Page 3 of 3 FirstFirst 1 2 3
Results 31 to 37 of 37
Reload Thread: Rear Speakers not as loud as fronts?
  1. #31
    Jan 2007
    any wet spot i can find
    3,282
    1188 Post(s)
    Re: Rear Speakers not as loud as fronts?
    Quote Originally Posted by est;8086629W
    Ok.
    Contrary to what you signature says. Read the manual and find out which of the wires from the HU are powering the speakers.
    Switch the fronts and rears. (Front left plus into rear left plus, front left minus into rear left minus should be 8 wires total to switch)
    Not trying to be mean there, sorry if it came out that way. There are good reasons to read manuals lol. Also do a google search on the wire harness you are using to figure out the colors. You can always buy a new wireharness from Advance auto or autozone in you cannot find the color charts.
    am I the only one who has an owners manual or two somewhere in the stack of bathroom reading material?
    "Bailout: Taking a trillion dollars from the people and giving it to the banks so the banks can loan it back to the people, at interest!"
  2. Likes Jaguar liked this post
  3. #32
    Jaguar's Avatar
    Jaguar is offline Senior VIP Member
    Jun 2012
    GA
    335
    2 Post(s)
    214 Post(s)
    Quote Originally Posted by West View Post
    Read the manual and find out which of the wires from the HU are powering the speakers. Switch the fronts and rears. (Front left plus into rear left plus, front left minus into rear left minus should be 8 wires total to switch).
    I edited the image to show where the only main set of wires on the back of the head unit are connected. Besides the subwoofer out, up there
    on top of the HU (in that photo) there are no "Front left plus into rear left plus, front left minus into rear left minus" connected at all.
    James 1:2-5 2 Count it all joy when you fall into various trials, 3 knowing that the testing of your faith produces patience. 4 But let patience
    have its perfect work, that you may be perfect and complete, lacking nothing
    . 5 If any of you lacks wisdom, let him ask of God, who gives to all
    liberally and without reproach, and it will be given to him
  4. #33
    West's Avatar
    West is offline Banned
    Jan 2012
    Oliver Springs, TN
    3,703
    1406 Post(s)
    Quote Originally Posted by Jaguar View Post
    I edited the image to show where the only main set of wires on the back of the head unit are connected. Besides the subwoofer out, up there on top of the HU (in that photo) there are no "Front left plus into rear left plus, front left minus into rear left minus" connected at all.
    There are two wire harnesses that connect the outputs from that circled area to your car. One connects into the deck and is connected to an aftermarket wire harness which has a connection that is compatible to your vehicle.
    Step 1
    Go into your car and carefully disconnect the two wireharnesses from the cars stock wiring. It should be a white or black connection. Don't cut any wires at this point, simply disconnect the harness from the cars wiring and you may have to press down on the connector to be able to remove it. Bring it to a place where you can see the color of all the wires easily.
    Step 2
    Read the manual and determine which wires go where and switch the fronts and rears (speaker outputs) between the two wire harnesses by cutting them. Strip some of the wire on each end and connect them with wire connectors (avaliable at autozone, advanced auto) or at a bare minimum electrical tape. Leave all the other wires intact.
    Step 3
    Reconnect the deck and wireharnesses to the car and observe. Do all of this with the battery disconnected until you are testing the deck.
    If you are not comfortable doing this take it to a car place and replace the deck. I doubt you will be able to find a car audio place that will charge you a reasonable amount of money to trouble shoot this.
  5. Thanks Jaguar thanked for this post
  6. #34
    Jaguar's Avatar
    Jun 2012
    GA
    335
    2 Post(s)
    214 Post(s)
    @West thanks. Like I said more than anything the rear speakers sound, muffled as if they are not getting enough power. Since nothing has changed with the wiring, this sounds like an issue with the head unit. It could be the wiring or it could be from having the wires cramped together in the harness with the head unit that are the cause for the ''loss of power'' to the rears. I'm going to get it taken care of tomorrow. The people at one of the shops I go to know me, they won't charge anything to diagnose the problem. To fix the problem, sure. If Im lucky I will be able to get away without buying a new head unit.
  7. #35
    West's Avatar
    Jan 2012
    Oliver Springs, TN
    3,703
    1406 Post(s)
    @West thanks. Like I said more, than anything the rear speakers sound muffled as if they are not getting enough power. Since nothing has changed with the wiring, this sounds like an issue with the head unit. It could be the wiring or it could be from having the wires cramped together in the harness with the head unit that are the cause for the ''loss of power'' to the rears. I'm going to get it taken care of tomorrow. The people at one of the shops I go to know me, they won't charge anything to diagnose the problem. To fix the problem, sure.
    Best of luck man. Post back on what they said.
  8. Thanks Jaguar thanked for this post
  9. #36
    maylar's Avatar
    maylar is offline Electrical Weenie
    Jan 2002
    Connecticut
    66
    3,498
    2 Post(s)
    399 Post(s)
    One guy adamantly explains HU do not get hot and another says it's not unusual,
    what/who am I supposed to believe?
    "Hot as a mf", as you explained, is NOT usual. Yes they get warm, but not so hot you can't touch them.
    I suggest that you disconnect the rear speakers at the HU and see if the HU runs cooler. If you have a short in the rear speaker wires somewhere it would explain why they sound crappy. I also suggest swapping the front and rear speakers at the HU... if the fronts get crappy then the HU has issues.
    But wouldn't the Big 3 upgrade put extra pressure on the head unit to perform?(0 gauge for christsakes)
    No.
    dave
    1999 Buick Park Ave Ultra
    Head Unit: JVC KWHDR720
    EQ: Audiocontrol EQL
    Front Stage: Hybrid Audio Technologies Imagine 5.25 mids, Morel Maximo tweets
    Sub Stage: Boston G3 10", 0.5 cu ft sealed
    Amp: PPI Phantom 900.4
    Rear Fill: Boston SE953 6X9's
  10. #37
    Jaguar's Avatar
    Jun 2012
    GA
    335
    2 Post(s)
    214 Post(s)
    Well.
    I did not end up taking the system to my dealer yesterday to diagnose any problems. The reason is, after I (1) removed the 16 pin clip from the back of the head unit, (2) cleaned the connectors (3) checked the fuse (4) put the wires back carefully in the harness so as not to have the HU mash them= the problem seems to have disappeared. I think the way the person who put my HU in my previous install was not, careful enough to make sure the wires were secured from resting against the HU. I noticed the connect one of the sub outs rca's appeared marred. It had to have come from heat dissipated from the back of the HU. New upgraded wiring should keep this problem from occurring again. Actually I plan on doing the entire car soon. Thanks for the suggestions brother(s).
  1. Rear speakers not as lound as fronts?
    By darkhunter139 in forum Speakers
    Last Post: 01-28-2008, 08:42 PM
  2. left speaker not as loud as right?
    By pluto in forum General Discussion
    Last Post: 05-13-2006, 11:33 AM
  3. 12 10's Not as loud as i thought
    By Silica in forum Subwoofers
    Last Post: 06-08-2004, 08:39 PM
  4. Not as Loud as I expected....
    By ssj2xxgotenxx in forum General Discussion
    Last Post: 02-04-2004, 12:10 PM
  5. System I just wired not as loud as I thought itd be
    By remote-control in forum Wiring, Electrical and Installation Help
    Last Post: 12-28-2003, 02:37 AM
