Page 1 of 2 1 2 LastLast
Results 1 to 15 of 26
Reload Thread: Should I run 4 or 8 ohm mids?
    _Vince's Avatar
    _Vince is offline Member
    Jul 2009
    New Orleans, LA
    59
    13
    13 Post(s)
    What's up CA members? I'm working on fiberglassing my doors and I want to run Sundowns: (1) 8", (2) 6.5", & (1) tweeter per door on a Sundown 100.4
    I'm stuck between running these parallel:
    all 8 ohm speakers at 2.66ohms
    all 4 ohm speakers at 1.33ohms
    8ohm 8" & 4ohm 6.5" 1.60ohms
    I'm running active, so tweeter wouldn't matter. So if someone can tell me the benefits and downfalls of running the above options, that'll be great.
    duanebro's Avatar
    duanebro is offline CarAudio.com Elite
    Oct 2011
    Grand Blanc, MI
    561
    74 Post(s)
    Re: Should I run 4 or 8 ohm mids?
    Less power from the amp at 8 ohms, other than that, not much.
    I am lost at why you want to use the size and number of speakers you listed.
    HU - Pioneer
    Front Stage - Old school MB Quartz run off a JL e2150
    Rear Stage - Stock - well one works, LOL
    Sub - Tang Band 740C in between the front seats
    Sub Amp - A tiny Kenwood. - because it fits under the seat.
    Total Spent on everything $50.
    _Vince's Avatar
    Jul 2009
    New Orleans, LA
    59
    13
    13 Post(s)
    Quote Originally Posted by duanebro View Post
    Yeah, but how loud will it be with all speakers at 8ohms?
    I'm making speaker pods for my doors and the maximum room I have without tremendously cutting the doors is 9". I also wanted to add some more midrange/bass to even out my 6 SA12s
    Rich B's Avatar
    Rich B is offline CarAudio.com Veteran
    Oct 2006
    *under the rainbow*
    6,504
    14
    235 Post(s)
    Is the 8" going to be wired to the same amp as the 2x 6.5", and what kind of amp is it?
    _Vince's Avatar
    Jul 2009
    New Orleans, LA
    59
    13
    13 Post(s)
    Quote Originally Posted by Rich B View Post
    Yes, I was going to run all the speakers parallel to a Sundown 100.4
    TreyE's Avatar
    TreyE is offline CarAudio.com Veteran
    Apr 2006
    Tampa
    3,843
    2 Post(s)
    187 Post(s)
    5ohms
    2011 Honda Accord Coupe
    ---Pioneer AVH-x3700BS---Seas Neo H1396---Silver Flute 6.5---05 RE XXX 12---FSD 1600D & 85.4---Knu Wiring---MurderMat Deadener
    Build: http://www.caraudio.com/forums/car-audio-build-logs-cars-trucks-suvs/618553-2011-accord-coupe-rims-suspension-idmax-silver-flute.html
    duanebro's Avatar
    Oct 2011
    Grand Blanc, MI
    561
    74 Post(s)
    Quote Originally Posted by _Vince View Post
    You will have half as much power at 8 ohms, so 3 db less. Could you fit two 8"s and one 6.5? Or depending on the speakers and what frequencies you want to use them at going with a smaller mid... 6.5" speakers can start to "beam" around 1500-2000 Hz iirc. There is more to look at than ohms....
    HU - Pioneer
    Below20hzonly's Avatar
    Below20hzonly is offline CarAudio.com Elite
    Feb 2012
    East Grand Forks, MN
    897
    274 Post(s)
    wouldnt you want to run the 8" at 4 ohms and the other speakers at 8?
  9. #9
    fasfocus00's Avatar
    fasfocus00 is offline doITdaWHITEwayORdoITtwice
    Jun 2007
    New Orleans, LA
    5,618
    3 Post(s)
    459 Post(s)
    i'd do the 8" in a kick panel, the 2 6.5" in the door and the tweeter in the door or the pillar. 8Ω and 4Ω have no real difference, it'll depend on what you want your final Ω load to be at. example I have 2 6.5" mids in each door, they are 4Ω each so I can get a 2Ω load on each channel. just personally preference I'd get another 2 channel amp and run just the 8" off of that and use that 4 channel to run your 6.5" and tweeter.
    Here is my feedback Thread: http://www.caraudio.com/forum/showth...ght=fasfocus00
    "If you ain't cheatin', You ain't trying"
  10. #10
    VWBobby's Avatar
    VWBobby is offline PG and SS nuthugger
    Jul 2010
    Nibiru
    36
    1,377
    170 Post(s)
    If you wanted to, you could run a "semi" active setup.... run the 8" speakers from 120hz on down bridged on the rear channels. Run the other speakers on the front channels in stereo from 120hz on up, HPF.
    '65 VW Bus
    MA Hippo 122, (2) Aura Sound 8's, (2) SoundStream 6.5 coax, (2) Alpine Type-S 6x9's [rear fill], MBQ DSC1500.1D, RF 501X
    '12 Nissan Altima - Bone Stock - Sounds good, but adding subs soon.
    '02 BMW 330xi (AWD coupe), every option - SOLD
  11. #11
    Rich B's Avatar
    Oct 2006
    *under the rainbow*
    6,504
    14
    235 Post(s)
    8" at 8ohms, the two 6.5" at 4ohms.
    Series the two 4ohm 6.5" to an 8ohm load, then parallel the 8ohm 8" with the two 6.5" already in series at 8ohm and you'll end up with a 4ohm load at the amp.
  12. #12
    duanebro's Avatar
    Oct 2011
    Grand Blanc, MI
    561
    74 Post(s)
    Just so I understand - each size of speaker will have its own channel? And the tweeters will be on another amp?
    HU - Pioneer
  13. #13
    _Vince's Avatar
    Jul 2009
    New Orleans, LA
    59
    13
    13 Post(s)
    Time to catch up with the posts
    I can fit 2 8" and 1 6.5", will just have them flat against the panel instead of centering.
    Quote Originally Posted by fasfocus00 View Post
    Yeah, I know it's about the final impedance but the individual impedance and how I wire it will determine the final impedance (right?). and I wanted to get a separate amp for the 8"s but that'll have to come later on.
    This is actually what I wanted to do, wasn't sure if it was going to work or not.
    no, tweeters will have it's own channel. and if it's okay to run the speakers like the reply above this one, than I want to run it like that.
  14. #14
    _Vince's Avatar
    Jul 2009
    New Orleans, LA
    59
    13
    13 Post(s)
    Nothing here, double posted
  15. #15
    keep_hope_alive's Avatar
    keep_hope_alive is offline Acoustics Engineer keep_hope_alive is a Supporting Member of the forum!
    May 2007
    Quad Cities, IL
    7,082
    28
    48 Post(s)
    1502 Post(s)
    it's not active if the 6.5's and 8's are on the same channel. and it is not advisable to give all 3 the same signal. having three speakers playing the same signal - yet each a different distance from your head will sound weird and poor. the effect is called comb filtering - a form of phase interference. you want to bandpass the 8" to handle midbass only. then let the 6.5's handle midrange - of which you only want 1 mid per side.
    if your question is if you should run two channels of the sundown at 1.33 ohms or 2.66 ohms, i vote the latter to make the load easier on the amp. later, when you have enough amp channels to do what you ultimately want, having all 4 ohm drivers is fine. but the real issue is that what you are planning to do is flawed. you're welcome to try and find out for yourself. maybe you'll like it. hell, people like Bose.
    running tweets active isn't gaining much. you don't need to T/A tweeters. you just want level control and crossover flexibility. you run tweets active when you have spare amps channels to play with.
    i would re-work your plan. run the tweeters off a passive crossover on the same channels as one 4 ohm 6.5" dedicated for midrange. then run a 8" midbass off the other channels, bandpass. this is a tried method that works well. when you have 6 amp channels, then run the various speakers individually.
    lastly, you don't want mids and midbass sharing the same airspace. the midbass will pressurize the mid (out of phase) and distort it.
    more speakers mounted on a door panel looks neat, but sounds quite poor. you want one driver producing midrange per side. you can double up on midbass drivers since the wavelengths are long enough that phase interference isn't as much of an issue when they are side-by-side.
    my buck-o-five
    got a question? shoot me a PM. Matthew 6:9-15 - YouTube Channel: https://www.youtube.com/channel/UCkYUo2EShW9lgtrfXiDvLNQ/videos
    2014 Accord build log: http://www.caraudio.com/forums/car-audio-build-logs-cars-trucks-suvs/608637-2014-accord-sport-sq-build-keep_hope_alive.html
    2001 Accord build log: http://www.caraudio.com/forums/car-audio-build-logs-cars-trucks-suvs/536049-2001-accord-ex-sedan-its-long.html
    My 1966 MGB: http://www.mgexp.com/journal/keephopealive
    Fix Photobucket Image Loading ------> https://addons.mozilla.org/en-US/firefox/addon/photobucket-fix/ <------
  1. Should I run my subwoofers at 2 ohm or 1 ohm?
    By Xanthous in forum Subwoofers
    Last Post: 10-11-2010, 12:30 AM
  2. Should i Run 4 ohm or 2 ohm loads?
    By RandyShaw in forum Amplifiers
    Last Post: 10-12-2007, 09:31 AM
  3. Should I run @ 1 or 4 ohms?
    By DarrenE46 in forum Amplifiers
    Last Post: 10-15-2004, 12:05 AM
  4. Infinity perfect, should I run 2 or 4 ohms
    By ecko3740 in forum Subwoofers
    Last Post: 02-16-2004, 08:19 PM
  5. should I go 2 ohms, or 4 ohms with speakers
    By spmachina in forum Subwoofers
    Last Post: 04-27-2002, 01:41 AM
