Results 1 to 8 of 8
Reload Thread: 6.5" components
    lawlyes2007's Avatar
    lawlyes2007 is offline Senior VIP Member
    Dec 2007
    Champaign, IL
    214
    6.5" components
    I need some opinions between these four sets:
    HAT Imagine
    CDT CL 62 PRO
    Morel Maximos
    Morel Tempos
    They will be going in a mazda 6. Mids in the bottom door and the stock tweets are in the door sail?
    I'm not against mounting in a coax configuration just want the best sounding set out of these or something similar.
    I do not have an amp picked out at the time.
    mylows10's Avatar
    mylows10 is offline B2,singer,ampere rep mylows10 is a Supporting Member of the forum!
    mylows10 is a Supporting Vendor of the forum!
    Sep 2009
    monterey , ca
    54
    22,434
    141 Post(s)
    1 Thread(s)
    6011 Post(s)
    Re: 6.5" components
    thats a hard decision ,they all sound really good ,so i guess its would come down to budget ,for me.if you deaden your doors ,they'll prolly sound close to the same.
    pioneer avhx 4800 dvd, ampere tfhe 9.0 and 150.4 with arc audio xxd 4080
    4 d3100 and 3 deka 8a31 and d975 ,270 dc power and 320 amp singer alt
    B2 ref mids,Cdt es6 mids cdt es 010 tweets x2 ,es 03 Mids x 2 mx1000 , sky high ,eb flex, and stinger hpm o gauge wires ,also 2 crossfire xsv2 18s in a 4th order no wall box
    NOR CAL DB DRAG JUDGE
    http://www.dcsoundlab.com
    Dec 2007
    Champaign, IL
    214
    Re: 6.5" components
    Yea kinda what i'm thinkin, but the budget isn't really a concern here as they are all pretty close to the same $
    keep_hope_alive's Avatar
    keep_hope_alive is offline Acoustics Engineer keep_hope_alive is a Supporting Member of the forum!
    May 2007
    Quad Cities, IL
    7,080
    28
    47 Post(s)
    1502 Post(s)
    Re: 6.5" components
    They will sound different. But it is not feasible to audition all in the same car. each tweeter is a different size, you may want to consider mounting the tweeters into your decision. Don't coaxially mount them, use the sail panel.
    got a question? shoot me a PM. Matthew 6:9-15 - YouTube Channel: https://www.youtube.com/channel/UCkYUo2EShW9lgtrfXiDvLNQ/videos
    2014 Accord build log: http://www.caraudio.com/forums/car-audio-build-logs-cars-trucks-suvs/608637-2014-accord-sport-sq-build-keep_hope_alive.html
    2001 Accord build log: http://www.caraudio.com/forums/car-audio-build-logs-cars-trucks-suvs/536049-2001-accord-ex-sedan-its-long.html
    My 1966 MGB: http://www.mgexp.com/journal/keephopealive
    Fix Photobucket Image Loading ------> https://addons.mozilla.org/en-US/firefox/addon/photobucket-fix/ <------
    Wattser93's Avatar
    Wattser93 is offline Senior VIP Member
    Jan 2010
    Sparks, NV
    188
    16 Post(s)
    Re: 6.5" components
    I was also in the same boat looking for a solid set of comps at that budget. If I had an active capable HU, I would have bought the HAT Imagines. The only reason I didn't was because I don't have active capability, and was worried about the tweets being too bright and not having a way to tame them.
    I auditioned quite a few sets locally until I found a set that my ears liked. If you can, try to audition the sets before you make a decision. I found that "forum boners" that I read so highly of were nothing special to my ears.
    '01 Denali
    HU: KDC-X693
    Mids: Helix E62C comps on Arc Audio FD2200
    Substage: 12" Alpine Type-R in [email protected] on Alpine MRP-M350
    Dec 2007
    Champaign, IL
    214
    Re: 6.5" components
    I went ahead and bought the hats, now I'm in the process of installing them.
    Do I need a baffle on the inside of the door to keep water from getting on the speakers or how does that work?
    mylows10's Avatar
    Sep 2009
    monterey , ca
    54
    22,434
    141 Post(s)
    1 Thread(s)
    6011 Post(s)
    Re: 6.5" components
    you can if you want or just matt the doors .should have pm'ed me i could have saved you some cash if you had bought the cdt's
    zako's Avatar
    zako is offline CarAudio.com Elite
    Jan 2011
    TX
    1,347
    238 Post(s)
    Re: 6.5" components
    Quote Originally Posted by Wattser93 View Post
    You don't need an active head unit to run them active. Run the woofer with no low pass filter and the tweeter with a high precision 2.2uF Dayton capacitor inserted inline. This replicates the passive crossover of the Imagines. This is what I am running with tweeters mounted in door sails and it sounds good. I keep digging out and enjoying some older albums because they sound so much better now, even though they seemed like nothing special in the past. I adjusted the tweeter gains by ear until the high frequencies sound just right too me, and added time delay to the left tweeter and woofer with the stereo, the best I could to center the sound stage. The high pass filter on the woofers is 70Hz with 24dB (as recommended in the manual), the sub low pass is 50Hz @18dB, and I bumped 65Hz band on the EQ by 3dB. I would have replicated this setup gain. The speaker amplifier is MB Quart REF4.80 4x80watts.
  1. component speakers
    By <jaylee> in forum General Discussion
    Last Post: 10-29-2004, 09:46 AM
  2. &quot;Esoteric&quot; components
    By 89S4 in forum Amplifiers
    Last Post: 01-23-2002, 08:03 PM
  3. Replies: 4
    Last Post: 12-21-2001, 06:05 PM
  4. Diamond S600 components anyone heard or have them?
    By <Integra> in forum General Discussion
    Last Post: 12-16-2001, 03:15 PM
  5. Replies: 0
    Last Post: 12-16-2001, 03:10 PM
