Page 3 of 3 FirstFirst 1 2 3
Results 31 to 33 of 33
Reload Thread: suggestions for "sql" front stage
  1. #31
    blakgtp's Avatar
    blakgtp is offline Member
    Jan 2013
    WA
    73
    Re: suggestions for "sql" front stage
    k. went ahead and bought the vifa's. can't wait for them to arrive. thanks for all the help guys
  2. #32
    blakgtp's Avatar
    Jan 2013
    WA
    73
    So I know it's been a while, but I've been busy. Plan on installing the silver flutes soon. Is it worth it to make an angled baffle so the woofer is more on axis? or should I just mount them on a flat baffle to the door?
  3. #33
    zako's Avatar
    zako is offline CarAudio.com Elite
    Jan 2011
    TX
    1,347
    6 Post(s)
    Quote Originally Posted by blakgtp View Post
    For a 6 inch woofer, sound dispersion starts becoming directional at about 2KHz, and you can experience a dip as big as -10dB past 2.5KHz. However, you can certainly use equalizer to adjust the woofer's frequency response in the upper mid-range, as long as it can actually play accurately in upper frequencies. Another solution is to let the tweeter play down to like 2.5KHz, then it won't matter if the woofer is on axis or off axis. However, a tweeter may sound harsh the lower you crossover it if you like to play loud music. The seas tweeter resonance frequency is at ~1.1KHz, so I think 2.5KHz HP with a sharp slope should be doable. If you have a good equalizer to bring up woofer's upper midrange or if you install woofers more on axis, I think it would be preferable to HP the tweeter at like 4KHz for smoother sound.
  1. Front Stage For Sale SQL!
    By infamous_e46 in forum Speaker Classifieds
    Last Post: 07-31-2011, 12:55 PM
  2. AMP suggestion for 3 way ACTIVE front stage.
    By xslothlovechunk in forum Amplifiers
    Last Post: 11-02-2006, 02:47 PM
  3. New Components for Front Stage
    By FAM4LIFE in forum Subwoofers
    Last Post: 01-16-2003, 06:37 PM
  4. how much power for front stage?
    By drkodin in forum Subwoofers
    Last Post: 11-20-2002, 04:43 PM
  5. help me select an amp for front stage...
    By xmywarx in forum Amplifiers
    Last Post: 03-24-2002, 08:26 PM
