Results 1 to 7 of 7
Reload Thread: ok i'm confused
    sq4me's Avatar
    sq4me is offline Junior Member
    Jan 2004
    Idaho
    35
    ok i'm confused
    silk vs titanium
    from reading the forums, i've read that metal tweets are harsher on the ears than silk. I thought silk was better for sq. but yet utopias and hex components are mentioned as some of the best sq comps. I looked them up and both use titanium tweets. So if these are some of the best sounding comps on the market, does it matter whether the tweets use silk or titanium?
    Somebody set me strait.
    -Tyson-
    Berry47's Avatar
    Berry47 is offline CarAudio.com Elite
    Dec 2003
    My Pants
    34
    1,076
    Re: ok i'm confused
    The harshness of aluminum just occurs in most comp sets. I've heard harsh silk tweeters it's in the install and design behind the tweeter.
    Mine: CDT, Eclipse, Diamond Audio, Dayton, Aura
    Wifey: Infinity, Concept, Pioneer, Profile, JBL
    Refs: Ruckus, MSSOKC
    outbacksport's Avatar
    outbacksport is offline Senior VIP Member
    May 2003
    S Cal
    309
    Re: ok i'm confused
    Soft-dome tweeters are not as bright as metal domes b/c their frequency response tends to exhibit a gentle "roll-off" above 16KHz. This makes them more natural sounding by virtue of design, but also makes them favor a more on-axis mounting scheme. There are a few soft dome tweeters out there that have extended high-end response (Dynaudio, for example) because they were designed SPECIFICALLY for off-axis mounting in cars. (The Dynes actually were designed for kick panel applications where extended freq response and off-axis mounting yield the best results and best path lengths).
    Conversely, hard domes, by virtue, do not exhibit much high freq roll-off at all, and likely extend ABOVE 20KHz (which we cant hear anyways). Many mfg’s of hard dome tweeters must in turn design their crossovers with switchable resistances to tame the tweeter's output depending on mounting location. These are the "-2dB, -3dB, -4dB, etc" settings for the tweeters.
    I have Focal 165V2's and they dont sound harsh to me at all, actually they sound really detailed. I might try to replace it with a LPG NFA soft dome just to see if it will sound better.
    adam71's Avatar
    adam71 is offline P9 = Ultimate SQ
    Jul 2003
    Michigan
    5,795
    Re: ok i'm confused
    Quote Originally Posted by outbacksport
    Wow, those were a few things I did NOT know. Well under my posts you see what I'm running for components. The tweeters I'm using are NOT really what I'm looking for and could sound better. Would you know what might be a good replacement tweeter? I'm not worried about certain brand names since you see I'm running MTX Black Gold drivers with an MB Quart 3-way crossover. So let me know if you know a good replacement.
    Adam
    Source Unit: Pioneer P9 combo
    Tweeters: CDT DRT-25 Silk
    Mids: CDT ES-5 (5.25")
    Midbass: CDT M6 (6.5")
    Subs: Pioneer TS-W12PRS
    Mid & Tweet amp: Pioneer PRS-X340
    Midbass Amp: Pioneer PRS-X720
    Sub Amp: Pioneer PRS-X720
    sq4me's Avatar
    Jan 2004
    Idaho
    35
    Re: ok i'm confused
    so in short, you're saying that if you use kick panels (which I plan on building and installing anyways), titanium tweeters won't be as harsh sounding and sound better than in the doors or anywhere else?
    -Tyson-
    sq4me's Avatar
    Jan 2004
    Idaho
    35
    Re: ok i'm confused
    and when i do install components in kick panels, what is the best way to aim the midrange and tweets for optimal sound staging?
    -Tyson-
    adam71's Avatar
    Jul 2003
    Michigan
    5,795
    Re: ok i'm confused
    Quote Originally Posted by sq4me
    Its ALL trial and error. Different automotive interiors are going to act different accoustically. You'll have to experiment along the way. I mean you wouldn't want to build a "*****in" set of kicks and find out they would have sounded better in a different angle. It sounds like a pain in the *** and for the most part it WILL be. But the time you spend on it now will allow you to enjoy them instead of cuss at them in the future.
    Adam
  1. confused on ohms
    By marleyskater420 in forum Wiring, Electrical and Installation Help
    Last Post: 02-06-2004, 09:59 PM
  2. So Confused!!
    By Omarvelous in forum Subwoofers
    Last Post: 01-22-2004, 11:59 PM
  3. Please help! Confused!
    By Superjimbo31 in forum Speakers
    Last Post: 01-05-2004, 10:12 PM
  4. Im sooo confused!
    By ackinum6910 in forum General Discussion
    Last Post: 12-19-2003, 08:39 PM
  5. Torn, confused, you name it.
    By NYC-Havok in forum Speakers
    Last Post: 07-21-2003, 01:31 AM
