SPeaker Baffles ? to get or not to get is the question!
I have a little 88 crx and was wondering if i should get speaker baffles? i heard that these type of cars get moisture in the door panel but i wasn't sure i should get Baffles or heard deadening the door ? what do you guy-s think ? getting SA-6.5cs :yumyum:
Re: SPeaker Baffles ? to get or not to get is the question!
One technique I've seen for protecting speakers in doors that tend to get water coming in is to buy foam baffles and cut out the back so it's like an umbrella. Sound deadening is a must for any vehicle to get the most out of your speakers. Even just some vibration damper will help with bass reproduction and reducing vibrations of the sheet metal and panels.
You could plastidip the woof baffle and use something like trumpet said to protect the rear.
