Results 1 to 6 of 6
Reload Thread: 5 x7 / 6 x 8 help!
    blnk64's Avatar
    blnk64 is offline Member
    Apr 2011
    Wattsburg, PA
    25
    53
    14 Post(s)
    5 x7 / 6 x 8 help!
    I recently posted about installing a 2 way 6.5 set of coxials for my front stage. Turns out I need 6x8 or 5x7 to fit my doors tho. I know I can find brackets to fit 6.5s into these spaces but if i wanted to stick with the 5x8s what brands should I be looking at? Btw i dont think i have enough room to cut space for a 6x9. Morel, cdt, focal, etc dont carry any 6x8s. Brands I have found that do are:
    JBL
    JL c5-570
    Kicker
    Alpine
    Infinity
    Boston Acoustics sr 80
    I'm sure i missed a few but any thoughts on what i listed. I'm willing to spend 200 to 350 for the pair.
    2003 Ford Escape
    First system...
    Headunit: Kenwood 248u
    Amp: Alpine mrp 1000
    Subs: 2 fosgate p3d2 12s
    zako's Avatar
    zako is offline CarAudio.com Elite
    Jan 2011
    TX
    1,347
    238 Post(s)
    Re: 5 x7 / 6 x 8 help!
    If you're looking at component speakers that fit oval holes, then your selection is very limited. Infinity and JBL (same company) make oval speakers in components form, but based on most reviews, they're pretty average speakers with tweeters having a reputation for being harsh. If you want to buy more expensive speakers, consider JL Audio C5 or Image Dynamics XS. Both have good reviews. That's pretty much it. If I was buying right now, I'd get the same I have right now (Hybrid Audio Imagine running active) with an adapter or perhaps something made by Hertz or Focal.
    If you're looking at coaxial speakers, then there will be a bit more choices.
    Buck's Avatar
    Buck is offline always low Buck is a Supporting Member of the forum!
    May 2008
    Nashville
    18,643
    28 Post(s)
    1117 Post(s)
    Just make a baffle to fit the 6.5 out of abs or .5 wood. That's what I did in my exploder.
    Alpine - ASE (local) - Batcap - CT Sounds - eD - Excessive Amperage - Powerware - Rainbow
  4. Thanks blnk64 thanked for this post
  5. #4
    blnk64's Avatar
    Apr 2011
    Wattsburg, PA
    25
    53
    14 Post(s)
    Thank you for the input but i have a few more questions
    1. How does sq and spl compare for a 5x7 compared to a 6.5 of equal caliber?
    2. And lastly any more input on JL c5 series? If I go with a 5x7 JL has one of the few upper end 5x7s I could choose from.
    2003 Ford Escape
    First system...
  6. #5
    zako's Avatar
    Jan 2011
    TX
    1,347
    238 Post(s)
    Quote Originally Posted by blnk64 View Post
    There is probably little inherently bad with the speaker being oval. The issue is that your selection is very limited. Look at truly high end brands like Morel, HAT, Hertz, Focal, and many others. If you want to use their speakers (perhaps with the exception of one or two lowest end models) you have to buy round woofer.
    I never heard them, but someone compared their sound to Hybrid Audio Imagine. If that comparison is valid, they should be decent speakers.
  7. #6
    blnk64's Avatar
    Apr 2011
    Wattsburg, PA
    25
    53
    14 Post(s)
    Ok thank you. Looks like I'm gonna have to go with a 6.5. I'm thinking focal polyglass with a mount to fit properly. I've ears good things about them
    2003 Ford Escape
    First system...
  1. rockford x7.a need help look
    By customlt1 in forum Amplifiers
    Last Post: 07-31-2006, 12:26 PM
  2. Rockford x7.a V.S jbl 1201.1 PICK ASAP!!!HELP!!!
    Last Post: 07-20-2006, 01:39 AM
  3. jl 500.1 or audiobahn 1300 hcx? HELP!!!! quick
    By rpeterson57 in forum General Discussion
    Last Post: 06-04-2002, 04:40 AM
  4. need help on my setup
    By <helpme> in forum General Discussion
    Last Post: 12-11-2001, 01:28 AM
  5. SUGGESTIONS!!!!!!!! HELP??!!!!
    By <nate> in forum General Discussion
    Last Post: 12-10-2001, 12:30 PM
