Page 2 of 2 FirstFirst 1 2
Results 16 to 24 of 24
Reload Thread: Tweeter recommendations to pair with Hybrid Clarus Mids
  1. #16
    hari-bhari's Avatar
    hari-bhari is offline Senior VIP Member
    Mar 2005
    atl
    217
    10 Post(s)
    Re: Tweeter recommendations to pair with Hybrid Clarus Mids
    been reading a lot and hearing good things about
    Vifa XT25
    Seas Neo
    Peerless HDS
  2. #17
    zako's Avatar
    zako is offline CarAudio.com Elite
    Jan 2011
    TX
    1,347
    238 Post(s)
    Why no mentions of the Alpine Type-X tweeter? Supposedly it's one of the best for the money. It's a popular tweeter in active setups, so its frequently traded. Having said that, the Seas Neo Aluminum should fit the bill for everyone except those looking for super high fidelity output. It's a crisp but smooth tweeter that will allow to be high passed at relatively low frequency, if necessary. A pair costs under $100.
  3. #18
    zako's Avatar
    Jan 2011
    TX
    1,347
    238 Post(s)
    Quote Originally Posted by hari-bhari View Post
    Recently went active on my Hybrid Clarus set, sourced from a CarPC with EQ, time alignment, phase, and crossover adjustments, powered with a DSC4125 (125 RMSx4) soon to be swapped for a JL or Cadence 5 channel.
    By the way, what high pass frequency do you use on the tweeter? The stock crossovers use somewhere in the 5000-6000Hz range. Make sure you stay there.
  4. #19
    dragnix's Avatar
    dragnix is offline LXIX
    Dec 2006
    Socal cuz i'm So cool
    19,730
    682 Post(s)
    Quote Originally Posted by zako View Post
    Why no mentions of the Alpine Type-X tweeter? Supposedly it's one of the best for the money. It's a popular tweeter in active setups, so its frequently traded. Having said that, the Seas Neo Aluminum should fit the bill for everyone except those looking for super high fidelity output. It's a crisp but smooth tweeter that will allow to be high passed at relatively tweetslow frequency, if necessary. A pair costs under $100.
    I do believe the type x tweets are the xt25 from vifa
  5. #20
    Jroo's Avatar
    Jroo is offline CarAudio.com Elite
    Feb 2007
    richmond virginia
    509
    90 Post(s)
    I believe this is going to be as close to the type x tweeter as you will find.
    Madisound Speaker Store
    Ive never truly understood all the differences in the versions, but I think several used this one and said it was basically like what came in the type x seperates. I love my type x tweeters, but Im not sure how much you will gain or loss by going with them. I thought the Hybrid tweets were supposed to be very laid back. Maybe try getting them much more on axis with a tweeter cup or something?
  6. #21
    keep_hope_alive's Avatar
    keep_hope_alive is offline Acoustics Engineer keep_hope_alive is a Supporting Member of the forum!
    May 2007
    Quad Cities, IL
    7,082
    28
    48 Post(s)
    1502 Post(s)
    you can run the Clarus mids up to 10k, but if they aren't pointed at you you won't hear it.
    got a question? shoot me a PM. Matthew 6:9-15 - YouTube Channel: https://www.youtube.com/channel/UCkYUo2EShW9lgtrfXiDvLNQ/videos
    2014 Accord build log: http://www.caraudio.com/forums/car-audio-build-logs-cars-trucks-suvs/608637-2014-accord-sport-sq-build-keep_hope_alive.html
    2001 Accord build log: http://www.caraudio.com/forums/car-audio-build-logs-cars-trucks-suvs/536049-2001-accord-ex-sedan-its-long.html
    My 1966 MGB: http://www.mgexp.com/journal/keephopealive
    Fix Photobucket Image Loading ------> https://addons.mozilla.org/en-US/firefox/addon/photobucket-fix/ <------
  7. #22
    hari-bhari's Avatar
    Mar 2005
    atl
    217
    10 Post(s)
    crossing at 5800hz at 12db right now.
    i dont know if the clarus mids play up to 10k... i spoke directly with bob morrow at hybrid and he said their upper limit was around 6k. i'll look into the seas neo and vifa xt25... although i have no idea how im going to mount a ring type tweet in my door.
  8. #23
    Why So Cereal?'s Avatar
    Why So Cereal? is offline Invisible Cereal
    Sep 2010
    Drowning in milk
    7,403
    1555 Post(s)
    any benefit to letting my mids play higher up? i was thinking if the new tweets play lower, i can go ahead and change my crossover to the 3-4k range and raise up my soundstage some.
    The main benefit to having your mids play higher is that you'd try not to have a shift between drivers in some of most sensitive frequencies or in the vocal range. But, thats virtually impossible when using a 6.5 b/c without it being aimed at you, beaming will really ruin your FR at those frequencies until your tweeter picks up.
    If you're looking to cross lower, I'd definitely say go with the Seas Neos. The LPGs are very nice tweeters but in my experience don't like to go below 4khz AT ALL. Crossing lower can help raise the stage in some cases. Its really a matter of preference and how your car is setup.
    I'd say for ease of use or experimentation purposes, go with the Seas Neo tweeters. They are some of the best reviewed tweets for the money and they have the ability to be crossed pretty low. Coupled with the fact that your HAT mids can play out to 5 or 6khz, you have a lot a room to play around with diff. xover points and see which one gives u the best mix of proper tonality and stage height.
  9. #24
    hari-bhari's Avatar
    Mar 2005
    atl
    217
    10 Post(s)
    Quote Originally Posted by princ3cmo View Post
    i believe i'm sold, sir. ill give it a shot. worse case i revert back to my hybrid tweets and sell/return these. thanks!
  1. What mids to pair with my Vifa XT25s?
    By LaserRed38 in forum Speakers
    Last Post: 01-10-2010, 09:41 PM
  2. Mids to pair with Rainbow CAL 25's
    By Kyle! in forum Speakers
    Last Post: 06-03-2009, 03:40 PM
  3. Right tweeter to mate with Hybrids?
    By syvlvr in forum Speakers
    Last Post: 09-07-2007, 03:32 PM
  4. Replies: 3
    Last Post: 02-08-2007, 02:17 PM
  5. Tweeters to pair with XXX mids.
    By valant_94gt in forum Speakers
    Last Post: 06-15-2006, 09:06 PM
