I think that 6 channel is a pretty nice bet. It is plenty of power. Keep in mind it's not a lot of power, it's not going to scream at you. But I think 100w @ mid-bass, 50w @ mid-range, and 50w @ tweeter, (all underrated at 12v), will be plenty of power to sound very nice. And as I'm sure you know, that's not a ton of power if you want to get really loud, but I don't think that is your goal with that gear. If it IS your goal though, I'd look into a stronger 4 channel for the tweets and mid-range, and a bridged 4 channel or beast 2 channel for the mid-bass. You know as well as any of us, if you want louder, you need more power. So if you just want a good sounding, decent output SQ set-up, you're set with that 6 channel. If you want to get loud, double your power.
As for the 3-way thing.... I'm not speaking from experience, but just from a lot of consideration, and what I read here.... I'd start off by getting an already built 3-way set, on the cheaper side... maybe used. And just use it to get experience with gains and T/A, and settings your crossover points, and you can play around with speaker locations. Keep in mind if you buy the set used, it's already lost it's new value, so you can sell it off for the same price you bought it for. Then once you have experience under your belt with it, sell those off, and piece together your affordable set from Madisound, PE, or DIYcable. And for what it's worth.... this is my dream mid-bass selection: DIYCable.com : Intro » Home » Exodus Anarchy »
Register To Reply
Bookmarks
