Page 2 of 3 FirstFirst 1 2 3 LastLast
Results 16 to 30 of 36
Reload Thread: Missing bass. Last heard in stock Honda speakers.
  1. #16
    Jan 2007
    any wet spot i can find
    3,282
    1188 Post(s)
    Re: Missing bass. Last heard in stock Honda speakers.
    Quote Originally Posted by Needforsound View Post
    Thanks for the reply audiobaun!
    I had no intention of adding an amp or sub. I just wanted to straight-up replace the four stock speakers, and was told the Alpines would be a vast audible improvement. But now my bass is cut off, and the sound is much worse than the old stock Honda speakers. What is wrong here? Is it a possible installation issue? They sound like 3 inch speakers.
    You took out speakers that were specifically designed to operate in your car and to sound their best with the factory power applied. You replaced them with speakers designed to fit a particular hole in the door. This happens every day. You will probably need a subwoofer to replenish the extended lower frequency response you lost by removing the factory speakers. The speakers you bought are obviously not capable of reproducing the sound you are missing. The trade off is that the Alpines will handle more power at the frequency range they are designed to play in.
    And yes, there is still a possible installation issue. It is possible you have a speaker out of phase, which will cause loss of output and frequency response.
    "Bailout: Taking a trillion dollars from the people and giving it to the banks so the banks can loan it back to the people, at interest!"
  2. #17
    Needforsound's Avatar
    Needforsound is offline Junior Member
    Jul 2012
    FL
    4 Post(s)
    The stock speakers were destroyed to make mounts for the new.
    Let me be clear: I am NOT expecting gut-rumbling low end. But right now, the bass is cranked to the max (even turned the treble down), and I cannot get anything out of these things bass-wise. Kick drums sound like slapping meat. I'm an audio engineer and I know what can be done with 70hz, so something is definitely not right here.
    I will talk to the shop that sold and installed these. $320 (installed) was supposed to vastly improve my sound, running off the stock head unit. I am looking to this community for advice on how to best handle this fairly with the shop, and how to approach them.
  3. #18
    Jan 2007
    3,282
    1188 Post(s)
    Go to them and tell them you suspect you have a wiring issue because it sounds like you have a speaker or two out of phase.
  4. #19
    supermaxx123's Avatar
    supermaxx123 is offline CarAudio.com Elite
    Aug 2009
    I.E.
    1,833
    47 Post(s)
    Sadly most shops will tell you anyhing to sell their products. If they had to destroy your old speakers to mount new ones?? Already something sounds wrong. Maybe they were mounted with rivets, if so I can understand they wanted to do it quick. Maybe it is an installation issue. I'm also guessing the new alpines need more power than your old speakers did, still even then I don't see why there would be no bass at all. Could be a phase issue but we could not tell you exactly with the info provided.
    I'm surprised they didn't test it right there in front of you soon as they installed them. Not sure how your shop handles their installs and expectations so it'd he hard to recommend what to tell them other than there is no bass.
    Bought from: tc3k101, vitveet, chico305, pieper88, Toxic Tuan, rusty_armadillo, tristanmay
    Traded with: modskwod, jmkanek
    Sold to: smd4life, AQHDC3, fastfocus00
  5. #20
    Jan 2007
    3,282
    1188 Post(s)
    true, but if you get on their *** and have them double check the install, and it still sounds like poo afterwards, then you KNOW . 1st eliminate the possibility of an install mistake.
  6. #21
    Jul 2012
    FL
    4 Post(s)
    Thanks everybody!
    I was the last pickup of the day; everybody was gone while I was listening in the parking lot. Since the whole shop was eager to bolt for the evening, perhaps it was a hasty wiring job after all. Either way, if they make it right I have no problem.
  7. #22
    Fiendstolemyamp's Avatar
    Fiendstolemyamp is offline Call of the Wintermoon
    May 2011
    GA
    793
    58 Post(s)
    If you want to get decent midbass out of aftermarket speakers you have to take the time to do a proper install. I bet the shop just screwed them into where the stocks were mounted & they aren't sealed off properly, etc.
    I use gain as a volume control.
  8. #23
    BrownVanMan's Avatar
    BrownVanMan is offline CarAudio.com Veteran
    May 2009
    Minneapolis MN
    2,018
    1 Post(s)
    331 Post(s)
    The frequency response only goes to 70hz. A buddy had the 5x7s and did what your saying. They aren't designed for bass
  9. #24
    LosIsATool's Avatar
    LosIsATool is offline CarAudio.com Veteran
    Apr 2011
    Pensacola, Florida
    37
    17,724
    107 Post(s)
    7517 Post(s)
    You got screwed. You cant just replace stock speakers with better ones, it dont work like that on head unit power. Of course they are going to tell you what you want to hear. You can support your local shops all you want but dont go in there stupid or they will shaft you.
    2014 Ford Fusion SE 2.0T
    JBL MS-8
    DD M1c, DD SS4A
    IDQ12v4 1.8cu sealed
    Hertz HT28
    Hertz HV165XL
    Knuconceptz OFC, Custom fit Soundrive RCAs.
  10. #25
    keep_hope_alive's Avatar
    keep_hope_alive is offline Acoustics Engineer keep_hope_alive is a Supporting Member of the forum!
    May 2007
    Quad Cities, IL
    7,080
    28
    47 Post(s)
    1502 Post(s)
    the issue here is not the speakers. it's extremely common.
    the reason? seals.
    no, not the kind that get eaten by sharks as narrated by Sigourney Weaver.
    the kind of seals created with perfectly crafted mounts and foam weatherstripping.
    what you need to do is recreate the factory seals. these exist in two main locations.
    1. between the woofer and the metal.
    2. between the woofer and teh plastic door panel grill opening.
    #2 is usually missed.
    the door panel acts as the front baffle of the enclosure since the door metal has huge holes in it. the rear wave from the speaker combines with the front - cancelling it out.
    midbass/bass is all about seals and isolating front from rear.
    got a question? shoot me a PM. Matthew 6:9-15 - YouTube Channel: https://www.youtube.com/channel/UCkYUo2EShW9lgtrfXiDvLNQ/videos
    2014 Accord build log: http://www.caraudio.com/forums/car-audio-build-logs-cars-trucks-suvs/608637-2014-accord-sport-sq-build-keep_hope_alive.html
    2001 Accord build log: http://www.caraudio.com/forums/car-audio-build-logs-cars-trucks-suvs/536049-2001-accord-ex-sedan-its-long.html
    My 1966 MGB: http://www.mgexp.com/journal/keephopealive
    Fix Photobucket Image Loading ------> https://addons.mozilla.org/en-US/firefox/addon/photobucket-fix/ <------
  11. Likes quackhead liked this post
  12. #26
    Jan 2007
    3,282
    1188 Post(s)
    Quote Originally Posted by keep_hope_alive View Post
    the reason? seals.
    Thank you for taking this to the next level of understanding....and this too falls on the installers for an improper install, if they did not replicate the OEM install using the aftermarket speakers.
  13. #27
    Popwarhomie's Avatar
    Popwarhomie is online now Team Lethal Pressure
    Jan 2010
    Jacksonville, FL
    5,033
    59 Post(s)
    2296 Post(s)
    Go back to the shop and tell them your issues..
    2016 Focus ST - Rockford DSR1 / PPI 900.4 / Silverflute 6.5" mids / Massive CT2 tweeters /Sundown Xv2 15"/ Taramps DSP3k / Stinger Roadkill / KNU wiring / Northstar SMSAGM80 /
    2010 Focus coupe [email protected]
    Pioneer 80prs /(8) FU Audio 750 12"s / (4) FSD 2600s / (1) FSD 125.4 / (1) FSD 85.4 / (4) Crescendo UN-10" mids / (4) Crescendo FT1 tweeters / Stinger Roadkill / 2/0 EB flex wire / (5) Powerware 90AH batteries / DC 270XP Alt /
    https://www.youtube.com/popwarhomie
    Quote Originally Posted by BOOMINGRANDPA View Post
    I have no idea what i'm talking about.
  14. #28
    Kangaroux's Avatar
    Kangaroux is offline I put on
    Dec 2010
    Maine
    9,902
    3 Post(s)
    1624 Post(s)
    OP, goto lowes/HD and pick up 10' of some nice 3/4" weatherstripping for like 4 bucks. Then head on over to audiotechnix.com and grab some 60 mil b-stock for like $58 shipped.
  15. #29
    Jan 2007
    3,282
    1188 Post(s)
    Quote Originally Posted by Kangaroux View Post
    lol...yea, do this AFTER you ream some installer ***!
  16. #30
    May 2007
    Quad Cities, IL
    7,080
    28
    47 Post(s)
    1502 Post(s)
    most installers won't go through the extra effort. it's $60/hr for custom work like sealing doors. if you go back and want additional seals, expect to pay for it.
    your best bet is to DIY. this stuff is easy.
    here is a thread i've added a lot of door speaker installation pics to
    Installing door speakers and sound deadening and more - Honda Accord Forum - Honda Accord Enthusiast Forums
    this is what i mean about seals and foam:
  17. Thanks shpatb thanked for this post
  1. stock system speaker problem in friends car.
    By theothermike in forum General Discussion
    Last Post: 01-20-2008, 01:13 AM
  2. Tight Bass for ROCK in an acura rl w/stock bose
    By chrisNSX in forum Subwoofers
    Last Post: 09-17-2006, 02:47 AM
  3. can i put speakers in stock location?
    By DbRufus1234 in forum Wiring, Electrical and Installation Help
    Last Post: 10-25-2004, 03:53 AM
Tags for this Thread
