Results 1 to 5 of 5
Reload Thread: MB Quart RSD213
    hpaco's Avatar
    hpaco is offline Junior Member
    Jan 2004
    Puebla, Mexico
    Icon33 MB Quart RSD213
    I want to run this components with a Power Acoustik LT964 rated at 100Wx4@4ohms. The specs of the MB´s are:
    -MBQUART RSD213 5.25" 2 Way Reference
    -Power Range: 40-100 watts, -Tweeter 1" (25mm) REFERENCE Neo Tweeter
    -RWC 130 Midrange 5.25" (130mm) TX-3 Midrange Driver
    but I dont know if it is 40W RMS and 100WPeak,would be to much power running them with 100W????
    hpaco's Avatar
    Jan 2004
    Puebla, Mexico
    Re: MB Quart RSD213
    anybody???
    brandont's Avatar
    brandont is offline Member
    Feb 2004
    Las Vegas, NV
    35
    66
    Re: MB Quart RSD213
    You can run those with no problems, just don't crank the gains. I've had 120w to my stock dual cones for two years (I was between components at the time). As long as you have a good crossover (not the passive one, but the high pass one on the amp or deck) you should be fine. I had my dual-cones at no less than 78hz......NO PROBLEMS. You have some good speakers, don't worry. Tell me the rest of your system....
    Shop around, Retail is always too much!!!!
    Upfront Bass is your friend.
    Alpine CDA-9815's Avatar
    Alpine CDA-9815 is offline CarAudio.com Elite
    Jan 2004
    BFE
    30
    1,454
    Re: MB Quart RSD213
    Yeah it sould be fine using that amp. Power Acoustic I believe overrates their power ratings anyways. So if it says 100 @ 4 ohms you'll proably be lucky to see 50-70.
    hpaco's Avatar
    Jan 2004
    Puebla, Mexico
    Icon7 Re: MB Quart RSD213
    Quote Originally Posted by brandont
    well... at this time this is my system, hehehe. It´s a Renault Megane II Sedan but I´m going to have it next weekend (red flame). I heard the sound and was really bad so i decided to upgrade it as soon as i have it. I didn´t order the rear speakers because nobody knows the size some says 4" some 5" so I better wait to have it and then i will decide:
    1 change the rear speakers for some MB Quart or infinity coaxial's or
    2 put a subwoofer in the trunk sending the another 200W and run the rear speakers with the HU.
    Also I´m not going to change the stock HU soon because I dont want to lose the stering wheel crontrols and the center display. so I´m not going to change until an interface to run these comes. (the model is new, September in europe and last week in mexico)
    Ohhh another question, to improve the sound quality would be helpfull using an equalizer??? (until I change the HU) =)
  1. mb quart
    By awestone05 in forum General Discussion
    Last Post: 01-19-2004, 09:42 AM
  2. MB Quart DSD 213's with Musicomp C/O's
    By 80_Cutlass_mn in forum Speakers
    Last Post: 12-01-2003, 12:04 AM
