Results 1 to 2 of 2
Reload Thread: Polk Audio db6750's and db675's install questions.
    AsahiToro's Avatar
    AsahiToro is offline Junior Member
    Feb 2004
    Tampa, FL
    Any pro installers out there? Can I fit these guys in an 04 Acura TSX's doors (6750's up front/675's in back)? I think I only have a mounting depth right around 2" in the doors. Can I fit these without screwing with the window and also still be able to use the stock grills? If not what about the 6500's and 650's?
    Thanks for any experience input,
    Scott
    AsahiToro's Avatar
    Feb 2004
    Tampa, FL
    Re: Polk Audio db6750's and db675's install questions.
    Sorry for the bump but does anyone know if these will fit? I'm OK with a little sheetmetal cutting if needed. I'm just wondering if I can make them fit and look stock?
