Results 1 to 9 of 9
Reload Thread: 4 inch pillar speakers.
    kramer_212's Avatar
    kramer_212 is offline Music-Expression
    Jul 2011
    Minnesota
    4,282
    23 Post(s)
    well in a couple of weeks im going to finally mold a center channel (pair) and do my pillars.
    deciding if i want to do comps or coaxials, can't seem to find respectable 4 inch comps around. both the pillars and the center (4 speakers total) will have there own amp from all the door speakers, and don't plan on having them that loud. compared to the bigger door speakers.
    was thinking this to match all my t2 comps that will be in the doors(if i have to go coaxail).
    90% sure the amp will be a t400-4 or t400-2also.
    Rockford Fosgate® - T142
    also could be just mids to if there are respectable ones out there then i can just move some of the tweeters from the doors up into the center, and pillars.
    sacsking916's Avatar
    sacsking916 is offline stayin high an loud
    Apr 2009
    emerald triangle..home of da trees
    6,435
    6 Post(s)
    Re: 4 inch pillar speakers.
    do some mids off of madisound or something of that sort
    TEAM AUDIO TECHNIX
    TEAM SSC
    TEAM CADENCE
    Sold to: imtjnotu; ace_800; omegabunny crazykenkid Bought from: El_weenie; fasfocus00; retroaudioinc; f1mclarenagr; jason19; tone415; twizted859; noph33rracing; tony30cl; carlosg_313 Traded with: Micah_Jones; MikeOfTulsa
    Apparently I was called out, or called a goat fucker, or something. I really have no idea. Im just along for the ride at this point.
    Quote Originally Posted by CRXBMPN View Post
    King James has nothing on King Sac!
    kramer_212's Avatar
    Jul 2011
    Minnesota
    4,282
    23 Post(s)
    Quote Originally Posted by sacsking916 View Post
    im going to go take a look quick.
    thanks. anymore?
    kramer_212's Avatar
    Jul 2011
    Minnesota
    4,282
    23 Post(s)
    these might work, but for that price i might be better off just going with the fosgates.
    kramer_212's Avatar
    Jul 2011
    Minnesota
    4,282
    23 Post(s)
    Markaudio CHP-70 Gen2 Black Paper: Madisound Speaker Store
    these look decent also maybe i should think about running a 4 and 3 inch i have the room for it.
    Why So Cereal?'s Avatar
    Why So Cereal? is offline Invisible Cereal
    Sep 2010
    Drowning in milk
    7,348
    74 Post(s)
    TangBand Bamboo drivers on PE for nice 3 or 4 inchers.
    Also Dayton RS series, i remember reading a review over on diyma that these stuck with and exceeded in performance drivers that costed way more!
    Those would be my top choices.
    kramer_212's Avatar
    Jul 2011
    Minnesota
    4,282
    23 Post(s)
    Quote Originally Posted by princ3cmo View Post
    Ima go check out the daytons right meow.
    trumpet's Avatar
    trumpet is online now Supporting Vendor trumpet is a Supporting Member of the forum!
    trumpet is a Supporting Vendor of the forum!
    Jan 2011
    Langdon, ND
    32
    1,929
    48 Post(s)
    Where do you have the T1TS(dumbest model number ever) and the tweeters from the T2 components mounted? If you're serious about complicating your front stage even more, you might be disappointed to find that placing more drivers up high is not a cakewalk. Reflections off the glass can be a real ***** to deal with, plus comb filtering gets out of hand as you add more and more drivers. This all adds up to a chaotic mess of sound. There's no need to do both a huge 4" mid and a 3" mid on your A-pillars. If you must have it then I doubt you can be talked out of it.
  9. #9
    keep_hope_alive's Avatar
    keep_hope_alive is offline Acoustics Engineer keep_hope_alive is a Supporting Member of the forum!
    May 2007
    Quad Cities, IL
    5,015
    28
    124 Post(s)
    i think T1TS is a brilliant model number, as long as the phase plug is flat on the end :O
    I have a set of the 4" Dayton RS full range. too big for apillars in my Accord. I'd have to cut away sections of the dash to get the desired airspace. the 3" version is awkward due to the size of the terminals, but the truncated version may fit better in the apillars. A full range woofer, on axis, will sound better than a coaxial or woofer/tweeter pair for the reasons described above. the highs will be subdued, but more natural. depends on what your goals are - accuracy or just loudness. making the apillars look good is a different effor than making them sound good. airspace is crucial for midrange performance and aiming is crucial for high frequency performance and control of reflections. i don't like coaxial speakers - mostly due to the use of cheap components with poor execution. and you have the woofer and tweeter overlapping in response - but not properly aligned.
    there are many examples at DIYMA in this thread and good discussion as to the challenges and benefits.
    http://www.diymobileaudio.com/forum/diyma-sq-forum-technical-advanced/65061-improve-your-soundstage-$2.html
    madisound and parts express have a huge selection of full range drivers perfect for an apillar appliation. Pearless, Vifa, Tymphany, Tang Band are all affordable options. Mark Audio has a very nice selection that i'd also like to try.
    have you been helped by me? i'd love to know. shoot me a PM.
    My 2001 Accord build log:
    http://www.caraudio.com/forums/car-audio-build-logs-cars-trucks-suvs/536049-2001-accord-ex-sedan-its-long.html
    Can I help you? valencebandacoustics@gmail.com
    Want to learn about car audio electronics?
    http://www.bcae1.com
  1. 4 inch speakers in my mr2..
    By m3rK201 in forum Speakers
    Last Post: 02-16-2010, 01:44 AM
  2. best 5" inch speakers?
    By Charlie Rigz in forum Speakers
    Last Post: 09-17-2004, 01:29 AM
  3. 6.5 inch speakers
    By tlh1005 in forum Wiring, Electrical and Installation Help
    Last Post: 04-15-2002, 11:27 AM
  4. Best 6x8 inch speakers??
    By crzybob77 in forum General Discussion
    Last Post: 03-09-2002, 04:49 PM
