Page 2 of 2 FirstFirst 1 2
Results 16 to 17 of 17
Reload Thread: tweeters and woofers at same gain level?
  1. #16
    zako's Avatar
    zako is offline CarAudio.com Elite
    Jan 2011
    TX
    1,347
    238 Post(s)
    Re: tweeters and woofers at same gain level?
    Quote Originally Posted by maylar View Post
    I believe the Imagine tweets are 12 ohms, which would mean that they get 1/3 the power of the mids with the same applied voltage. It makes sense that a tweeter with no level controls in the crossover would want the same signal level as the mating midrange.
    That could explain it, though it's not the case according to Scott Buwalda:
    Imagine I6 High Pass/Wattage (Active) - Page 2
    The stock crossover is not very good. A lot of people find tweeter a little bright. The first order high pass also means the tweeter plays a bit too much of upper mid-range frequencies. I find the stock setup fatiguing.
  2. #17
    maylar's Avatar
    maylar is offline Electrical Weenie
    Jan 2002
    Connecticut
    66
    3,498
    2 Post(s)
    399 Post(s)
    Quote Originally Posted by zako View Post
    Unfortunately, my hearing is poor above 6K so I barely notice my Imagine tweets at all especially off axis low in the doors.
    I based my hunch on their impedance on the 2.2uF hipass cap and the 6 kHz published spec. People assume that component tweeters are 4 ohms which is not always true. Next time I have my doors apart I think I'll measure them.
    dave
    1999 Buick Park Ave Ultra
    Head Unit: JVC KWHDR720
    EQ: Audiocontrol EQL
    Front Stage: Hybrid Audio Technologies Imagine 5.25 mids, Morel Maximo tweets
    Sub Stage: Boston G3 10", 0.5 cu ft sealed
    Amp: PPI Phantom 900.4
    Rear Fill: Boston SE953 6X9's
  1. Replies: 6
    Last Post: 06-26-2006, 12:55 AM
  2. Alt and ground noise possible at same time?
    By zachzchw in forum General Discussion
    Last Post: 05-22-2005, 11:48 PM
  3. What subs are at same level or higher than 12" L7?
    By loudfivepoint0 in forum Subwoofers
    Last Post: 01-12-2005, 01:12 AM
  4. Replies: 5
    Last Post: 10-11-2003, 02:11 PM
  5. Amp distorts at low gain level
    By redciv in forum Amplifiers
    Last Post: 08-04-2002, 12:23 PM
