Page 2 of 3 FirstFirst 1 2 3 LastLast
Results 16 to 30 of 37
Reload Thread: Rear Speakers not as loud as fronts?
  1. #16
    Kangaroux's Avatar
    Kangaroux is offline I put on
    Dec 2010
    Maine
    9,902
    3 Post(s)
    1624 Post(s)
    Re: Rear Speakers not as loud as fronts?
    The back of the headunit is a giant heatsink so naturally it will get hot but it should not be hot enough that it's burning your hand. If it's warm to the touch that's fine.
  2. #17
    Jaguar's Avatar
    Jaguar is offline Senior VIP Member
    Jun 2012
    GA
    335
    2 Post(s)
    214 Post(s)
    Quote Originally Posted by quackhead View Post
    the sub amp pre out has no connection to the HU speaker level outputs, so don't worry about that being an issue. Hu internal amps are very small and do get real hot IIRC, yours is only rated for like 22wrms or so. I never used the HU amp because they don't put out much and get real hot...some folks run a set of tweeters or a center channel with them.
    @quackhead I didn't think it was unusual for the HU to get hot, especially with the Big 3 upgrade I have sending it that extra power..
    We'll see what the problem is! We'll see! . Still though. One guy adamantly explains HU do not get hot and another says it's not unusual,
    what/who am I supposed to believe?
    Quote Originally Posted by Kangaroux View Post
    But wouldn't the Big 3 upgrade put extra pressure on the head unit to perform?(0 gauge for christsakes) Once I put the Big 3 upgrade in this car
    all the components in my car lit up twice as bright. The headlights were twice as bright, and the sound was noticeably improved (in every sense).
    James 1:2-5 2 Count it all joy when you fall into various trials, 3 knowing that the testing of your faith produces patience. 4 But let patience
    have its perfect work, that you may be perfect and complete, lacking nothing
    . 5 If any of you lacks wisdom, let him ask of God, who gives to all
    liberally and without reproach, and it will be given to him
  3. #18
    mylows10's Avatar
    mylows10 is offline B2,singer,ampere rep mylows10 is a Supporting Member of the forum!
    mylows10 is a Supporting Vendor of the forum!
    Sep 2009
    monterey , ca
    54
    22,434
    141 Post(s)
    1 Thread(s)
    6011 Post(s)
    well all i can say is that i've been installing longer that alot of guys on here are old .like kangaroux says a little warm to the touch but not so much that it would burn or even hurt a bit .warm is ok ,hot is not .....
    pioneer avhx 4800 dvd, ampere tfhe 9.0 and 150.4 with arc audio xxd 4080
    4 d3100 and 3 deka 8a31 and d975 ,270 dc power and 320 amp singer alt
    B2 ref mids,Cdt es6 mids cdt es 010 tweets x2 ,es 03 Mids x 2 mx1000 , sky high ,eb flex, and stinger hpm o gauge wires ,also 2 crossfire xsv2 18s in a 4th order no wall box
    NOR CAL DB DRAG JUDGE
    http://www.dcsoundlab.com
  4. #19
    Jan 2007
    any wet spot i can find
    3,282
    1188 Post(s)
    Maybe my idea of hot is not what someone else may think is hot...I was not talking about hot enough to fry an egg...warm to hot?..anyways, if it is hot enough to feel like it burns you, then I would think you have a problem, whether it is a speaker wire short, or possible HU ground issue.
    "Bailout: Taking a trillion dollars from the people and giving it to the banks so the banks can loan it back to the people, at interest!"
  5. #20
    shpatb's Avatar
    shpatb is offline CarAudio.com Elite
    Jan 2008
    Wisconsin
    652
    174 Post(s)
    Yeah the only reason I suggested the 4 channel is if the decks getting hot you're probably playing it loud enough for the headunit to distort the sound causing it to heat up. If it's not a wiring issure than it's probably what mylows said.
    2008 G8 LC6i Kenwood 6.5's upfront, Morels in the rear. Alpine PDX-F4, 2x BA-SPG555 sealed with JBL 14001
    2004 Pontiac Grand Prix GT2
    Head unit - eclipse CD5000
    Front Components - Boston Z6's Rear "fill"- Boston SR95
    Front&Rear Amp - Boston GT24
    Sub -2x Boston SPG-555 @ 34hz
    Sub amp -BA GT28
    ect - 12 farad stinger cap,0 gauge stinger wiring, stinger 1500 battery, 200a alt
    refs: keifersracing
  6. #21
    mylows10's Avatar
    Sep 2009
    monterey , ca
    54
    22,434
    141 Post(s)
    1 Thread(s)
    6011 Post(s)
    Maybe my idea of hot is not what someone else may think is hot...I was not talking about hot enough to fry an egg...warm to hot?..anyways, if it is hot enough to feel like it would almost burn you,or you can smell that hideous electric burning wire scent , then I would think you have a problem, whether it is a speaker wire short, or possible HU ground issue.
    this we agree
  7. #22
    West's Avatar
    West is offline Banned
    Jan 2012
    Oliver Springs, TN
    3,703
    1406 Post(s)
    I would suggest wiring the rear speaker to the HU front outputs and listen to verify if it is HU problems or rear speaker problems. If your rear speakers are exposed to the pressure from the subs, they could very well be blown. Hopefully it is just a speaker wiring short..
    Do this ^^
    Don't worry about heat, everything is going to run hotter in the summer (your deck sits behind the firewall and you engine will run hotter as well). I have noticed that stock HU's can run very hot as well. No smoke, no smell of burning, no problems (usually) as long as you are not trying to push a system beyond what it was designed to do you should only be concerned about functionality. Some decks have fans in back, you can check that they are working if you are really concerned.
    Upgrading you system with a 4 channel amp should reduce the heat regardless of what deck you are using, because you will be reducing the current that flows from the deck to your speakers. This will most likely fix the problem if there is something wrong with the speaker level outputs from the deck. If the problem is with the audio processor (not likely) you will need to replace the deck to have your rears work correctly. You need to isolate the problem by doing what quackhead said.
    Send the front outputs to the rear speakers.
    Possibilities:
    1) No change - The speakers are toasted or you have a wiring issue between the deck and speakers.
    2) Fixes the problem
    - The decks rear speaker outputs are bad.
    --> Try adding a 4chan amp to see if that solves it
    --> Replace the deck (less work)
  8. Thanks Jaguar thanked for this post
  9. #23
    Jaguar's Avatar
    Jun 2012
    GA
    335
    2 Post(s)
    214 Post(s)
    It get's as hot as the amp, as quick as the amp. And by hot yes I mean too hot to leave your hand on it long, after about 30 minutes. That's a guesstimate, I never actually timed it. If you ask me what's going on with respect to the original post, I think the Big 3 is partially responsible for added pressure on the HU to perform. Either that, or it's a wiring issue. The wires on the doors are low grade, I just haven't had time to upgrade them yet, could be sooner than I felt like it though (as in tomorrow). I don't mind buying a new head unit. People here would say the one I have (Sony CDX-GT700HD) *****, but I don't think the head unit was originally the problem. Just as your cars original wiring was not to handle the strain of upgrades in car-stereo component's, I think, ONCE you put the BIG 3 UPGRADE in (with 0 G wire for Christsakes), I don't think the upgraded components, particularly Head Unit's were meant to handle the type of power of such a huge wiring upgrade. That's my theory as to why it's getting as hot as it is. It seems like the only logical choice, besides the amp, but head units are designed to carry the draw from amplifiers. How far are we from topic on this one.
  10. #24
    Jan 2007
    3,282
    1188 Post(s)
    Quote Originally Posted by mylows10 View Post
    this we agree
    and I was not trying to disagree, I actually missed the post where you said they do not get hot and would have worded mine slightly different. I truthfully suspect what has been said here. The HU gets run pretty hard trying to keep up with a couple of subs and with both rear speaker acting up at the same time, you may have hit it on the head with the rear channels going out...but this is one of those that is difficult to diagnose without actually being there to hear the distortion and play with the system.
  11. #25
    TheUnderFighter's Avatar
    TheUnderFighter is offline Beer Addict
    Mar 2011
    Murrieta, California, (SoCal)
    27
    3,488
    862 Post(s)
    My HU got hot as hell in the summer. And that was only running rear speakers too.
    They head unit doesn't get any MORE power with 0 gauge wiring. It makes it easier for the power to flow. The components do not have to strain as hard to get that power. It's not making anything work harder or use more power, it's just lessening the strain. You're way off there man.
    And as West suggested, try running the rear speakers off the front channels of the HU and see if you have the same distortion issue.
    2nd, I'd just get a small amp for the speakers anyway. They will see more potential with better and cleaning power.
    2009 Hyundai Elantra - Budget Sound in Progress
    HU- Kenwood eXcelon KDC-X994
    Fronts- Crescendo MP6 mids, Vifa Ring Radiator tweets on Arc KS300.4
    Subs- Single SA-10 on Mmats 2000.1 @ 1ohm
    Misc- 1/0 CCA from AT, Big 3 in Stinger HPM, and AT 60 mil deadener
    Bought from: Inferno333, select127, treesive, Kangaroux, DonH
    Sold to: coolest user, Psychodrama, MidgetClown, mr.tigger, av83
  12. Likes Jaguar, West liked this post
  13. #26
    West's Avatar
    Jan 2012
    Oliver Springs, TN
    3,703
    1406 Post(s)
    Quote Originally Posted by TheUnderFighter View Post
    ^^ This.
    Unless he did something gangster and rerouted power from the batter to the HU without using a fuse. I pray that this did not happen...
    Amps are good and take the opportunity to upgrade the deck as well.
  14. #27
    Jaguar's Avatar
    Jun 2012
    GA
    335
    2 Post(s)
    214 Post(s)
    Quote Originally Posted by West View Post
    Do this ^^
    Well, my head unit is out, not detached, out. I touched it, it was hot as hell but not because anything was on, because of how hot is outside.
    I will have to check it and report back at night as to how hot it get's when it's cool out... Going to try and deduce the problems going on here.
    You need to isolate the problem by doing what quackhead said. Send the front outputs to the rear speakers.
    I would, but my fronts and rears are not connected by RCA's there is nothing coming or going out of the in or output jacks, just a huge garbled
    concoction of collective wire held by a clip.
  15. #28
    West's Avatar
    Jan 2012
    Oliver Springs, TN
    3,703
    1406 Post(s)
    I would, but my fronts and rears are not connected by RCA's there is nothing coming or going out of the in or output jacks, just a huge garbled concoction
    [/QUOTE]
    Ok.
    Contrary to what you signature says. Read the manual and find out which of the wires from the HU are powering the speakers.
    Switch the fronts and rears. (Front left plus into rear left plus, front left minus into rear left minus should be 8 wires total to switch)
    Not trying to be mean there, sorry if it came out that way. There are good reasons to read manuals lol. Also do a google search on the wire harness you are using to figure out the colors. You can always buy a new wireharness from Advance auto or autozone in you cannot find the color charts.
  16. #29
    Jaguar's Avatar
    Jun 2012
    GA
    335
    2 Post(s)
    214 Post(s)
    The rear speakers in question (the door speakers in the rear), can turn up loud, but with twice the volume as the front's. The fronts are clear, the
    rear speakers sound muffled more than anything. I'll be taking it in tomorrow. If the line out to the rear speakers are damaged on the head unit,
    what might you say the cause could have been?
  17. #30
    West's Avatar
    Jan 2012
    Oliver Springs, TN
    3,703
    1406 Post(s)
    Quote Originally Posted by Jaguar View Post
    The rear speakers in question (the door speakers in the rear), can turn up loud, but with twice the volume as the front's. The fronts are clear, the rear speakers sound muffled more than anything. I'll be taking it in tomorrow. If the line out to the rear speakers are damaged on the head unit, what might you say the cause could have been?
    The cause is most likely crrappy Asian manufacturing.
  1. Rear speakers not as lound as fronts?
    By darkhunter139 in forum Speakers
    Last Post: 01-28-2008, 09:42 PM
  2. left speaker not as loud as right?
    By pluto in forum General Discussion
    Last Post: 05-13-2006, 12:33 PM
  3. 12 10's Not as loud as i thought
    By Silica in forum Subwoofers
    Last Post: 06-08-2004, 09:39 PM
  4. Not as Loud as I expected....
    By ssj2xxgotenxx in forum General Discussion
    Last Post: 02-04-2004, 01:10 PM
  5. System I just wired not as loud as I thought itd be
    By remote-control in forum Wiring, Electrical and Installation Help
    Last Post: 12-28-2003, 03:37 AM
