+ Reply to Thread
Page 3 of 4 FirstFirst 1 2 3 4 LastLast
Results 31 to 45 of 47
Reload Thread: Advice on SQ Component Speakers. Price Range $150-$300
  1. #31
    neo_styles's Avatar
    neo_styles is offline AKA Pop Twidget
    Sep 2012
    Porter Ranch, CA
    27
    3,055
    41 Post(s)
    Re: Advice on SQ Component Speakers. Price Range $150-$300
    Quote Originally Posted by blakgtp View Post
    bumping this thread because I am looking for new front stage in the same budget. I'm after a warmer sound, hate harsh highs. how would I determine out of those speakers listed above, which ones would sound "warm" and which ones would be more detailed/brighter etc. ?
    Has to do with the presence of the mid. Warmer sets tend to have more midbass presence while the tweets are laid back. Bright sets will have a higher emphasis on the tweeter. They'll also be called crisp of overly detailed.
    I picked my JBLs because I thought they were a good middle between both extremes. Plenty of midbass, well detailed (especially with live/acoustic instruments), but not shrill or sibilant.
  2. #32
    neo_styles's Avatar
    Sep 2012
    Porter Ranch, CA
    27
    3,055
    41 Post(s)
    Also keep in mind the harshness of a tweeter has more to do with install than it does the driver itself. Give it too many surfaces on which to reflect and even the best tweeters will sound awful. Most people prefer mounting their tweeters on the a-pillar roughly 2-3 inches above the highest point on the dash to minimize reflections.
    Common beliefs when it comes to a tweeter's harshness has to be in its material. Textile domes (silk) are softer while metal domes (aluminum/titanium) are harsher. There are exceptions to every rule though...
  3. #33
    blakgtp's Avatar
    blakgtp is offline Member
    Jan 2013
    WA
    53
    thanks for the reply. Do you think I'd get better value for my dollar buying a component set, or piecing together a set? possibly with silver flutes for the mids. I've wanted to try a 3 way setup with dash pods, but I'm not sure if it's more trouble than it's worth.
  4. #34
    neo_styles's Avatar
    Sep 2012
    Porter Ranch, CA
    27
    3,055
    41 Post(s)
    Are you already set up to go active? If so then yes, you can save yourself dough by piecing it together yourself. My personal recommendation would be the Dayton RS-180 mids and Vifa ring radiators for tweets. Both at Parts-Express.
  5. #35
    neo_styles's Avatar
    Sep 2012
    Porter Ranch, CA
    27
    3,055
    41 Post(s)
    Or you could go nuts and get the planar magnetics on PE. Saw a setup of those planars on DIYMA and started drooling involuntarily.
  6. #36
    blakgtp's Avatar
    Jan 2013
    WA
    53
    Quote Originally Posted by neo_styles View Post
    Yes I have the clarion cz702 hu so I can go 2 or 3 way active. the thing i like about 3 way, is that I don't have to worry as much about the mid woofer being off axis, if the tweet and midrange are on axis. at least I think that's how it works? i'm kinda a noob
  7. #37
    neo_styles's Avatar
    Sep 2012
    Porter Ranch, CA
    27
    3,055
    41 Post(s)
    There's more to it than that. I'd consider starting 2-way and adding the midbass when you get the hang of things. Setting up a 3-way, from what I've heard, is a bitch. Since you have an active-capable HU, you can use phasing, TA, and EQ to compensate for the lesser-than-optimal mounting locations of your mid and tweet. I'd spend some time in the DIYMA How-to section to learn a few tips and tricks for going active as well.
    How are you able to mount your mid and tweet on axis, btw?
  8. #38
    blakgtp's Avatar
    Jan 2013
    WA
    53
    I was going to make dash pods
  9. #39
    neo_styles's Avatar
    Sep 2012
    Porter Ranch, CA
    27
    3,055
    41 Post(s)
    That's smart. I'd say keep the dash pods as your plan and just go 2-way for now. Learn how to tune that active. You can always add the midbass later.
  10. #40
    Ridinhi's Avatar
    Ridinhi is offline CarAudio.com Veteran
    Aug 2006
    NC
    2,807
    6 Post(s)
    Quote Originally Posted by ge_off_me View Post
    I can get you a good deal on some PHD MF series components. I would put money on the fact that they would sound better than the imagines. Hell, even the CF line should sound about equal with the imagines. PHD - Speakers - Model MF 5.1 KIT -
    Can you pm me some info on the PhD mf 6.1 kit? And price
  11. #41
    mlstrass's Avatar
    mlstrass is online now Shaggy DOA
    Jul 2006
    Illinois
    9,653
    14 Post(s)
    Vifa xt25 ring radiator is an excellent sounding tweeter, but it needs to be mounted on-axis or output drops off a ton...
  12. #42
    gckless's Avatar
    gckless is online now CarAudio.com Veteran
    Aug 2011
    San Antonio
    3,503
    24 Post(s)
    OMG yes. I did the same thing.
    Quote Originally Posted by ducatipaso View Post
    To say that 8inch, 10inch and even 12inch subs are for girls is just not true. 15inch subs can't play fast beats, they take more power and that taxes the vehicles electrical system. You will wake up and "hear" then see the light at the end of the tunnel and it will be 3 10's pounding so hard you wont even open your trunk or turn your system on because you 15's will sound sloppy & weak.
    Quote Originally Posted by benbenondatrack View Post
    stfu lesbo.why are you worried about me so much? you must want to date me ya little cookie monster but i dont even like sweets. your just a cup full of ice, dirt dead nasty azz ice...without the water.
  13. #43
    Chriszle's Avatar
    Chriszle is online now CarAudio.com Elite
    Jan 2011
    SD
    1,564
    7 Post(s)
    Not sure if it has been mentioned yet, but if you blew your tweeters in less than a year, you might want to find out what is causing the issue before spending money on more speakers. Also, the speakers you choose will only sound as good as the installation allows. Properly installed 50 dollar coaxials can sound as good or better than 300 dollar components that are poorly installed.
  14. #44
    blakgtp's Avatar
    Jan 2013
    WA
    53
    so. I haven't made up my mind on the front stage yet because I've heard mixed things about the daytons rs180 and vifa radiator tweet combo. Do you think they will have enough output to keep up with my sub stage (sundown sa-15 on 1700watts, soon to be 2 sa-15's on 2500watts)? I'm pretty much a "SQL" guy. I like sq but it needs to be loud (at times). I'm thinking of giving the front stage 250 watts per side. 150watts per mid woofer and 100watts per tweet. (obviously tweets will never see that much) opinions?
  15. #45
    trumpet's Avatar
    trumpet is offline Supporting Vendor trumpet is a Supporting Member of the forum!
    trumpet is a Supporting Vendor of the forum!
    Jan 2011
    Langdon, ND
    32
    2,165
    52 Post(s)
    If you run your mids and tweeters in their pistonic range you don't even need them aimed on axis. This works if you apply the logic of keeping the speakers operating so their polar response is the same whether you're in the driver's seat or the passenger's seat. I did this with my latest setup so I have a 3-way entirely on/in the doors below the glass. I use the factory speaker location up front for a 6.5" driver and I have 2" mids and 1" tweeters on the door panel near the latches. I've found that in conjunction with my MS-8 for tuning I get better tonality and more stable imaging than I ever had with the mids and tweeters above the dash. Stage depth has been compromised only slightly and all sound is on the dash.
    You can run 100W to tweeters that are rated for much less power if you use a high crossover frequency with a 24 dB/octave slope. This requires a midrange driver unless you use a woofer that can play up to or beyond 5 kHz or so. I have my tweeters crossed at 6 kHz with 120W RMS per tweeter.
    Small town service, family owned and operated. @EasyWayElectron for specials
    Click for my CDT Audio dealer store, Clarion, JBL, Precision Power, Massive Audio, Diamond Audio, Metra, and much more
    my system: Precision Power P-771NX, JBL MS-8, Massive Audio NX4, Xtant 1.1i, CDT MX-3MO with DRT-26A upgrade, MX-3CSL center, JBL MS-BassPro SQ
+ Reply to Thread
  1. New build advice on SQ
    By Myster in forum General Discussion
    Last Post: 11-26-2006, 06:42 PM
  2. advice on honda civic speakers
    By jayroc2k in forum Speakers
    Last Post: 04-20-2004, 06:23 PM
  3. advice on some components
    By Blackterror in forum Speakers
    Last Post: 04-04-2004, 08:41 PM
  4. Advice on SQ setup
    By jb4153 in forum General Discussion
    Last Post: 02-20-2004, 08:46 PM
  5. SQ Component Speaker Help
    By 996twint in forum Subwoofers
    Last Post: 09-18-2002, 01:59 AM
