Page 1 of 3 1 2 3 LastLast
Results 1 to 15 of 45
Reload Thread: 3 in each door?
    Nov 2010
    Brandon , FL
    31
    4,640
    5 Post(s)
    3 in each door?
    Bassin Buick's Avatar
    Bassin Buick is offline Banned
    Nov 2010
    Brandon , FL
    31
    4,640
    5 Post(s)
    Re: 3 in each door?
    BTW , they would be running bandpassed off of a hifonics eagle bridged to 2 channels.
    Would go in a sealed fiberglass pod below the door panels in my truck.
    Nov 2010
    Brandon , FL
    31
    4,640
    5 Post(s)
    Re: 3 in each door?
    nobody at all??
    CHEMMINS's Avatar
    CHEMMINS is offline CarAudio.com Veteran
    Aug 2010
    Nevernever Land
    4,069
    4 Post(s)
    Re: 3 in each door?
    Meh....bravox are usually overpriced....but those are cheap.
    High qts though....not too cool for doors.
    References:
    kmarei, ge_off_me, AudioPipe, slim2fattycake, Louisiana_CRX, ARMed&Bangin, EXTREMECHEVYMAN, Dpc69ss, Psychoacoustics, Shinju, jonny101abc, snoopdan
    BUYING SILVER TOP TRF MOTORS
    Nov 2010
    Brandon , FL
    31
    4,640
    5 Post(s)
    Re: 3 in each door?
    gonna be in a sealed fiberglass pod. high qts usually needs small sealed enclosures right? I'm not too hip to the t/s stuff.
    CHEMMINS's Avatar
    Aug 2010
    Nevernever Land
    4,069
    4 Post(s)
    Re: 3 in each door?
    high qts = big box
    References:
    CHEMMINS's Avatar
    Aug 2010
    Nevernever Land
    4,069
    4 Post(s)
    Re: 3 in each door?
    2.47 cubes needed for 3 to have a flat roll off with -3db at 80hz
    References:
    Nov 2010
    Brandon , FL
    31
    4,640
    5 Post(s)
    Re: 3 in each door?
    ran the t/s through bassbox pro. gives me a f3 of 100hz with 3 of them in .5 sealed with heavy poly fill. Not that bad.
  9. #9
    Nov 2010
    Brandon , FL
    31
    4,640
    5 Post(s)
    Re: 3 in each door?
    Quote Originally Posted by CHEMMINS View Post
    OUCH!! thats huge!
  10. #10
    CHEMMINS's Avatar
    Aug 2010
    Nevernever Land
    4,069
    4 Post(s)
    Re: 3 in each door?
    Yep.....they are made for HT usage....
    References:
  11. #11
    Nov 2010
    Brandon , FL
    31
    4,640
    5 Post(s)
    Re: 3 in each door?
    so i need to be looking for low QTS?? i'm trying to do a multi woofer setup in the doors with some of the buyout type speakers. something dirt cheap but still good quality.
  12. #12
    CHEMMINS's Avatar
    Aug 2010
    Nevernever Land
    4,069
    4 Post(s)
    Re: 3 in each door?
    https://www.madisound.com/store/prod...oducts_id=8405
    Run 2 in each door.....better bet. 1.63 cubes for 2.....to get a -3 db at 80hz
    References:
  13. #13
    CHEMMINS's Avatar
    Aug 2010
    Nevernever Land
    4,069
    4 Post(s)
    Re: 3 in each door?
    These are what I wanna run....
    Peerless 831735 6-1/2" HDS Driver
    1 cube for 2 to tune to -3db at 70 hz.
    Could go slightly smaller box and gain a lil before roll off.
    References:
  14. #14
    Nov 2010
    Brandon , FL
    31
    4,640
    5 Post(s)
    Re: 3 in each door?
    i've been thinking about those too. but if i go with 2 per door i'm gonna go 8" because i have the room for bigger mids. were talking about a '85 F-150 here. LOL
    prolly just stick with my original plan to use 2 8ohm silver flutes per door. any 8 ohm 8" models you think i should look at? remember i'm not running gobs of power only about 150x2@4 for the mids.
  15. #15
    CHEMMINS's Avatar
    Aug 2010
    Nevernever Land
    4,069
    4 Post(s)
    Re: 3 in each door?
    Dayton Audio DC200-8 8" Classic Woofer
    1.2 cubes for 2......-3db at 60 hz
    References:
