Results 1 to 11 of 11
Reload Thread: Water leaking in door panel
    Nov 2011
    Iceland
    45
    Hope this is the right place for this thread.
    I am installing speakers in my doors next saturday.
    I currently have no speakers in the doors, the stock speakers have been taken out.
    This is a bad picture of the water that's lying on the botton of the door panel.
    When I put my hand in there, one drop of water comes down where the speaker is going to be placed every 20-30 sec.
    I dont know if my car leaks from the outside when it's raining, because when the new speakers were being fitted it was raining alot and
    (they have been taken away, check my older thread if you're confused) the door was open and the inside of the door was wet(the interior of the door).
    Is there anything I can do to prevent the water from dripping on the new speakers, or is this a minor problem?
    I will spray the outside of the door with water tomorrow to check if the rain is the reason for this.
    06goat's Avatar
    06goat is offline bumpin bluegrass
    Sep 2008
    Michigan
    1,738
    19 Post(s)
    Re: Water leaking in door panel
    You can get some XTC Foam baffles from partsexpress.com. Cut them in half so it only covers the top half and allows the speaker to breathe almost just as well as if it wasnt there.
    2006 GTO
    800prs
    Audio System X--ion 70.6 PLUS
    Dayton Ref's
    GaryWA's Avatar
    GaryWA is offline Noobie
    Jan 2012
    Washington State
    109
    You could always try some butyl or some dynamat and see if it helps.
    06goat's Avatar
    Sep 2008
    Michigan
    1,738
    19 Post(s)
    The water is most likely coming from your window gasket. Minor leaking is normal with a lot of vehicles. Something you just half to deal with unless you want to try and refabricate your window seal
    2006 GTO
    800prs
    Dayton Ref's
    Wingsfreak9's Avatar
    Wingsfreak9 is offline CarAudio.com Veteran
    Nov 2009
    Howell, MI
    4,578
    1 Post(s)
    get a new door.
    Quote Originally Posted by AZ_G6GT_Beatin View Post
    then your a D U M B A S S can you read that shi t
    Quote Originally Posted by misfit138 View Post
    How did you manage to pack that much stupid into such a small amount of words?
    Sold to: nom nom, Trever, Spooney, dkhage1, tghersh88
    Bought from: MikeyF, Paaco1981, Thorshammer1, Sundownz, Ridinhi, Cl1ckclack, nom nom, profoundwill, vfrrider, El_Weenie, DBBOOM
    keep_hope_alive's Avatar
    keep_hope_alive is offline Acoustics Engineer keep_hope_alive is a Supporting Member of the forum!
    May 2007
    Quad Cities, IL
    5,118
    28
    127 Post(s)
    you will always get water in the door - the window seals are not water tight. that is why the bottom has drain holes.
    you just need to channel water around the opening. you can make a lip with deadener, use weathestripping foam, use a XTC foam baffle, anything to make a half circle channel on the top half of the speaker opening.
    i can post pics of my process for doing this...
    have you been helped by me? i'd love to know. shoot me a PM.
    My 2001 Accord build log:
    http://www.caraudio.com/forums/car-audio-build-logs-cars-trucks-suvs/536049-2001-accord-ex-sedan-its-long.html
    Can I help you? valencebandacoustics@gmail.com
    Want to learn about car audio electronics?
    http://www.bcae1.com
    May 2007
    Quad Cities, IL
    5,118
    28
    127 Post(s)
    3/4" CCF weatherstripping around the top
    used deadener to wrap around and create a larger lip
    lolingirunarlol's Avatar
    lolingirunarlol is offline Member
    Nov 2011
    Iceland
    45
    Thank you guys for your replies.
    So, for my CXS64 V2 - Image Dynamics 6.5", this would be perfect(?)
    The Install Bay VXT60 XTC 6-1/2" Round Large Frame Foam Car Speaker Baffles | eBay
  9. #9
    06goat's Avatar
    Sep 2008
    Michigan
    1,738
    19 Post(s)
    Quote Originally Posted by lolingirunarlol View Post
    If youre not a diehard SQ guy, and i mean diehard, then they will work, just cut them in half and put it on the top half of the speaker when you mount it.
    2006 GTO
    800prs
    Dayton Ref's
  10. #10
    May 2007
    Quad Cities, IL
    5,118
    28
    127 Post(s)
    Don't cut it completely in half. You want a full seal between the speaker and door so the front flange is needed. Just remove the back and half of the cup so the speaker can breathe.
  11. #11
    audiobaun's Avatar
    audiobaun is offline Premium Member audiobaun is a Supporting Member of the forum!
    Jun 2011
    rockwall,Tx
    5,996
    36 Post(s)
    With that much water in the bottom of the door, it seems that the drain holes may be clogged.Prob need to look into that to unclog them before placing the speakers in,or make them larger/drill them out.Just an opinion.Thats alot of water.Recommend getting new door seals as well.
  1. 8" in door panel
    By justinschmiidt in forum Speakers
    Last Post: 05-26-2006, 02:09 AM
  2. pod in door panel ?
    By regal8r in forum Enclosure Design & Construction Help
    Last Post: 05-20-2006, 03:18 PM
  3. cutting holes in door panels?
    By Ryde _Or_Die in forum Enclosure Design & Construction Help
    Last Post: 02-22-2004, 11:05 AM
  4. speakers in door panel on saturn
    By Benny212 in forum Wiring, Electrical and Installation Help
    Last Post: 12-15-2003, 09:40 PM
  5. 6.5 in door panels
    By CaddyLacGrills in forum Wiring, Electrical and Installation Help
    Last Post: 04-29-2003, 06:03 PM
