+ Reply to Thread
Page 3 of 7 FirstFirst 1 2 3 4 5 6 7 LastLast
Results 31 to 45 of 94
Reload Thread: Is this why my front stage gets over taken by my sub stage?
  1. #31
    jockhater2's Avatar
    jockhater2 is offline CarAudio.com Veteran
    Sep 2011
    Saukville, WI
    2,598
    34 Post(s)
    Re: Is this why my front stage gets over taken by my sub stage?
    Quote Originally Posted by RAM_Designs View Post
    Hell, I'm just running some 6.5's in my doors and they can get louder than I want them to be. There's only so loud you can go before it just starts to hurt. Maybe my ears are just sensitive(my wife will argue otherwise).
    wow. I wouldn't know because everythings on the head unit. I originally only had 2 tweets and 2 door speakers in the front of the car. I added the 2nd set to try and make up for the over powering bass.
    I guess power is what I should have done, not more speaker.
    Head Unit Pioneer P99RS
    3 Runs of 1/0 OFC Power and 3 Runs of 1/0 OFC Ground
    1 XS Power D3400 & 2 XS Power XP3000 with Copper Bus Bars
    380 Amp & 320 Amp Iraggi Alternators(One is a chevy case, the other ford)
    RD 7500.1 running 2 12 inch Ascendant Audio Mayhems (might go up for sale)
    Tuned to 36 hertz. About 4.5 cubic feet, 8" Aeroport (made by dbeez)
    Audison LRx 6.9k on Morel MDT-29, RS100-4 & RS225-8 Daytons
    Alex Jones www.infowars.com Endgame, Obama Deception, Truth Rising,
    Fluoride in the water, poison in vaccines, chemical trails in the skyglobal
    elite banks run our government towards a one world global government.
  2. #32
    RAM_Designs's Avatar
    RAM_Designs is offline SketchUp Master
    Feb 2006
    Rockwall, TX
    27
    21,072
    97 Post(s)
    I'm using some HAT Imagine 6.5's and running them off an old school Alpine MRV-1507 with a potential 2x225 at my disposal.
    1,000+ designs since March 2011...
    I have my PM's turned off, please email at Ryan@RAM-Designs.com
  3. #33
    mlstrass's Avatar
    mlstrass is offline Shaggy DOA
    Jul 2006
    Illinois
    9,576
    12 Post(s)
    parallel wiring the coax's will change the xover point/slope of the built in xovers. Might not be a good thing.
    MbQuart 4ch is a very solid amp, especially if you can find one for a good price.
    Personally I'd sell off all the stuff you have and get a decent set of 6.5" comps and bridge a 4ch to power them.
  4. #34
    mlstrass's Avatar
    Jul 2006
    Illinois
    9,576
    12 Post(s)
    A single set of quality components and a 2x150 amp will please most anybody.
    Depends upon the substage and goals. For my daily that's fine, for my demo set up not even close....
  5. #35
    av83's Avatar
    av83 is online now CarAudio.com Veteran
    Mar 2012
    Illinois
    2,598
    47 Post(s)
    This is true for me, too. I see these front stages in peoples sigs around here and wonder how they can still hear. Mine is plenty loud enough to cause pain, and I have entry-level comps with about 100 wrms going to each tweet and the same to each woofer.
    HU: KDC-X994
    Front stage: Phd FB 6.1PRO KIT, Active
    Sub stage: 1st gen RE XXX 12" w/Fi recone
    Highs Amp: Kenwood Excelon XR-4S
    Lows Amp: Mmats D300hc
    The Rest: AT 60 mil, Optima Redtop underhood and Yellowtop in trunk, Big 3 and front to rear +/- runs in Monster Cable 1/0
  6. #36
    ejschultz's Avatar
    ejschultz is offline CarAudio.com Veteran
    Nov 2008
    Schererville, IN
    2,921
    19 Post(s)
    Quote Originally Posted by jockhater2 View Post
    so what is running "active"?
    Active vs. Passive: An attempt by me to explain
    94 Caprice Classic LS: DEH-P800PRS, TS-C720PRS, MRV-F545, MRD-M1005, 2 REF-TM12.4 in 2.5 net cubes sealed; 97 Grand Cherokee TSi: CDA-9855, TS-D1720C, MRV-F345, MRD-M605, SWX-1043D in .54 net cubes sealed
    Resident Jeep Expert, Mother Fucker
  7. #37
    jockhater2's Avatar
    Sep 2011
    Saukville, WI
    2,598
    34 Post(s)
    Quote Originally Posted by ejschultz View Post
    So one speaker per channel is required to use the full range amps crossovers effectively. Unless I hook up two of the same size speakers then I can share the channel and still use the full range's crossovers.
  8. #38
    mlstrass's Avatar
    Jul 2006
    Illinois
    9,576
    12 Post(s)
    You can run as many speakers as you want per channel, assuming they all need the same xover point/slope...
  9. #39
    jockhater2's Avatar
    Sep 2011
    Saukville, WI
    2,598
    34 Post(s)
    Quote Originally Posted by mlstrass View Post
    thank you for that. Ok. So don't mix tweets with mids.
    And impedance has to be the same. correct?
  10. #40
    jockhater2's Avatar
    Sep 2011
    Saukville, WI
    2,598
    34 Post(s)
    Keep in mind that I want more power than I need, in-case I want to add more speakers in the future. Because If I am going to replace my coaxial's...I might just keep them and add components to the doors. I have plenty of space in my door cards to add more door speakers. And I don't see the point in just tossing the coaxial's.
    I am personally trying to find broken ones as I have a friend who fixes amps. And I want a quality power house.
    I will bold the ones that I think look really nice.
    But some of these aren't that much more than a broken one would cost to buy and get fixed.
    So far. The crescendo seems like the best option for me. And $300 plus doesn't seem bad to me at all. Otherwise those TF t1000-4 if I can talk the guy down.
    But give me your opinions guys.
    Do me a favor. And just quote this list and delete the ones that you say no too. Remember. I am looking for decent power so I have room to upgrade if I want. I prefer to over kill my projects.
    @quackhead ; @matt_bennett05 ; @VWGolfMKVI ; @goingdef ; @RAM_Designs ; @mlstrass ; @av83 ;
    Phoenix Gold Xenon 200.4
    Precision Power P900.4 145W x 4, 4 available
    Alto Mobile ADP304 4 channel class d
    Boston Acoustics GT42 4 Channel Amp
    old school Earthquake PA-4050c
    Monster 4 Channel
    Old school Phoenix Gold 6ch
    FS: Eclipse XA4000 4chan amp
    F/S Zapco 360.4
    this one looks real NICE
    Crescendo c1100.4
    I thought this one looked nice. But power seems a little weak. but there is where your opinion is needed.
    RARE! Blown JBL GTH400 6 channel - Car Audio Classifieds
    same with this one
    broken Kicker Impulse 356xi 6 channel - Car Audio Classifieds
    perfect. Its a power house and its broken.
    (2) Blown Rockford Fosgate T1000-4 - Car Audio Classifieds
    Memphis 16-MC4.125 4 channel - Car Audio Classifieds
    gs designs redline gs8000 beast 4ch 1ohm old school goodness - Car Audio Classifieds
    Nib dd s-4 - Car Audio Classifieds
    Soundstream REF4.920 - Car Audio Classifieds
    FS : Sundown Audio SAX 100.4 Great Price!! - Car Audio Classifieds
    Orion 8004 4 Channel Car Amplifier Broken Bad Rear Left Channel | eBay
    PPI Precision Power PCX 4125 Amplifier | eBay
  11. #41
    Jan 2007
    any wet spot i can find
    3,282
    50 Post(s)
    Crescendo c1100.4]
    "Bailout: Taking a trillion dollars from the people and giving it to the banks so the banks can loan it back to the people, at interest!"
  12. #42
    jockhater2's Avatar
    Sep 2011
    Saukville, WI
    2,598
    34 Post(s)
    Quote Originally Posted by quackhead View Post
    the crecendo?
    can you give me some 2nd, 3rd and such options?
    I'd like to if anything I found was decent and your opinions please.
    ---------- Post added at 01:53 PM ---------- Previous post was at 01:52 PM ----------
    Refurb Cadence United Series Vegas 4 Channel 1800 Watt Class AB Car Amplifier | eBay
  13. #43
    Jan 2007
    3,282
    50 Post(s)
    the crecendo?
    all of the amps you mentioned were decent..I loved the Eclipse for the x-over functions, decent power, the Crescendo is almost new, very good power and I believe their x-overs are ok too. The PPI new, excellent x-over and power...but I know you are leaning to class A/B..lemme put it this way, for A/B - Crescendo, Class D - Eclipse or PPI.
    Of course the RF 1000.4 would be beast mode, but do you really want to buy a broke amp?
  14. #44
    jockhater2's Avatar
    Sep 2011
    Saukville, WI
    2,598
    34 Post(s)
    I am not leaning towards an A/B. I'd rather have a class D full range. I am not too concerned with SQ. I mean. Come on. I run everything off the HU and I think it sounds great. I am clearly no audiophile.
    And yes. I'd rather buy a beast amp that is in rough shape or broken. Like I said. My buddy john can fix it. My exile 5k was bought broken. John fixed it for $175 and offers free repairs on it if I have any odd troubles. And He fixed my Us Amp AX3000DE for 125 that someone on ebay blew the crap out of.
    I PM'd the guy on the RF 1000.4 but it looks like his post has been inactive for a while.
    Also. I don't know if I will use the X-overs on the amp. I am unsure. Because I switch a lot between hip hop/rap and deathcore/metalcore/metal. So I use the EQ settings from my ipod because I switch between the genres so much.
  15. #45
    Jan 2007
    3,282
    50 Post(s)
    ****, I found one!...check this dude out.
    LANZAR Optidrive 2000 Watt 4 Channel Competition Class Mosfet Amplifier in Car Amplifiers | JR.com
+ Reply to Thread
  1. What the hell is this and how do I hook it up to my sub?
    By sue bee in forum Wiring, Electrical and Installation Help
    Last Post: 03-22-2009, 10:28 PM
  2. is this why?
    By mythyone in forum Subwoofers
    Last Post: 09-21-2008, 11:18 PM
  3. Can my 12" SX get more output by building a better box than this?
    By Basshead808 in forum Enclosure Design & Construction Help
    Last Post: 05-11-2006, 10:06 PM
