+ Reply to Thread
Page 1 of 2 1 2 LastLast
Results 1 to 15 of 20
Reload Thread: How do I hook up speakers/tweeters without a crossover?
    sjv13's Avatar
    sjv13 is offline StayStrange
    Apr 2011
    Lansing, MI
    616
    2 Post(s)
    I'm running a pair of the Focal IS 165 comps. These have integrated crossovers somehow, so there is no crossover box needed. I am running them off the Alpine KTP-445, so there was no need for me to figure out how to wire them to a "real amp" before. Now I have a 4 channel on the way, and need to figure out how this is going to work.
    Here is what I have to connect: amp, woofers, tweeters.
    There is no crossover involved, so I'm not really sure how I get it down to two wires (+/-) from four (woofer +/- and tweeter +/-).
    Any information on how to do this would be great!
    2000 Volvo v70
    HU: Pioneer MVH-8200bt
    Front Stage: Focal IS-165
    Sub: Alpine Type-R 12"
    Speaker Amp: Polk PA660 bridged to 150x2wrms
    Sub Amp: Alpine MRX-M50
    Sub Box: Custom, tuned to 33Hz
    sjv13's Avatar
    Apr 2011
    Lansing, MI
    616
    2 Post(s)
    Re: How do I hook up speakers/tweeters without a crossover?
    Does no one really have an answer to help me out?
    2000 Volvo v70
    mylows10's Avatar
    mylows10 is online now WEST COAST DC & PHD REP mylows10 is a Supporting Member of the forum!
    mylows10 is a Supporting Vendor of the forum!
    Sep 2009
    monterey , ca
    13,034
    360 Post(s)
    use them on the hight pass filter only
    pioneer avhp 4100 dvd, 2 dc lvl 4 10's custom built by Thor's hammer , ab vfl 4480
    ab vfl 150.4 ,2 pc 2150 ,
    cdt 6.5 es 61 im mids,cdt es 010 tweets with es 200 us x overs stinger hpm o gauge wires
    NOR CAL DB DRAG JUDGE
    http://www.dcsoundlab.com
    zako's Avatar
    zako is online now CarAudio.com Elite
    Jan 2011
    TX
    1,245
    5 Post(s)
    Just hook them up the same way they're running right now on the Alpine amp.
    ewadz3006's Avatar
    ewadz3006 is offline CarAudio.com Elite
    Jan 2012
    erie, PA
    735
    7 Post(s)
    Troll?
    I feel sorry for those who do not drink, when they wake up on the morning that's the best they're going to feel all day.-Frank Sinatra
    2004 mercury mountaineer
    Hu Kenwood excelon x996
    Fronts Incriminator audio comps
    Front amp Aq 120.4
    sub amp Aq2200d
    subs 2 sundown sa 12's @ 32hz
    wiring knu 1/0 ofc
    sjv13's Avatar
    Apr 2011
    Lansing, MI
    616
    2 Post(s)
    Quote Originally Posted by zako View Post
    But that's the thing. I don't know what's going on with the Alpine amp because it just uses a wiring harness. Do you think I can just wire the positives of the woofers and tweeters together and the negatives of them together? Just by splicing?
    Quote Originally Posted by ewadz3006 View Post
    Troll?
    No, I'm really not. I've never wired a "real" 4 channel amp before and there is no manual for the Focals, and I can't find any information online any where about how people have hooked them up to an amp before.
    2000 Volvo v70
    >>SQL<<'s Avatar
    >>SQL<< is offline CarAudio.com Elite
    May 2011
    USA
    1,461
    1 Post(s)
    you are missing the crossovers, you need them
    There are no magical built in crossovers
    ewadz3006's Avatar
    Jan 2012
    erie, PA
    735
    7 Post(s)
    Quote Originally Posted by >>SQL<< View Post
    this... you need the crossovers. do a google image search and you will see what they look like. it has a input + &- (from amp) and a woofer output and a tweeter output. there is one of these for the left and one for the right speakers.
    Front amp Aq 120.4
    sub amp Aq2200d
    wiring knu 1/0 ofc
  9. #9
    >>SQL<<'s Avatar
    May 2011
    USA
    1,461
    1 Post(s)
    you are missing these
  10. #10
    Sonic.'s Avatar
    Sonic. is offline Senior VIP Member
    Jul 2012
    Toronto
    455
    Each woofer and each tweeter has an integrated 6 dB/octave crossover, hence they can be connected one per channel, as stated above, use them on hpf.
    http://www.crutchfield.com/S-xVNn83t...ml#details-tab
  11. #11
    sjv13's Avatar
    Apr 2011
    Lansing, MI
    616
    2 Post(s)
    That's actually I think somehow there are. Just look at this. It's part of the reason I bought them.
    Focal Integration IS 165 6-3/4" component speaker system at Crutchfield.com
    2000 Volvo v70
  12. #12
    richericks's Avatar
    richericks is offline Member
    Jun 2012
    Oregon
    62
    2 Post(s)
    Well, if no crossover is needed, run the Front RCA from your HU to the amp. At the amp end put a 'Y' splitter on each RCA. Plug the left channel RCAs into channel 1 & 3 on the amp, and the right RCA channel into channel 2 & 4. From the output side of the amp, run channel 1 to the left tweeter, run channel 2 to the right tweeter, channel 3 to the left mid, and channel 4 to the right mid. That keeps your tweeters on one gain and your mids on another, so you can dial them in independently. Although, it might be helpful to know which 4 channel amp is on the way (the Polk in your sig?).
    Someone please correct me if I'm off base here.
  13. #13
    sjv13's Avatar
    Apr 2011
    Lansing, MI
    616
    2 Post(s)
    Quote Originally Posted by richericks View Post
    Yes. It's the one in my sig. That might work. But I'm gonna try to see if I can contact Focal about it and see what they'd recommend.
    2000 Volvo v70
  14. #14
    sjv13's Avatar
    Apr 2011
    Lansing, MI
    616
    2 Post(s)
    *SNIP*
    I know what crossovers are... I'm just not sure how to hook up my speakers to a 4 channel because they somehow don't use one. That is a selling point of the "Integration" line of speakers from Focal.
    2000 Volvo v70
  15. #15
    >>SQL<<'s Avatar
    May 2011
    USA
    1,461
    1 Post(s)
    ok buddy - you are right.
    Your speakers have built in 6db crossovers on them.
    What is it you want to do? Me personally I would run the tweeters from 2 channels of the 4 channel amp and the mid woofers on the other 2 channels.
+ Reply to Thread
  1. how do you hook up lights to your speakers?
    By btlagunas in forum Speakers
    Last Post: 03-23-2009, 05:14 PM
  2. how do you hook up lights to your speakers?
    Last Post: 03-22-2009, 05:52 PM
  3. How do i hook up my tweeters.
    By CallMeChad in forum Speakers
    Last Post: 02-22-2009, 03:13 PM
  4. How do I hook up Speakers to my MRP-F300 Alpine amp
    By tbbaker01 in forum Wiring, Electrical and Installation Help
    Last Post: 06-06-2008, 02:09 PM
  5. Replies: 7
    Last Post: 11-02-2006, 01:27 PM
