Page 2 of 2 FirstFirst 1 2
Results 16 to 21 of 21
Reload Thread: Running active and rear speakers?
  1. #16
    splwj47's Avatar
    splwj47 is offline CarAudio.com Veteran
    Aug 2011
    Great White North
    28
    2,674
    977 Post(s)
    Re: Running active and rear speakers?
    Quote Originally Posted by mlstrass View Post
    what is your reason for going active? Especially with a set of passive comps...
    his drivers are not a passive comp set. the mids and tweets were bought seperate. the tweets are not even offered in a passive comp set. and the mids and tweets are some of the highest end drivers cdt has.
    2003 JEEP Grand Cherokee
    HU- pioneer 80prs
    Front Stage- Tantric HD comps.
    FS Amp- B2 Quattro
    Sub Amp-B2 Zero1
    Subs- Tantric HDD 12's
    box - 4.5^3 32hz
  2. #17
    myjaja's Avatar
    myjaja is offline Audioque
    Sep 2006
    San Antonio, Tx Posts: 143,632 _____<^>*_*<^>_____
    3,655
    492 Post(s)
    Quote Originally Posted by Seraphim38 View Post
    while there are people above who have noted the importance of time alignment, I am sure that they are aware of the mechanical benefits of going active:
    When running a passive crossover, the amplifier stage has to push full bandwidth, from low bass to high treble frequencies, and has to push through the resistance of a crossover. With an active setup, the amplifier stage has several octaves less of frequencies to cover and doesn't have to push through a passive crossover network. The result should be much cleaner sound with less overall distortion and probably greater volume capability before the driver starts audibly distorting. From a power perspective, active amplification is absolutely the way to go. Time and phase alignment are also useful, but going active alone without TA is still quite beneficial.
    Thank you, that's exactly what I wanted to hear.
    Refs: sbcaprice305, mattmcss, systembumping, LeofromtheH, audiobahnuser18, stishdr, wcarson8911, jnoel, mr_kebo, 93 saturn sl2
    HU: Home stereo converted to dc
    Speakers: Stock
    Subs: 6 1/2 home sub
    Amp: off the stereo
    Wiring: extended power cord
    neon lights: Christmas lights duct taped to frame
  3. #18
    mlstrass's Avatar
    mlstrass is offline Shaggy DOA
    Jul 2006
    Illinois
    10,775
    5 Post(s)
    1264 Post(s)
    As mentioned before, run ALL the mids off one amp. That way you can control the bandpass xover for them. Run the tweeters off another amp, so they have the same HPF.
    Or you could do 2ch's for mids and 2ch's for tweeters. You will not have a perfect up front stage, but to many people that doesn't matter...
  4. #19
    seankurz's Avatar
    seankurz is offline Junior Member
    Feb 2013
    Tempe, AZ
    22
    3 Post(s)
    I had read somewhere that you can run active up front and also run speakers in the rear by using rca splitters on the front RCA outs and running those 4 channels into a 4 channel amp. then run the rear RCA outs >>> a separate amp>>>rear speakers, still leaving the sub RCA out open. Is this totally off? (i'm also new to active, trying to learn) pic attached
    [IMG][/IMG]
  5. #20
    seankurz's Avatar
    Feb 2013
    Tempe, AZ
    22
    3 Post(s)
    So like this? [IMG][/IMG]
  6. #21
    mlstrass's Avatar
    Jul 2006
    Illinois
    10,775
    5 Post(s)
    1264 Post(s)
    that will work, pretty much how my set up is, just that I have 14 amps....
  1. Replies: 4
    Last Post: 06-08-2007, 09:41 PM
  2. front and rear speakers
    By scrappy in forum Speakers
    Last Post: 05-23-2005, 01:47 AM
  3. Making custom front and rear speaker boxes??
    By flakko in forum Speakers
    Last Post: 08-15-2004, 05:50 PM
  4. front and rear speakers
    By sk24iam in forum Subwoofers
    Last Post: 04-03-2003, 08:24 PM
