Results 1 to 5 of 5
Reload Thread: Is this possible?
    DJ B's Avatar
    DJ B is offline Junior Member
    Mar 2004
    Columbus, NJ
    17
    Is this possible?
    I have a 96 grand am sedan. it has 4x6s in the front, but the speaker grille is around 6.5"
    is it possible for me to either
    a) mount mdf where the plastic mount is for the 4x6 and put 6.5's in there
    or
    b) mount 6.5's on the actual plastic door panel. obviously secured with mdf....how would the acoustics sound for something like this?
    i really need midbass in the front, but i dont want to end up with speakers that i can't use for whatever reason.
    Logikalliquid's Avatar
    Logikalliquid is offline CarAudio.com Elite
    Oct 2003
    SoVA
    33
    972
    Re: Is this possible?
    as long as you got the clearence for the mounting depth B is definately possible. you could try cutting/sanding the mdf to angle it right to help the acoustics.
    sumone's Avatar
    sumone is offline CarAudio.com Veteran
    Dec 2003
    Midwest
    3,416
    dude we're in the same boat...
    I can tell you that you probably don't wanna mount them on the panel...
    using some mdf as a spacer is your best bet after fiberglassin some kick panels. that's what I'm gonna do (once I get the mdf...). then when it gets warmer, gonna glass them kicks.
    DJ B's Avatar
    Mar 2004
    Columbus, NJ
    17
    Ok I'm almost defniely doing option B (mounted in door panels)
    is there anything i should look out for so i dont regret it? (vibrations, not enough support, just plain not working, etc)
    DJ B's Avatar
    Mar 2004
    Columbus, NJ
    17
