Results 1 to 10 of 10
Reload Thread: can coaxials take a 2ohm load?
    Ryde _Or_Die's Avatar
    Ryde _Or_Die is offline Senior VIP Member
    Feb 2004
    Tampa, FL
    321
    I found out my coaxials are rated half what I thought they were going to be. So now I was just wondering if I could use only one channel to run a pair of 4 ohm 6.5s. I'll lose alot of clarity if I did that though, wouldn't I?
    jbl_marshall21's Avatar
    jbl_marshall21 is offline important person
    Oct 2002
    nebraska
    2,494
    1 Post(s)
    Re: can coaxials take a 2ohm load?
    u shouldn't lose any audible sound quality. as long as ur amp can handle the 2 ohm load, u'll be fine.
    Alpine CDA-9886
    RUX-C701
    PXA-H701
    JL xr-650csi
    JL vr-650cxi
    2 8" W7
    JL HD750/1
    JL HD600/4
    2007 Chevy Trailblazer
    sumone's Avatar
    sumone is offline CarAudio.com Veteran
    Dec 2003
    Midwest
    3,416
    it doesn't matter what impedance the speakers provide...the amp just has to support it. it can be anything as long as the amp is "x" stable where x is a number less than or equal to speaker's impedance "z"
    Feb 2004
    Tampa, FL
    321
    Well do you think that I would be safe running 75rms to a coaxial that is rated for only 40rms if I turn the gain down halfway or so? Then I wouldn't have to mess with different wiring options.
    outbacksport's Avatar
    outbacksport is offline Senior VIP Member
    May 2003
    S Cal
    309
    What speakers are these?
    Feb 2004
    Tampa, FL
    321
    CDT CL-6X 6.5s
    On their site they say they are rated for 80 watts RMS but when I got the speakers I guess they are only rated for 80rms as a pair.
    May 2003
    S Cal
    309
    How did you come with 80 rms for the pair? Does it show on the speaker that they are 2 ohms?
    According to their site the specs are
    Model: CL-6X (Slim Coaxial)
    Midrange: 6"
    Mounting depth: 2.25"
    Crossover: 6 dB.
    Tweeter: Angle mount .75" metal dome
    tweeter for perfect imaging
    Power handling: 80 watt
    Frequency response: 60Hz-20kHz
    Sensitivity: 92 dB.
    Impedance: 4 Ohm
    Do you have a manual that comes with the coaxials?
    I would think they are 80 rms at 4 ohms.
    Feb 2004
    Tampa, FL
    321
    I thought from the site that they would be 80rms per speaker. But on the back of each speaker it reads 40w nominal.
  9. #9
    adam71's Avatar
    adam71 is offline P9 = Ultimate SQ
    Jul 2003
    Michigan
    5,795
    Quote Originally Posted by Ryde _Or_Die
    It could be that the RMS rating is 40 watts and the max is 80 watts. Just a guess. But if you ran those both off one channel that would be a mono load and you would lose alot of clarity not to mention you'd lose your stereo image. So I'd advise against that. Just run them in stereo and keep the gain down far enough or choose a different pair of speakers that can handle more.
    Adam
    Source Unit: Pioneer P9 combo
    Tweeters: CDT DRT-25 Silk
    Mids: CDT ES-5 (5.25")
    Midbass: CDT M6 (6.5")
    Subs: Pioneer TS-W12PRS
    Mid & Tweet amp: Pioneer PRS-X340
    Midbass Amp: Pioneer PRS-X720
    Sub Amp: Pioneer PRS-X720
  10. #10
    May 2003
    S Cal
    309
    Ryde_or_Die here is what CDT wrote me about your speakers.
    from [email protected]
    Hi, These speakers are designed to be used at lo level as rear fill speakers
    power handling @ 100Hz high pass amp setting is abt 40 RMS 80 max
  1. Terminology - Please contribute
    By frozenfire89 in forum General Discussion
    Last Post: 02-12-2004, 10:06 PM
  2. Help With Wiring 2 10's
    By Bump_and_Blaze in forum Wiring, Electrical and Installation Help
    Last Post: 01-08-2004, 03:09 AM
  3. electric load on car
    By morganator88 in forum Wiring, Electrical and Installation Help
    Last Post: 12-16-2003, 10:25 PM
  4. what ohm load is this?
    By maniackilla in forum General Discussion
    Last Post: 10-22-2003, 11:22 AM
  5. Difference Between 2ohm and 4ohm
    By gdlkn007 in forum Subwoofers
    Last Post: 10-21-2003, 11:06 PM
