Page 3 of 5 FirstFirst 1 2 3 4 5 LastLast
Results 31 to 45 of 65
Reload Thread: audio system for honda fit
  1. #31
    UnderFire's Avatar
    UnderFire is offline CarAudio.com Veteran
    Apr 2011
    Dayton, OR, 97114
    2,096
    1 Post(s)
    542 Post(s)
    Re: audio system for honda fit
    Hybrid Audio Imagines are great speakers to look into. They sound amazing in confined spaces and aren't too in your face. I speak from experience I had a set in a Regular cab truck.
    97 4runner, 3RZ, 5 Speed
    Headunit: Pioneer DEH-P9800BT
    Mids: Pioneer ????
    Tweets: CDT DRT-25
    Fronts Amp: Memphis M-Class 4x50
    Sub Amp: Diamond D3 400.1
    Substage: 2x 12" Dayton HO's
    Electrical: 160 Amp Alt, Kinetik HC2400, Interstate DCM0100, 2/0 Throughout
  2. #32
    teeforb's Avatar
    teeforb is offline Member
    Mar 2012
    United States
    34
    9 Post(s)
    Quote Originally Posted by UnderFire View Post
    are the cost for hybrid audio less than that of the focal?
  3. #33
    mylows10's Avatar
    mylows10 is offline B2,singer,ampere rep
    Sep 2009
    monterey , ca
    54
    22,442
    141 Post(s)
    1 Thread(s)
    6015 Post(s)
    depends on the model , but usually no
    pioneer avhx 4800 dvd, ampere tfhe 9.0 and 150.4 with arc audio xxd 4080
    4 d3100 and 3 deka 8a31 and d975 ,270 dc power and 320 amp singer alt
    B2 ref mids,Cdt es6 mids cdt es 010 tweets x2 ,es 03 Mids x 2 mx1000 , sky high ,eb flex, and stinger hpm o gauge wires ,also 2 crossfire xsv2 18s in a 4th order no wall box
    NOR CAL DB DRAG JUDGE
    http://www.dcsoundlab.com
  4. #34
    jirehn's Avatar
    jirehn is offline Senior VIP Member
    Nov 2011
    Tempe, AZ
    369
    59 Post(s)
    It depends on your budget. If you have a great budget it will definitely a fantastic set up for your audio.
  5. #35
    teeforb's Avatar
    Mar 2012
    United States
    34
    9 Post(s)
    Does people still use tube subs? I'm thinking this can be a good substatute as its easy to take out if I need all my space
  6. #36
    hispls's Avatar
    hispls is online now CarAudio.com Veteran
    Sep 2009
    Cape Cod, Massachusetts
    9,949
    15
    36 Post(s)
    4038 Post(s)
    Quote Originally Posted by teeforb View Post
    Most of them are below average, but then again if you're on a tight budget and don't need a lot of output they may work. If you want something you can remove easily you don't want a powered subwoofer since there's way more wires attatched than if you had a small amp under a seat and woofer/box only in the trunk.
    IMO Arc amp is a good pick (though the one you mentioned may be too much power for what you're after). High quality amp is a good investment. It'll pay off it performance, reliability, and have a chance at holding some re-sale value down the road.
    I'm guessing you just want to replace factory speakers and add a small subwoofer (really that's about all your budget allows). You've said you don't want to/don't have time/can't do the work yourself. Now you should consider cost of installation AND if the shop that is competent to do it will install stuff you buy elsewhere. If they'll install stuff you buy elsewhere you have more options, if not you may consider shopping around. I'd like to see you into something between Kenwood and Focal for speakers personally. Focal are good, but expensive and as has been said, really only their higher end lines are "worth" the premium price. Actually if you live near a best buy, you might take a look at the Alpine type R components (or coaxials). They're fairly priced and sound really nice IMO. Ditto for type R subs.
    I would say your primary focus should be a good sounding set of components in the front and a small subwoofer in the trunk (which is easy for you to remove if that's likely to be an issue). You can keep the factory speakers in the rear powered off the head unit or just unplug them (which is what I'd do).
  7. #37
    nateberrier's Avatar
    nateberrier is offline ******
    Jun 2009
    Douche, Ohio
    4,641
    202 Post(s)
    Honder Fit owner here, what year is it?
    Refs: mrmakinmoves[SCAMMER] AKA ICHASEPAPER2010, skydeaner, fukinmovin, mossberg385t, grimreper912003, LBC99, Dbeez, Michaellane, thegreatestpenn, truckstoy, ge_off_me, btr, cupid6969, johnprdeye, jh8909, tylerj, UMWDawg92, nu2spl, zerosktr111, SPLAUDIO, $LICK CALIFA$, jfroghobo
    http://www.execution-audio.com/
  8. #38
    T.I.K.'s Avatar
    T.I.K. is offline F*ck it, we'll do it live
    Oct 2010
    Michigan
    25
    4,163
    848 Post(s)
    If you want decent bass, consider getting like an SSA DCON and an EFFICIENT 300w amp, or buy a larger amp that does 300w @ 2 or 4 ohmsohms
    that's not a big system i'm sure it would fit in there
    Get taken down to funky town
  9. #39
    Jun 2009
    Douche, Ohio
    4,641
    202 Post(s)
    I would not probably run more than 750rms total, Not without an extra battery anyway. The big three upgrade is also a good option. Big 3 is replacing the wire for your charging system. Battery + to Alternator, Battery - to Chassis, and Motor to Chassis. Usually wanna upgrade to 1/0 and will help move electrons so your car can better provide electricity to said audio.
    ELD in the Honders is a pain, because the car stops charging to save gas. You can offset this by turning on your blower, (hot or cold), turning your lights on, and driving over 65mph. You can bypass it also, but I dont think you want to do that assuming its still under warranty.
    If your Fit is 09+, when you remove the radio, you will have to pop a panel out just above your lower drink holders and remove a screw before the radio pops all the way out.
    The tweeters will pop out easy up top, I suggest cutting holes in the factory plastic cups or poking a hole through and running wire up to new ones on top (great factory location, and even better if you have the tweeters facing you)
    The door panels come off by popping the outer plastic part of the arm rest off, you can see the clips if you look at the underside of the arm rest. The door panel clips attaching it to the actual door are a pain and may break so be careful.
    Factory speakers are molded into their own little adapters. I took the factory speakers out and cut the actual cone out, then used the remaining piece for a speaker adapter pod.
    Rear speakers I wouldnt even bother with.
    In the back you can ground near the cargo loop in the corner near where the seats fold down.
    When removing the interior trim to run wire, it is easiest to pull the door seal off or partially off and then pull straight up on the trim panels, they are connected in a weird mannor and this is the easiest way.
    There is a rubber grommet behind the dash sorta up to the top on the passenger side which is good for running power wire through, just not when the engine is hot lol.
    It doesnt take much to get this car loud either.
    I can help with pics if needed
  10. #40
    teeforb's Avatar
    Mar 2012
    United States
    34
    9 Post(s)
    Quote Originally Posted by nateberrier View Post
    2012
  11. #41
    kramer_212's Avatar
    kramer_212 is offline CarAudio.com Veteran
    Jul 2011
    Minnesota
    4,485
    482 Post(s)
    Quote Originally Posted by mylows10 View Post
    china garbage
    truth, never had a kenwood that i liked.
  12. #42
    teeforb's Avatar
    Mar 2012
    United States
    34
    9 Post(s)
    For bass, keep in mind i do not want to sacrifice almost no space in my fit. I need something extremely small and removable. I'm not looking for BOOOM, but rather something that will enhance my listening experience of my other speakers. A small little box no larger than a few inches thick and maybe a quality 8inch sub will do. If i need to go do my hobbies, i want to be able to easily unwire and remove the box as i'll need all the space in the back of my fit.
  13. #43
    MANTI5's Avatar
    MANTI5 is offline CarAudio.com Elite
    Nov 2010
    Southern AZ
    1,434
    1 Post(s)
    40 Post(s)
    You may be better off with just a good set of components amped properly and see if you want more bass after that.
    Refs: Mitch86, talon, kramer_212, kushy_dreams, ctmaudi, pro-rabbit, ikoolguy, tat2bass
  14. #44
    Why So Cereal?'s Avatar
    Why So Cereal? is offline Invisible Cereal
    Sep 2010
    Drowning in milk
    7,403
    1555 Post(s)
    This amp : Boston Acoustics GT-2125 (gt2125) GT Reference 2-Channel Amplifier
    With a nice set of comps and properly deadened doors is the way I'd go
  15. #45
    teeforb's Avatar
    Mar 2012
    United States
    34
    9 Post(s)
    hey guys, just found out boston acoustics are out of business.
  1. Best Audio System for my car (2001 Honda Odyssey)
    By crreed55 in forum General Discussion
    Last Post: 05-13-2011, 04:31 PM
  2. BUILDING CAR AUDIO SYSTEM(for Beginners)
    By BASS OUTLAW in forum General Discussion
    Last Post: 11-06-2004, 09:08 PM
