Page 2 of 5 FirstFirst 1 2 3 4 5 LastLast
Results 16 to 30 of 70
Reload Thread: Lets say you have $1k for front speakers...
  1. #16
    Why So Cereal?'s Avatar
    Why So Cereal? is offline Invisible Cereal
    Sep 2010
    Drowning in milk
    7,403
    1555 Post(s)
    Re: Lets say you have $1k for front speakers...
    Quote Originally Posted by neo_styles View Post
    Either Scanspeak Deluxe kit or the GB Neo10 mids (200 each), Neo3 tweets (100 each), and Dayton RS 8" midbasses (50 each). Run 'em active.
    ---------- Post added at 05:07 PM ---------- Previous post was at 05:07 PM ----------
    Hell, if you can fit the 10" Dayton mids, go with those.
    The Madisound Speaker Store
    -OR-
    Dayton Audio RS270-8 10" Reference Woofer 295-357
    Bohlender Graebener Neo10 Planar Transducer 264-715
    Bohlender Graebener Neo3W Planar Tweeter w/Back Cup 264-730
    If I go active, I'll only do 2 way fronts.
    The MS8 has 8 outs right?
    Tweeters + mids + rears = 6
    Subs + Center = 2
    That takes care of all 8 channels there.
    In order to do 3 way front, I would have to eliminate rears.
  2. #17
    neo_styles's Avatar
    neo_styles is offline AKA Pop Twidget
    Sep 2012
    WA
    32
    3,623
    1703 Post(s)
    Quote Originally Posted by princ3cmo View Post
    Subs + Center = 2
    Or you can eliminate the center. MS8's Logic7 processing does center channel simulator well enough
    Spotify: http://open.spotify.com/user/neo_styles/playlist/6t9ru42j0wbEsuo4bXqXD8
  3. #18
    Sep 2010
    Drowning in milk
    7,403
    1555 Post(s)
    Even eliminating the center doesn't leave enough channels for the midbass drivers of a 3 way front stage.
    That just opens up one channel.
  4. #19
    hispls's Avatar
    hispls is online now CarAudio.com Veteran
    Sep 2009
    Cape Cod, Massachusetts
    9,962
    15
    36 Post(s)
    4050 Post(s)
    Because of the way things are looking. The build will be "SQL" oriented. Very SQ oriented up front with a strong sub stage out back thats not necessarily SQ oriented. The catch is that, I will be using a double din HU and I will be running rears.
    I suppose, the only way around both those issues is to go with an external processor. In that case, I'll probably go with the MS8 (as I can't see the ARC PS8 really being worth the coin for what I'll be using it for).
    Granted I go with the MS8, then yes I suppose I could go active. What drivers would you guys recommend at the price point?
    I really like the Scan Illuminator mids as of now. But, I'm still searching.
    Planned on using rears with no processing and SQ don't belong in the same paragraph.
    I just got some SEAS lotus tweeters that I like a lot. I'd be very interested in trying thier mids.
    I really really like planar mids/tweets but they can be finicky about playing off-axis so you need good locations. I've done a 3 way with 6.5" midbass, planar mid, and soft dome tweet, that I really liked.
  5. #20
    neo_styles's Avatar
    Sep 2012
    WA
    32
    3,623
    1703 Post(s)
    In that case, just strike the planar mids except those are definitely the crown jewel of the setup
  6. #21
    shadow's Avatar
    shadow is offline Senior VIP Member
    Jan 2012
    Dallas,Texas
    243
    84 Post(s)
    Dynaudio ESOTEC SYSTEM two way another couple of bills you could get the three way with 8" midbass...
    Think I'm going to run some this year...
  7. #22
    Sep 2010
    Drowning in milk
    7,403
    1555 Post(s)
    Quote Originally Posted by hispls View Post
    The rears we're going to be delayed by a mini DSP and attenuated. They would only have been missing the differenced signal (or whatever processing the MS8 does to them)
    I hear SEAS makes awesome tweeters. I never hear much remarkable about their mids, but I do hear that they are solid enough and never much bad so I will consider them.
    Your comment about the planars is the main reason that I'm against them. I would need to do a lot of playing with aiming on them, and while that part is fine and I do that with all of my setups anyway, the looks of the Planars just do not fit every location IMO and I don't want to end up with the optimal sounding spot being the most aesthetically unpleasing spot.
  8. #23
    neo_styles's Avatar
    Sep 2012
    WA
    32
    3,623
    1703 Post(s)
    Quote Originally Posted by shadow View Post
    That esotec wideband mid is deep as hell, though. It is closed back so I guess you could just loosely mount it in the kick. @TaylorFade ; had some experience with either the esotar or the esotech. He could probably shed some light on it.
  9. #24
    neo_styles's Avatar
    Sep 2012
    WA
    32
    3,623
    1703 Post(s)
    There's a really good build log with the BG planar mids and tweets on DIYMA. He just wrapped them in grille cloth and mounted them up the a-pillars. couldn't even really tell they were there.
  10. #25
    Sep 2010
    Drowning in milk
    7,403
    1555 Post(s)
    yep I saw those, I think on woofersetc.
    My concern with 3 ways was driver value per dollar.
    In other words, how much better are the drivers in $1k 2 way in comparison to a $1k 3 way set where the money is split between two extra drivers and crossover components for them?
    ---------- Post added at 08:24 PM ---------- Previous post was at 08:23 PM ----------
    I have been looking for something like that. Same idea I was toying with in my head.
    Got a link to it?
  11. #26
    neo_styles's Avatar
    Sep 2012
    WA
    32
    3,623
    1703 Post(s)
    The esotec benefits immensely from that wideband mid. It's a solid choice if you have the processing for it, but the size would be my concern. It'll take some decent fab to get those where you'd want them
    ---------- Post added at 05:25 PM ---------- Previous post was at 05:24 PM ----------
    Got a link to it?
    It's bookmarked on my Chrome. I'll PM it to you when I get home. System must have sounded amazing with all the work he put into it.
  12. #27
    murph's Avatar
    murph is offline Low for Life
    Sep 2011
    Richmond,VA
    4,164
    2 Post(s)
    1523 Post(s)
    Lets say you have alt=k for front speakers...-4xsjqzs.jpg Can you really get better tweets than that for the money.
    Hu: kenwood kdc-x995
    Sub: Boston acoustics G5 12 in a quasi 6th order
    Amp: Phoenix gold zx600.2 ti
    Front Speakers: Eclipse sc6500
    HIT UP FOR BASS ---> http://www.youtube.com/user/BassWithMurph?feature=mhee
  13. #28
    Sep 2010
    Drowning in milk
    7,403
    1555 Post(s)
    I'll have to look into the Dims of it then. I'll more than likely head up to my pillars for the mids and tweeters as opposed to kicks.
    Def shoot me that link
    ---------- Post added at 08:29 PM ---------- Previous post was at 08:29 PM ----------
    Quote Originally Posted by murph View Post
    Attachment 26539678 Can you really get better tweets than that for the money.
    Those the PHDs?
  14. #29
    shadow's Avatar
    Jan 2012
    Dallas,Texas
    243
    84 Post(s)
    I'm running Milles three way right now and I like have'n my mid and tweeter above my dash...
    I have ran them as two way and they sounded great that way also... Just for my install having the mid and tweeter above my dash works for me...
  15. #30
    murph's Avatar
    Sep 2011
    Richmond,VA
    4,164
    2 Post(s)
    1523 Post(s)
    Those the PHDs?
    I would like to see a product and pricing list from them.
    Yeah they are the AF 1.c tweet's f'n sexy. Hit up geoff for pricing.
  1. Making the right choice for front speakers?
    By SoSo09 in forum Speakers
    Last Post: 05-08-2009, 01:51 PM
  2. amp for front speakers
    By RebelDogg in forum Amplifiers
    Last Post: 06-02-2008, 01:44 PM
  3. Replies: 12
    Last Post: 06-01-2008, 01:52 PM
  4. what is the best position for front speakers?
    By luv2bass in forum Speakers
    Last Post: 05-01-2004, 10:16 PM
  5. Replies: 37
    Last Post: 05-27-2003, 05:58 PM
