+ Reply to Thread
Page 1 of 2 1 2 LastLast
Results 1 to 15 of 24
Reload Thread: Exodus Anarchy
    gckless's Avatar
    gckless is offline CarAudio.com Veteran
    Aug 2011
    San Antonio
    3,382
    23 Post(s)
    Exodus Anarchy
    Just got them today. They are beautiful
    Compared to some Polk dB651's I have:
    Quote Originally Posted by ducatipaso View Post
    To say that 8inch, 10inch and even 12inch subs are for girls is just not true. 15inch subs can't play fast beats, they take more power and that taxes the vehicles electrical system. You will wake up and "hear" then see the light at the end of the tunnel and it will be 3 10's pounding so hard you wont even open your trunk or turn your system on because you 15's will sound sloppy & weak.
    Quote Originally Posted by benbenondatrack View Post
    stfu lesbo.why are you worried about me so much? you must want to date me ya little cookie monster but i dont even like sweets. your just a cup full of ice, dirt dead nasty azz ice...without the water.
    ciaonzo's Avatar
    ciaonzo is online now TheContinental
    Feb 2009
    WI
    8,636
    21 Post(s)
    Re: Exodus Anarchy
    Those can't possibly sound good, they're 8ohm.
    You'll never get enough powerz to them.
    Saying "clipping doesn't kill speakers" is a half-truth at best. Technically no, clipping itself does not hurt the speaker. But in clipping your amp, you can easily create a situation that WILL kill the speaker. Was the squared waveform the DIRECT cause of the failure? No. In the end, the answer is, always has been, and can only be... heat kills speakers. BUT, clipping increases heat generation, sometimes by a drastic amount. So to start a thread simply to state that clipping does not hurt speakers is, again, a half-truth at best.
  3. Thanks nismos14 thanked for this post
    Likes nismos14, BigSix liked this post
  4. #3
    RicksI30's Avatar
    RicksI30 is offline CarAudio.com Elite
    May 2011
    Tucson, Az
    24
    544
    Re: Exodus Anarchy
    Beautiful drivers, and pics!
    Head unit: Kenwood Excelon KDC-X996
    Front stage: Alpine Type X PRO mids Vifa Neo 1" silk tweeters
    Front stage amp: PPI Bk800.4
    Subs: SSA XCON 12's in 4.5 cubes tuned to 34hz
    Sub amp: PPI Bk1300.1
    Sound Deadening: Second Skin Damplifier Pro, Spectrum, and Sludge
    Team SSA
  5. #4
    BigSix's Avatar
    BigSix is offline Whippin the Bass
    Aug 2009
    Austin,Tx
    2,026
    Re: Exodus Anarchy
    What will you pair them with
    Refs- Hrtbrk1,Kharps,BenzmanSl65amg,power-fanatic07,ryanm923,goindef154,subydude81
    cianzo,Sthib,FasFocus,Misfits
    Quote Originally Posted by misfit138 View Post
    It's a fucking shame that you got caught up trying to steal from somebody, you lowlife piece of ****. I hope you fall, asshole first, onto a 14" combat knife that's attached to a 18v Dewalt drill...
    Quote Originally Posted by retrojordans View Post
    The MTs are just like the 05' XXX
  6. #5
    gckless's Avatar
    Aug 2011
    San Antonio
    3,382
    23 Post(s)
    Re: Exodus Anarchy
    Quote Originally Posted by ciaonzo View Post
    I'm excited to see if I can hear a difference with the higher ohm load. I'll be powering them with two channels bridged on a Zed Levi each. Around 300W @ 8 ohms.
  7. #6
    gckless's Avatar
    Aug 2011
    San Antonio
    3,382
    23 Post(s)
    Re: Exodus Anarchy
    Quote Originally Posted by BigSix View Post
    I've got a pair of Vifa NE25VTS-04 tweeters and a pair of custom 15" 3HP's on 5k. I've got a half chub thinking about it all.
  8. #7
    BigSix's Avatar
    Aug 2009
    Austin,Tx
    2,026
    Re: Exodus Anarchy
    Quote Originally Posted by gckless View Post
    oh nice
  9. #8
    ciaonzo's Avatar
    Feb 2009
    WI
    8,636
    21 Post(s)
    Re: Exodus Anarchy
    Iz not a EssQue setup?
  10. #9
    ciaonzo's Avatar
    Feb 2009
    WI
    8,636
    21 Post(s)
    Re: Exodus Anarchy
    Careful with that power. In free air it will only take about 50-75w to stroke them, depending on how low you cross.
  11. #10
    gckless's Avatar
    Aug 2011
    San Antonio
    3,382
    23 Post(s)
    Re: Exodus Anarchy
    Trying for the definition of SQL. They are tuned just under 30Hz, so definitely not all out SPL. The subs were built by Zeus with a bit more SQ in mind. Won't be pushing 5k to them at all times, just wanted some big power available for when I want it.
  12. #11
    RicksI30's Avatar
    May 2011
    Tucson, Az
    24
    544
    Re: Exodus Anarchy
    Do you mean IB?
    Team SSA
  13. #12
    ciaonzo's Avatar
    Feb 2009
    WI
    8,636
    21 Post(s)
    Re: Exodus Anarchy
    Quote Originally Posted by RicksI30 View Post
    Do you mean IB?
    Yep, same thing.
  14. #13
    TaylorFade's Avatar
    TaylorFade is offline I fail.
    Dec 2009
    Baton Rouge, La.
    2,627
    131 Post(s)
    Re: Exodus Anarchy
    Holy smexy moofers.
    Quote Originally Posted by eCrack View Post
    TaylorFail
    Quote Originally Posted by Suicide Bobb View Post
    Taylorfail, v.2
    Quote Originally Posted by Imtjnotu View Post
    tailorFail v.3
    Quote Originally Posted by brodeisel View Post
    TaylorFail v.4
    Quote Originally Posted by tat2bass View Post
    TaylorWin v.1?
  15. Likes gckless liked this post
  16. #14
    gckless's Avatar
    Aug 2011
    San Antonio
    3,382
    23 Post(s)
    Re: Exodus Anarchy
    Got it. I plan on actually running around 200W to them, plus/minus a little depending on how they perform. Gonna be nice to have some headroom.
  17. #15
    RicksI30's Avatar
    May 2011
    Tucson, Az
    24
    544
    Re: Exodus Anarchy
    Quote Originally Posted by TaylorFade View Post
    Holy smexy moofers.
    They will be my next mids! Can't wait to switch to the 80prs....or maybe the 99 and a three way. Looking forward to your thoughts on them OP!
    Team SSA
+ Reply to Thread
  1. Exodus anarchy 6.5" mids
    By 04silverz in forum Speaker Classifieds
    Last Post: 11-22-2012, 07:09 PM
  2. Exodus Anarchy Mids
    By 04silverz in forum Wanting to Buy (WTB) - Car Audio
    Last Post: 09-28-2012, 11:17 AM
  3. Exodus Anarchy 4 ohm Mids
    By bose301s in forum Speakers
    Last Post: 02-02-2012, 04:08 PM
  4. 4 ohm Exodus Anarchy
    By Jroo in forum General Discussion
    Last Post: 01-31-2012, 09:33 AM
  5. Exodus Anarchy mids just arrived.
    By RAM_Designs in forum Speakers
    Last Post: 01-15-2011, 02:26 AM
