Results 1 to 3 of 3
Reload Thread: 6.5 or 8?
    fenwick11's Avatar
    fenwick11 is offline Member
    Jul 2009
    Jacksonville,FL
    91
    6.5 or 8?
    I recently blew my door speakers and I have to replace them. I had some polk 6.5 that werent loud enough to keep up with my hcca 15. I was wondering are there 6.5 speakers that are loud enough to keep up with my 15 inch subwoofer and 6x9 in the rear of the car. Or should i make custom door panels and have 2 sets of 6.5 in each front door. Or I was directed towards getting some 8 inch mid bass drivers to put in the door. any input is helpful. thanks in advance
    Ride: Silver 2005 Dodge Magnum SXT.
    Head Unit: Pioneer Premier DEH-P410UB.
    Amp: Xtant 1000 xD.
    Subwoofers: Recently Stolen
    Box:
    Front Stage: Polk EX365 (Currently Running Off Head Unit.)
    Rear Stage: Polk DB691
    Looking To Buy: Subs, Kick Panels and Batt
    winkychevelle's Avatar
    winkychevelle is offline CarAudio.com Veteran
    Jun 2009
    Ponchatoula, La
    26
    3,431
    769 Post(s)
    Re: 6.5 or 8?
    just about any 6.5 should get loud enough if installed properly and powered correctly. but for loud and efficient look into the memphis power reference line and above. if you want more mid bass then an 8 could be a viable solution though i believe the install to be more the problem than the equipment.
    my factory speakers keep up with my hd12 on 2000w for the most part they fade out when i get to higher levels but if i amped them i see no reason they couldnt be loud enough. now i wont waste my time doing that because im going to be switching them out with some db drive comps in hopes that the db drive sound decent or ill jut switch them out for some focals.i just like the look of db drives top of the line components
    2014 Chevrolet Cruze Diesel
    2013 Chevrolet Silverado 3500HD 4x4
    Pioneer touch screen with front and rear cam, will add
    A kingpin camera and a trailer rear cam soon
    Memphis viv component run active
    Kicker cx1200.1
    Kicker cx 300.4
    2 jl 13tw5-3 wired to 1.5ohm at about 1000rms
    ****** box that needs to be replaced soon
    zako's Avatar
    zako is offline CarAudio.com Elite
    Jan 2011
    TX
    1,347
    238 Post(s)
    Re: 6.5 or 8?
    Massive Audio CK6 and RK6 have a reputation for high power handling and getting loud. The CK6 require lower clearance, and supposedly sound cleaner.
  1. Dynamat sheets or spray?
    By <Black> in forum General Discussion
    Last Post: 09-15-2004, 04:12 PM
  2. jl 500.1 or audiobahn 1300 hcx? HELP!!!! quick
    By rpeterson57 in forum General Discussion
    Last Post: 06-04-2002, 05:40 AM
  3. At this stage, better subs, or better highs?
    By <no1beefcake> in forum General Discussion
    Last Post: 12-22-2001, 09:34 PM
  4. Diamond S600 components anyone heard or have them?
    By <Integra> in forum General Discussion
    Last Post: 12-16-2001, 03:15 PM
  5. 2 jl 12' w6's or 3 jl 12'w3 or 1 jl 15' w3?
    By southernbandit20 in forum General Discussion
    Last Post: 12-13-2001, 12:35 AM
