noobs leading noobs...teh failz, teh lolz.....One Type R getting a legit 500rms will be louder then the boss, pioneers or duals. That said, I am not saying to get the R, just making a reference because it was suggested. I know as far as budget goes, people have had some luck with the Phoenix Gold RSD subs, and I actually heard a Crunch Ground Pounder 2 12 setup that was pretty loud (but was a legit install by someone with a fair amount of audio acumen)... Both of those subs can be had for well under 100$
edit- it appears the PG's are discontinued, and the sites that have them are about 110$, at that price I would lean to the R's. I did find the Crunch's tho, for around 65$
Team Flex Issues
45s out the trunk..lowww
REFS- Supergumby5000, Lastcall, 919motoring, hippishake, daboyfromdabx (great seller), beach22
power-fanatic07 thanked for this post
Buy that Audiopipe 1500D. It is a great budget amp and will last you a LONG time if you take care of it. Then decide if you want to run two meh 12s or one good 12/15.
^ those ones you linked are what I heard. 2 dvc2s tuned like at 34 or so off a kicker zx 750.1, and it pounded pretty good
Team Flex Issues
It is very necessary, if you are new you should not be helping others because you are still learning, just keep your mouth shut and read up, then give people some actual advice, not just what you want to buy.
As for the OP, listen to Magnus and some of these other guys, they've been here forever and know what they are talking about.
2002 Chevrolet Trailblazer LT
Pioneer AVIC-U310BT | Eclipse SC6500 | MB Quart Q4.80
(2) Fi BTL N2 12 in 4.5 cubes @ 33hz | Cactus K5 | XS D3100 & D3400 | Knu 0 Gauge | Big 3 | 250a Alt
SSA Dcons , sundown sa series , or Incriminator 187 series are great budget subs. and the audiopipe ap1500d is a great budget amp.
dcon's and 187's are rated at 300 rms but handle close to double that amount daily , and the sa series will handle 1K daily. my little brother runs 2 dcon 10's in a 2.5cu ft @ 32 hz box that i built. they play loud and proud and get super deep in his extended cab truck.
I think boss subs let off a chemical when you play them that turns you into a retard.
Got Refs? http://www.caraudio.com/forum/itrader.php?u=47119
Bookmarks
