Page 2 of 3 FirstFirst 1 2 3 LastLast
Results 16 to 30 of 45
Reload Thread: Going Active
  1. #16
    keep_hope_alive's Avatar
    keep_hope_alive is offline Acoustics Engineer keep_hope_alive is a Supporting Member of the forum!
    May 2007
    Quad Cities, IL
    7,082
    28
    48 Post(s)
    1502 Post(s)
    Re: Going Active
    off-axis means you are closer to 90 degrees relative to the centerline of the woofer - i.e. it is aimed away from you.
    on-axis means you are closer to centerline of the wooofer - i.e. it is aimed at you.
    all speakers have substantial high frequency roll-off when off-axis.
    you can put them in the dash (and lose visibility as well as cut the dash) or you can put them in the kicks. you have plenty of kick space once you relocate some of that crap down there (behind the kick panels). i vote kicks - plenty of room to make them work and give the woofers lots of airspace so the f3 point is lower. also, you improve ITD so you are less reliant on T/A
    got a question? shoot me a PM. Matthew 6:9-15 - YouTube Channel: https://www.youtube.com/channel/UCkYUo2EShW9lgtrfXiDvLNQ/videos
    2014 Accord build log: http://www.caraudio.com/forums/car-audio-build-logs-cars-trucks-suvs/608637-2014-accord-sport-sq-build-keep_hope_alive.html
    2001 Accord build log: http://www.caraudio.com/forums/car-audio-build-logs-cars-trucks-suvs/536049-2001-accord-ex-sedan-its-long.html
    My 1966 MGB: http://www.mgexp.com/journal/keephopealive
    Fix Photobucket Image Loading ------> https://addons.mozilla.org/en-US/firefox/addon/photobucket-fix/ <------
  2. Thanks West thanked for this post
  3. #17
    West's Avatar
    West is offline Banned
    Jan 2012
    Oliver Springs, TN
    3,703
    1406 Post(s)
    Re: Going Active
    Quote Originally Posted by keep_hope_alive View Post
    How do I give the woofers more air space? I should leave the 6.5'' in the door correct?
  4. #18
    May 2007
    Quad Cities, IL
    7,082
    28
    48 Post(s)
    1502 Post(s)
    Re: Going Active
    there is no shortage of airspace in the door - there is actually too much since the volume greatly exceedes the air spring compliance air volume resulting in a "free air" configuration.
    when you're in there, i recommend adding PVC encased fiberglass batt in the cavity (see build log), that really did wonders for me.
  5. Thanks West thanked for this post
  6. #19
    Alrojoca's Avatar
    Alrojoca is offline Senior VIP Member
    Jan 2012
    USA West Coast
    274
    71 Post(s)
    Re: Going Active
    Just my 2 cents here, you probably need an extra 2 channel amp to drive the tweeters and mids separate for an better active set up or drive the 6 1/2 inch drivers with a separate 2 ch amp to take full advantage of the hat components and the PR99RS.
    The tweeters and mids should be pointing towards the center between the 2 front seats for a better stage. Focals may sound better if highs are close to mids and even the 6 inch drivers.
    The hat one not so much. In any situation your head unit has plenty Of bands, like 32 bands per ch for EQ, and a time delay, the time delay will help correct any on axis or off axiss or any issues related to the distance between the drivers with any set you pick.
    Have fun! And good luck!
  7. Thanks West thanked for this post
  8. #20
    West's Avatar
    Jan 2012
    Oliver Springs, TN
    3,703
    1406 Post(s)
    Re: Going Active
    Quote Originally Posted by Alrojoca View Post
    Would a Mcc406m (mcintosh-6channel) not cut the cheese for an amp?
  9. #21
    West's Avatar
    Jan 2012
    Oliver Springs, TN
    3,703
    1406 Post(s)
    Re: Going Active
    Does anyone think ti would help if I used the McIntosh 4 channel (bridged for the 6.5'') and the Mc 6 channel (for the mids and tweeter, in bridged mode for 4 channel operation)? Would there be a big advantage there? I already have the amps, so whatever would work best is the way I'll go... I think that would be a TON of power lol
    Even if it means upgrading the alternator.
  10. #22
    West's Avatar
    Jan 2012
    Oliver Springs, TN
    3,703
    1406 Post(s)
    Re: Going Active
    Any thoughts?
  11. #23
    West's Avatar
    Jan 2012
    Oliver Springs, TN
    3,703
    1406 Post(s)
    Re: Going Active
  12. #24
    West's Avatar
    Jan 2012
    Oliver Springs, TN
    3,703
    1406 Post(s)
    Re: Going Active
    @av83 ; @pro-rabbit ;
    What do you think?
  13. #25
    Jan 2007
    any wet spot i can find
    3,282
    1188 Post(s)
    Re: Going Active
    Quote Originally Posted by West View Post
    didn't read the thread, but you are wanting to bridge the 4ch on a pair of 6.5 mids and use a 6ch for another set of mids and a set of tweets?
    "Bailout: Taking a trillion dollars from the people and giving it to the banks so the banks can loan it back to the people, at interest!"
  14. #26
    West's Avatar
    Jan 2012
    Oliver Springs, TN
    3,703
    1406 Post(s)
    Re: Going Active
    Quote Originally Posted by quackhead View Post
    yup the 4 channel is (100x4 @ 4ohm - bridged would be 200x2 @ 4) - 6.5 mids
    the 6 channel would be (50x4 @ 4 + 100x2 @ 4 so bridging the 50's would be 100x4) - 3.5'' mids and a pair of tweets
    Would it be worth doing? Or should I just use the 6 channel as is w/o the 4 channel?
  15. #27
    av83's Avatar
    av83 is offline CarAudio.com Veteran
    Mar 2012
    Illinois
    3,031
    13 Post(s)
    1335 Post(s)
    Re: Going Active
    What do you think?
    I think that you are going to have a very, very loud 3way setup, is what i think, lol. ...I have 100-120 rms going to each tweeter, and each mid, and its stupid loud. I'm pretty darn happy with what I'm getting out of my simple 5 speaker system, so I'm very hesitant to give you advice. I have different expectations than you, too. I sought sql on a budget, and found it. Your goals are different than mine.
    80prs
    SoundQubed 6.5 Pro's DD T2 Tweeters / new 4 Chan coming / new subs coming / DC Audio 5.0K
    Singer 310 6 phase 2 runs of Monster Cable 1/0 / Exide g78 AGM under hood and XS D3100 in rear
    Plenty of deadener. CCF and fiberglass insulation in doors... thanks to the advice of keep_hope_alive they sound AWESOME! :-)
  16. Likes West liked this post
  17. #28
    West's Avatar
    Jan 2012
    Oliver Springs, TN
    3,703
    1406 Post(s)
    Re: Going Active
    Quote Originally Posted by av83 View Post
    I like it loud, but not REALLY loud lol. Just was wondering if the sound quality would be better (maybe some more headroom?) dont know...
  18. #29
    av83's Avatar
    Mar 2012
    Illinois
    3,031
    13 Post(s)
    1335 Post(s)
    Re: Going Active
    are you sure about those specs? bridged output is usually closer to double the 2 ohm specs per channel. bu teven if it is what you say it is, that a shitload of power... Better get some speakers that can handle it if you plan on using all that juice.
    80prs
  19. Likes West liked this post
  20. #30
    av83's Avatar
    Mar 2012
    Illinois
    3,031
    13 Post(s)
    1335 Post(s)
    Re: Going Active
    I'd do it
    80prs
  1. Considering going active..
    By mr Tibbs in forum General Discussion
    Last Post: 10-25-2005, 12:35 AM
  2. should i go active??
    By iceteebone in forum Speakers
    Last Post: 07-27-2005, 08:28 PM
  3. Going active and using an EQ
    By jacko in forum General Discussion
    Last Post: 07-25-2005, 11:30 PM
  4. going active
    By audiolife in forum Speakers
    Last Post: 06-21-2005, 03:59 AM
  5. Going Active....
    By ngsm13 in forum General Discussion
    Last Post: 04-04-2005, 04:22 PM
