Results 1 to 3 of 3
Reload Thread: Caraudio crossover for PA speakers?
    Joe89's Avatar
    Joe89 is offline Senior VIP Member
    Dec 2007
    Northern California
    268
    44 Post(s)
    I know this will not be the correct way to do things, however...
    I would like to listen to my Eminence Beta's and ST350's before I install them in my vehicle.
    I have some passive crossovers for Memphis PR 6.5" component speakers.
    I am aware that crossover points are impedance dependent, but given that the Memphis 6.5" speakers are 4ohm, and I can wire (2) Beta's in parallel to 4ohm, (same case for the Memphis tweeters and ST350's), will I be okay testing the speakers (with low wattage) in this manner? In my vehicle the speakers will be run with an active crossover.
    Edit: Just realized the receiver I am using to power these is only stable at 8ohm. Anyone have any ideas? Can a set of useable crossovers be found at Radioshack or Fry's for cheap?
    Edit2: I suppose I will turn this into an educational project and attempt to build my own passive xo's. http://www.parts-express.com/resourc...-crossover.cfm I will be following this guide. Now, I have to see if I can source the necessary capacitors, inductors, resistors, etc locally...
    Refs
    .....Realm of Excursion.....
    MajorPayne TEAM_HAVOC_SPL HexiBase
    .....Car Audio Forum.....
    Jybfan04 Jando86
    Seraphim38's Avatar
    Seraphim38 is offline Member
    Jan 2012
    WA
    87
    29 Post(s)
    Re: Caraudio crossover for PA speakers?
    ideas:
    The drivers themselves may be 8 ohms but you also have to account for the resistance of the crossover. Without getting into a lengthy post, you'll likely be fine for a short test. If you want to turn them into your new home theater speakers, that's different.
    TitoThePirate's Avatar
    TitoThePirate is offline Newb Nuthugger
    Feb 2012
    Milwaukee,Wi
    26
    456
    161 Post(s)
    do realize passive crossovers have a wattage limit. also! you can use pa equiptment in car enviroments and car audio and live enviroments. its just not always recommended.
  1. Help with crossovers for midrange speakers
    By 46panel in forum Speakers
    Last Post: 02-06-2011, 01:56 PM
  2. WTB Crossover for componet speakers
    By buzyao in forum Wanting to Buy (WTB) - Car Audio
    Last Post: 10-03-2009, 10:05 PM
  3. Different brands crossover for speakers?
    By silenkiller in forum Speakers
    Last Post: 02-28-2008, 12:46 PM
  4. one crossover for two speakers?
    By maldecido33 in forum Home Audio/Video
    Last Post: 07-22-2006, 02:32 PM
  5. Designing a crossover for a DIY speaker project
    By jaygeorge1979 in forum Home Audio/Video
    Last Post: 11-09-2005, 06:01 PM
