+ Reply to Thread
Page 2 of 3 FirstFirst 1 2 3 LastLast
Results 16 to 30 of 43
Reload Thread: Cant get SQ out of these comps help!
  1. #16
    stay_high's Avatar
    stay_high is online now CarAudio.com Elite
    Jun 2011
    Bradenton Florida
    594
    6 Post(s)
    Re: Cant get SQ out of these comps help!
    Quote Originally Posted by goingdef View Post
    have you even tried to use the amps xovers instead of the hu's I know my hu's settings aren't on a steep enough slope and don't allow me to turn it up at all but sound awesome low, IDK just a thought.
    Yes i have tried both crossovers. and no i didnt combine both of them (although i even tried this too) lol.
    Head Unit: JVC Arsenal KD-AHD65
    Mids/Highs: I.D. CTX65c's
    Mids/highs amp: Kicker zx550.2
    Subs: 2 12 inch AQ SDC's. Custom Ported box tuned @ 35 hz
    Sub amp: MB Quart onx1500.1
  2. #17
    goingdef's Avatar
    goingdef is offline CarAudio.com Veteran
    Jan 2008
    Norfolk VA
    32
    2,816
    11 Post(s)
    Quote Originally Posted by stay_high View Post
    well IDK it sounds like you've tried everything, Wait idea! try reversing your subs phase when I inverted my 12"s my doors sounded blown everytime I turned it up it took me a minute to realize what I had done but when I reversed phase everything cleared up and sounded great again.
    electrical: Optima yellow top, big 3 in stinger 1/0g
    HU: JVC AVX-77 touch screen
    Front stage: RE XXX 6.5" comps
    front stage amp: Rockford T600.2
    subs: 2 Rockford T1 12's,
    sub amp: Rockford T1500.1BDCP
    Enclosure: center port(designed&built by JayDubb757)
  3. #18
    stay_high's Avatar
    Jun 2011
    Bradenton Florida
    594
    6 Post(s)
    REally? how would that affect speakers on a different amp? Could i just unhook the subs/amp and see how the comps sound? Would that have the same effect? But yea i know i have tried everything possible and just cant figure it out. Pisses me off when my buddies have cheap *** gear from best buy that they just tossed in their car and it is out performing my stuff thats at least half way decent and i took my time installing... Think im gona try to run some RCA's from my friends HU to my kicker amp... If it still sounds bad that would eliminate a problem with my HU
  4. #19
    stay_high's Avatar
    Jun 2011
    Bradenton Florida
    594
    6 Post(s)
    By reversing phase you mean just hooking up neg wire to pos terminal and pos wire to neg terminal correct?
  5. #20
    goingdef's Avatar
    Jan 2008
    Norfolk VA
    32
    2,816
    11 Post(s)
    yep thats what I mean and as far as how it effects it; does you windshield flex? If so then when your subs pressurize the cabin and your door speakers attempt to fight them in the opposite direction they lose and the result is terrible sound!
  6. #21
    stay_high's Avatar
    Jun 2011
    Bradenton Florida
    594
    6 Post(s)
    Dude on a low note my windows get some crazy flex goin. But the thing is i have been listening to the comps with the sub lvl all the way down just to get the settings right. But how would reversing the polarity stop the flex? Just make the subs not as loud or something? I also heard once that i canot reverse polarity on my subs because the speaker wire is hooked up directly to them or somethin
  7. #22
    goingdef's Avatar
    Jan 2008
    Norfolk VA
    32
    2,816
    11 Post(s)
    wired straight to my subs backwards! and yes it's just as loud and you won't even notice except your highs may clear up!
  8. #23
    stay_high's Avatar
    Jun 2011
    Bradenton Florida
    594
    6 Post(s)
    But u switch polarities on the amp right? I dont need to mess the way the subs wires?
  9. #24
    goingdef's Avatar
    Jan 2008
    Norfolk VA
    32
    2,816
    11 Post(s)
    right if you look the wires are red to red on the subs but look where they go into the amp the red is going to the - and the black is going to+
  10. #25
    thevic24's Avatar
    thevic24 is offline my silence is deadly...
    Apr 2007
    right behind you
    5,718
    Well try and use an Ipod for the source and see if it still gets crapy sounding. If it dose, then the amp my be cooked.
    Silently stalking you through glass....
  11. #26
    pickup1's Avatar
    pickup1 is online now Audiosystem. .
    Aug 2005
    Roanoke,TX
    48
    6,661
    17
    28 Post(s)
    Or bypass the amp and see if that works..
  12. #27
    Exist_ential's Avatar
    Exist_ential is offline CarAudio.com Elite
    Mar 2012
    Southwest PA
    33
    772
    14 Post(s)
    im no guru (or SQ guy at all) but goingdef's suggestion makes total sense.
    if you are getting windshield flex from your sub that means they are pushing all the pressure to the front of the cabin, conversely the mids/tweets are doing the exact same thing at the exact same time but are pushing towards the sub (in a sense).
    If you have enough pressure in the cabin to flex the windshield then you have enough pressure to keep the cones on the mids/tweets from moving properly. by switching phase on your subs they will be pressurizing the cabin at the exact OPPOSITE time as the mids/tweets, therefore allowing the mids/tweets to time to move to create the vibrations needed to produce sound.
    i would think an easy test for this (if you dont want to mess with the sub wiring right away) would be A. turn of the sub completely or B. open all the doors to equalize cabin pressure. If during either (or both) of these tests your mids/tweets sound like they should then goingdef's suggestion is the proper fix.
    HU-- Jensen vm9224bt double din
    Sub -- T3 TSS custom built by Corey Dean
    Amp -- American Bass XD3000
    refs: mylows10, princ3cmo, cthedinger, cjwoods, nuboot, evilsaint, skaraudio x2, brodeisel, omegabunny x2, Louisiana_CRX
    if i helped you out please remember to click thanks.
  13. #28
    stay_high's Avatar
    Jun 2011
    Bradenton Florida
    594
    6 Post(s)
    Quote Originally Posted by Exist_ential View Post
    right but i have been listenining to them without the subs on so its not that
    ---------- Post added at 11:13 AM ---------- Previous post was at 11:12 AM ----------
    Quote Originally Posted by pickup1 View Post
    What do you mean? Wire the speakers to the HU?
  14. #29
    stay_high's Avatar
    Jun 2011
    Bradenton Florida
    594
    6 Post(s)
    Quote Originally Posted by thevic24 View Post
    I do this by using a Y adapter right? Like a rca to headphone jack then just straight the amp and my iphone?
  15. #30
    maylar's Avatar
    maylar is offline Electrical Weenie
    Jan 2002
    Connecticut
    61
    3,243
    8 Post(s)
    OP you say you have the mids sealed to the doors, but what is the install like? You using the factory mounting? Got any pics of the inside of your doors?
    Reason I ask is that some factory speaker mountings are sealed boxes (my Buick was like that), tuned to the OEM speakers and any aftermarket speaker can sound terrible. Just throwing out possibilities...
    dave
    1999 Buick Park Ave Ultra
    Head Unit: JVC KWHDR720
    EQ: Audiocontrol EQL
    Front Stage: Hybrid Audio Technologies Imagine 5.25
    Sub Stage: In process (will be Boston G310)
    Amp: Boston Acoustics GTA-704 4 Ch
    Rear Fill: Boston SE953 6X9's
+ Reply to Thread
  1. getting sq out of a l7 15
    By 4uha8ers in forum Subwoofers
    Last Post: 06-26-2006, 02:33 PM
  2. What would you get out of these four comps?
    By phatrabbitzz in forum Speakers
    Last Post: 06-08-2004, 02:20 PM
  3. cant get current out of power wire
    By lAciDl in forum Wiring, Electrical and Installation Help
    Last Post: 10-15-2003, 02:50 AM
  4. Out of these HU's, What one would you get?
    By ss3079 in forum General Discussion
    Last Post: 04-16-2002, 02:56 PM
  5. Out of these, which one do I get?
    Last Post: 03-29-2002, 07:48 PM
