Page 2 of 2 FirstFirst 1 2
Results 16 to 26 of 26
Reload Thread: help with tweeter noise (running active)
  1. #16
    UMWDawg92's Avatar
    UMWDawg92 is offline CarAudio.com Elite
    Jun 2010
    Missoula, MT
    27
    1,319
    59 Post(s)
    Re: help with tweeter noise (running active)
    turn your gain down on the tweeter channel or if your hu has level matching built in turn your tweets down, I had this problem and turned my gains down just a little bit and level matched and it went away
    Bought from: Misfit138, Nateberrier, Loudrc, Jarvisb, DMP, RAM_designs, go_go_thrash, alxmlr789,imjnotu
    Sold to: Lazyrider, TaylorPro, AJM511, Energizedsbs, diarmer, sobe3yourself
    Traded with: Vitveet, Resko1 x2, Suicide Bobb, Dumple
    More that I've forgotten now and some more in progress
    http://www.caraudio.com/forums/buyer-seller-feedback/506469-umwdawg92s-feedback-thread.html
  2. #17
    splwj47's Avatar
    splwj47 is offline CarAudio.com Veteran
    Aug 2011
    Great White North
    29
    2,674
    977 Post(s)
    Quote Originally Posted by UMWDawg92 View Post
    tried turning the gain down for the tweets and didnt do anything. it made it a bit quieter but didnt go away, went all the way down with the gain and it was still there. what does this level matching do that u speak of?
    2003 JEEP Grand Cherokee
    HU- pioneer 80prs
    Front Stage- Tantric HD comps.
    FS Amp- B2 Quattro
    Sub Amp-B2 Zero1
    Subs- Tantric HDD 12's
    box - 4.5^3 32hz
  3. #18
    UMWDawg92's Avatar
    Jun 2010
    Missoula, MT
    27
    1,319
    59 Post(s)
    My alpine 9887 has level matching for running active so that if you tweeters are way more sensitive you can turn them down a few dbs to match your mids but sounds like you may be getting some weird outside interference if it still does it on minimum gain
  4. #19
    splwj47's Avatar
    Aug 2011
    Great White North
    29
    2,674
    977 Post(s)
    my tweets are ran at -3db, mids and subs are at 0bd
    HU- pioneer 80prs
    FS Amp- B2 Quattro
    Sub Amp-B2 Zero1
    box - 4.5^3 32hz
  5. #20
    keep_hope_alive's Avatar
    keep_hope_alive is offline Acoustics Engineer keep_hope_alive is a Supporting Member of the forum!
    May 2007
    Quad Cities, IL
    7,082
    28
    48 Post(s)
    1502 Post(s)
    the whine is usually signal ground related, which is unaffected by wire routing.
    since you have the whine on both tweeters and mids (but more noticeable on tweeters due to the frequency of the noise) it is associated with HU, RCA's, and amp.
    could be the amp itself.
    could be resistance between HU ground and amp ground. both should be grounded the floor.
    could be a bad connection in an RCA. even new ones have failures.
    got a question? shoot me a PM. Matthew 6:9-15 - YouTube Channel: https://www.youtube.com/channel/UCkYUo2EShW9lgtrfXiDvLNQ/videos
    2014 Accord build log: http://www.caraudio.com/forums/car-audio-build-logs-cars-trucks-suvs/608637-2014-accord-sport-sq-build-keep_hope_alive.html
    2001 Accord build log: http://www.caraudio.com/forums/car-audio-build-logs-cars-trucks-suvs/536049-2001-accord-ex-sedan-its-long.html
    My 1966 MGB: http://www.mgexp.com/journal/keephopealive
    Fix Photobucket Image Loading ------> https://addons.mozilla.org/en-US/firefox/addon/photobucket-fix/ <------
  6. #21
    splwj47's Avatar
    Aug 2011
    Great White North
    29
    2,674
    977 Post(s)
    Quote Originally Posted by keep_hope_alive View Post
    i cant hear no whine comming from the mids just the tweets. could you give a little more insight on the grounding suggestion?
    HU- pioneer 80prs
    FS Amp- B2 Quattro
    Sub Amp-B2 Zero1
    box - 4.5^3 32hz
  7. #22
    May 2007
    Quad Cities, IL
    7,082
    28
    48 Post(s)
    1502 Post(s)
    ground head unit to the floor, sand away paint, etc. make sure amp and HU are grounded to the same piece of metal - i.e. no tack welds between the two. the floor should be electrically continuous from the firewall to the tire well.
  8. #23
    splwj47's Avatar
    Aug 2011
    Great White North
    29
    2,674
    977 Post(s)
    Ok well ill try running 2 new grounds and see if that solves it. Length of the grounds wont mater? So if i run a ground to drivers side firewall and run the amp ground to the floor of the back foot area would be good?
    HU- pioneer 80prs
    FS Amp- B2 Quattro
    Sub Amp-B2 Zero1
    box - 4.5^3 32hz
  9. #24
    Durango03's Avatar
    Durango03 is offline Enthusiast
    Jul 2008
    Tn
    828
    402 Post(s)
    Quote Originally Posted by B2WJ4.7 View Post
    You ever get this figured out?
    HeadUnit: sold Front Stage: 6.5 skar vxi65 + IA i65c + DB drive pro tweets Highs Amp: sold Sub Stage: all sold Sub Amp: sold Box: Wall @ ~30cu.ft. Electrical: 100ft 2/0 welding wire + 75ft 1/0 Audio Technix + 2 C&D 140's
    Deadener: 100sq.ft. Audio Technix 60mil
    References (sold, bought): Winkychevelle, SKARaudio x2, Patthehat033, Mazdakid, Ten_ton_bass, GAMEOVERCCA, Horsemanwill, Boomsday, Zellner, g6ryder x2, Moble Enclosurs (Box design), Goodstuff, Bread0710, dgaf, Cat Man, and many more (MAF, CACO, & ebay references available as well [110+ transactions])
  10. #25
    splwj47's Avatar
    Aug 2011
    Great White North
    29
    2,674
    977 Post(s)
    Quote Originally Posted by Durango03 View Post
    had to send deck in for warranty. hot swaped rcas and fucked something up internally.
    HU- pioneer 80prs
    FS Amp- B2 Quattro
    Sub Amp-B2 Zero1
    box - 4.5^3 32hz
  11. #26
    Durango03's Avatar
    Jul 2008
    Tn
    828
    402 Post(s)
    ahh, well Im trying to get an idea as to whats wrong with my tweeters (popping and engine whine in tweets only).. I wired them up to a passive Xo, along with front stage speakers using wires from factory deck (now running pioneer avh).. I read on here that pioneer has bad RCA grounds so I wrapped each rca output with stripped 12ga and grounded that out and also ran a new HU ground.. didnt work. So I snipped off the tweet wires and ran new ones... tried moving the wires to different places in the Xo to see if it would make a difference.. Finally just wire all positives together and all negatives and there is no noise, works great! However now Im concerned that there is no filter for the tweet's and they are likely to blow anytime..
  1. going active, need help with tweeter amp
    By GrnEydDvl in forum Amplifiers
    Last Post: 01-12-2007, 11:27 PM
  2. help with tweeters
    By perrydog in forum Wiring, Electrical and Installation Help
    Last Post: 06-08-2006, 02:24 AM
  3. Help with mids for an active setup.
    By cd6551 in forum Speakers
    Last Post: 03-29-2006, 08:33 AM
  4. Help with tweeter placement
    By christiankills in forum Speakers
    Last Post: 03-01-2006, 04:44 PM
