05-31-2005, 08:13 AM
  2. *PICS* My Active DIY Component Setup
    Last Post: 04-29-2005, 04:43 PM
  3. DIY component speakers need a crossover
    By gundecker in forum Speakers
    Last Post: 01-10-2005, 09:23 AM
  4. DIY Component Questions
    By canadiancav in forum Speakers
    Last Post: 11-10-2004, 03:02 PM
