Page 3 of 3 FirstFirst 1 2 3
Results 31 to 33 of 33
Reload Thread: Amplifying tweets AND mids?
  1. #31
    MutantDreams's Avatar
    MutantDreams is offline Senior VIP Member
    Apr 2012
    Columbus, Georgia
    261
    64 Post(s)
    Re: Amplifying tweets AND mids?
    I don't really wanna derail the thread, would you mind explaining how you would time align them? Or what that is for that matter?
  2. #32
    gckless's Avatar
    gckless is offline CarAudio.com Veteran
    Aug 2011
    San Antonio
    5,164
    6 Post(s)
    2220 Post(s)
    Quote Originally Posted by MutantDreams View Post
    It's a process for making all the waves from each driver reach your ears at the same time. That way you don't hear any delay between your highs and mids, for example. You need some sort of processing to do this. Here's a way to do it by ear:
    http://www.diymobileaudio.com/forum/...alignment.html
  3. Thanks MutantDreams thanked for this post
  4. #33
    av83's Avatar
    av83 is offline CarAudio.com Veteran
    Mar 2012
    Illinois
    3,031
    13 Post(s)
    1335 Post(s)
    Quote Originally Posted by PapaGeno21 View Post
    Also because my amps all have their own crossovers that have been properly set, should I just let the headunit play through without the deck crossovers?
    I would use the hu crossovers, and turn the amps to full range. First try 80hz for the hpf and 63 for the lpf. if the mids sound like they're in trouble, then go to 80 & 100.
    you can always try a mix, too. the dc probably has a nice 24db crossover, you can use that one and use the hpf on the hu.
    80prs
    SoundQubed 6.5 Pro's DD T2 Tweeters / new 4 Chan coming / new subs coming / DC Audio 5.0K
    Singer 310 6 phase 2 runs of Monster Cable 1/0 / Exide g78 AGM under hood and XS D3100 in rear
    Plenty of deadener. CCF and fiberglass insulation in doors... thanks to the advice of keep_hope_alive they sound AWESOME! :-)
  1. ADS AL6 X over point for tweets and mids?
    By carter1010 in forum Speakers
    Last Post: 08-04-2010, 01:03 PM
  2. WTB: SQ oriented Tweets and Mids. No x-overs necessary
    By XaznKewLguyX in forum Wanting to Buy (WTB) - Car Audio
    Last Post: 09-22-2009, 03:25 AM
  3. WTB: Tweets and Mids
    Last Post: 08-04-2009, 09:44 PM
  4. Installing Seas Neo tweets and mids...what should I do? Pics included
    By Chowder Head in forum Wiring, Electrical and Installation Help
    Last Post: 08-14-2008, 01:19 AM
